Re: Which extruder to choose? March 12, 2015 04:20PM |
sheepdog43
You would be doing double duty and getting the worst of both systems, the complexity, ineficiency, and hassle of a geared extruder, and the added cost of a geared stepper all to accomplish what you could do with just a geared extruder.Quote
3DRapidClone
I see! The 5:1 geared nema stepper is a bit over geared right? So it slows retraction a bit? Seen anyone try to gear it down to 3:1 if that's even necessary? Im hoping an astroyn damper will fit too but it probably won't due to it needing to be close together.
I agree 3:1 is closer to ideal, but from a simplicity standpoint, the geared stepper is just so much easier to live with on a day to day basis.Quote
hercek
That is the reason I use printed gears. 5:1 (common for geared steppeers) is too much. Your retract speed will be low (probably below 50 mm/s). My opinion is one should have retract speed at least 100 mm/s for ABS with 0.5 head.
If we could get a 2:1 or 2.5:1 geared stepper, I would jump all over it.
Re: Which extruder to choose? March 12, 2015 06:06PM |
StickyLube
@AndyCart
About the Gerg's Wade extruder..do you know if someone is selling an entire kit for assembling it?
Cos all I have found till now are thinginverse designs, and I am not even sure which one is the most reliable for 1.75mm filament.
Re: Which extruder to choose? March 13, 2015 01:54AM |
