NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 09, 2014 05:45PM |
//#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line)
'ACCURATE_BED_LEVELING_POINTS' was not declared in this scope Marlin_main.cpp: In function 'void adjust_delta(float*)': Marlin_main.cpp:3287: error: 'ACCURATE_BED_LEVELING_POINTS' was not declared in this scope Marlin_main.cpp:3288: error: 'ACCURATE_BED_LEVELING_GRID_X' was not declared in this scope Marlin_main.cpp:3289: error: 'ACCURATE_BED_LEVELING_GRID_Y' was not declared in this scope Marlin_main.cpp:3294: error: 'bed_level' was not declared in this scope
I COMMENTED OUT ALL THOSE LINE:
//int half = (ACCURATE_BED_LEVELING_POINTS - 1) / 2;
//float grid_x = max(0.001-half, min(half-0.001, cartesian[X_AXIS] / ACCURATE_BED_LEVELING_GRID_X));
//float grid_y = max(0.001-half, min(half-0.001, cartesian[Y_AXIS] / ACCURATE_BED_LEVELING_GRID_Y));
//int floor_x = floor(grid_x);
//int floor_y = floor(grid_y);
//float ratio_x = grid_x - floor_x;
//float ratio_y = grid_y - floor_y;
// float z1 = bed_level[floor_x+half][floor_y+half];
//float z2 = bed_level[floor_x+half][floor_y+half+1];
//float z3 = bed_level[floor_x+half+1][floor_y+half];
// float z4 = bed_level[floor_x+half+1][floor_y+half+1];
// float left = (1-ratio_y)*z1 + ratio_y*z2;
//float right = (1-ratio_y)*z3 + ratio_y*z4;
//float offset = (1-ratio_x)*left + ratio_x*right;
// delta[X_AXIS] += offset;
// delta[Y_AXIS] += offset;
//delta[Z_AXIS] += offset;
…)Reporting endstop status x_max: open y_max: open z_max: open
SENDING:M119 Reporting endstop status x_max: TRIGGERED y_max: open z_max: open >>>M119 SENDING:M119 Reporting endstop status x_max: open y_max: TRIGGERED z_max: open >>>M119 SENDING:M119 Reporting endstop status x_max: open y_max: open z_max: TRIGGERED
echo:endstops hit: Y:1.78 echo:endstops hit: Y:1.81 echo:endstops hit: Y:1.84 Z:1.84 echo:endstops hit: X:1.94 Y:1.94 Z:1.94 echo:endstops hit: X:1.97 Y:1.97 Z:1.97 echo:endstops hit: X:2.00 Y:2.00 Z:2.00 echo:endstops hit: X:2.03 Y:2.03 Z:2.03
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 03:24AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 04:33AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 07:02AM |
Reporting endstop status x_max: TRIGGERED y_max: TRIGGERED z_max: TRIGGERED
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 07:42AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 09:17AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 10:39AM |
homing very smoothly
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 10, 2014 11:24AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 11, 2014 09:34AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 12, 2014 01:16PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 12, 2014 07:41PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 12, 2014 07:45PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 05:40AM |
G1 X -100 Y -100
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 05:49AM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 03:26PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 03:42PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 06:02PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 08:00PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 13, 2014 08:11PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 15, 2014 06:42PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! April 15, 2014 06:48PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! July 12, 2014 10:20AM |
and first print was the cube 20*20*20
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! July 12, 2014 06:35PM |
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! July 14, 2014 08:30AM |
