NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! sad smiley
April 09, 2014 05:45PM
Dear Reprappers and experts
My first post (not the last off Corse) smiling smiley
Finished from my build of a standard rostock with original dimension
(RAMP 1.4 - INDUINO MEGA 2560 – MECHANICAL ENDSTOPS V1.2 – A4988 STEPPER DRIVER – T2 BELT – 20 TOOTH ALU PULLEY – NEMA 17 STEPPER MOTOR)
I download the latest marlin, adjust the value in (configuration.h) (configuration_adv.h) to match value of files inside (example_configurations) folder and edit the value corresponding to my build
I disabled
//#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line)
When I tried to compile, it gives the following error:
'ACCURATE_BED_LEVELING_POINTS' was not declared in this scope
Marlin_main.cpp: In function 'void adjust_delta(float*)':
Marlin_main.cpp:3287: error: 'ACCURATE_BED_LEVELING_POINTS' was not declared in this scope
Marlin_main.cpp:3288: error: 'ACCURATE_BED_LEVELING_GRID_X' was not declared in this scope
Marlin_main.cpp:3289: error: 'ACCURATE_BED_LEVELING_GRID_Y' was not declared in this scope
Marlin_main.cpp:3294: error: 'bed_level' was not declared in this scope
WHAT I DID smiling smiley I COMMENTED OUT ALL THOSE LINE:
  //int half = (ACCURATE_BED_LEVELING_POINTS - 1) / 2;
  //float grid_x = max(0.001-half, min(half-0.001, cartesian[X_AXIS] / ACCURATE_BED_LEVELING_GRID_X));
  //float grid_y = max(0.001-half, min(half-0.001, cartesian[Y_AXIS] / ACCURATE_BED_LEVELING_GRID_Y));
  //int floor_x = floor(grid_x);
  //int floor_y = floor(grid_y);
  //float ratio_x = grid_x - floor_x;
  //float ratio_y = grid_y - floor_y;
 // float z1 = bed_level[floor_x+half][floor_y+half];
  //float z2 = bed_level[floor_x+half][floor_y+half+1];
  //float z3 = bed_level[floor_x+half+1][floor_y+half];
 // float z4 = bed_level[floor_x+half+1][floor_y+half+1];
 // float left = (1-ratio_y)*z1 + ratio_y*z2;
  //float right = (1-ratio_y)*z3 + ratio_y*z4;
  //float offset = (1-ratio_x)*left + ratio_x*right;
 // delta[X_AXIS] += offset;
 // delta[Y_AXIS] += offset;
  //delta[Z_AXIS] += offset;
MAYBE THIS IS A MISTAKE BUT I THOUGHT ITS ONLY FOR AUTO BED LEVELING
But voila it compile smiling smiley
Then I succeeded to upload the firmware to my board
(very excited to see it moving but sad smiley …)
Now lets go to PRONTERFACE
***HOME ALL AXIS RESULT :***
even if its on middle of the tower far from endstops it wont move. each axe separately and by sequence jump up little bit and go back down to its original position with a buzzy sound coming from stepper motor like a noisy beep
***SENDING M119 result :***
All endstops free:
Reporting endstop status
x_max: open
y_max: open
z_max: open
now I press X Y Z seperatly and send the commad for each so the result is :
SENDING:M119
x_max: TRIGGERED
y_max: open
z_max: open
>>>M119
SENDING:M119
x_max: open
y_max: TRIGGERED
z_max: open
>>>M119
SENDING:M119
x_max: open
y_max: open
z_max: TRIGGERED
If I move Z up in pronterface until hitting the endstops :
echo:endstops hit:  Y:1.78
echo:endstops hit:  Y:1.81
echo:endstops hit:  Y:1.84 Z:1.84
echo:endstops hit:  X:1.94 Y:1.94 Z:1.94
echo:endstops hit:  X:1.97 Y:1.97 Z:1.97
echo:endstops hit:  X:2.00 Y:2.00 Z:2.00
echo:endstops hit:  X:2.03 Y:2.03 Z:2.03
even when its showing hit , it wont stop sad smiley
Please if any one can guide me !!!!!!!!!
Its painful when its finished and not working
Please find attached my (configuration.h) (configuration_adv.h)
Many thanks in advance smiling smiley
open | download - Configuration.h (31.5 KB)
open | download - Configuration_adv.h (19.5 KB)
Re: NEED HELP !!! ROSTOCK BUILD - WHATS WRONG !!! sad smiley
April 10, 2014 03:24AM
I am just building my own version of a delta, and am using repetier firmware which deos config slightly differently.
However the issue you have seems to be familiar with many who build delta's, it is related to the endstop config, in that the end stops maybe set as normally open, but you have the config for normally closed, so the machine is trying to get a to a normally closd point,. Or you may have the config in the reverse, but the same is true in that the prog is looking for the wrong signal.
April 10, 2014 04:33AM
Basically the same as daveb500 said + I think you also need to comment out:
#define ACCURATE_BED_LEVELING
April 10, 2014 07:02AM
daveb500 / imyz
many thanks for your replies
i tried REPETIER and face same exact problem
i cleared EEPROM nothing change
if i invert the logic of my endstops it seems the result not as expected
All endstops free:
x_max: TRIGGERED
y_max: TRIGGERED
z_max: TRIGGERED
in this case if i do homing all axes jump few mm and stop
any suggestion
thanks again
April 10, 2014 07:42AM
Hi LB-3D
Your endstop configuration is working o.k although you seem to have your switches wired NO I.e they go closed circuit when you operate them. That's o.k though because you have the logic set to 'true'. The acid test is what happens when you send M119. As per your post all seems o.k. So it's not your endstop configuration causing the issue. You have your micro stepping set at 1/16. For your A4988 drivers that would mean all three jumpers under the driver on RAMPS being populated. Are they? Given that your end stops are operating correctly it must be something else. I would go back to a fresh copy of Marlin and just comment out #define ENABLE_AUTO_BED_LEVELING and #define ACCURATE_BED_LEVELLING and recompile
Andy
April 10, 2014 09:17AM
Do you have a thermistor connected? I cannot recall at the moment if the printer would run without the thermistor, if you have it defined in the firmware.
Try to define the temp sensor ar 0 and try again. It's this line:
#define TEMP_SENSOR_0 0 (you have 1 at the moment).
Sorry, I am not at the printer and cannot test it to be sure.
April 10, 2014 10:39AM
HOOOOORAY!!!!
ANDY U'R RIGHT - THANK YOU VERY MUCH - you saved me
i didn't know that those jumper are related to stepper driver eye rolling smiley
once installed - homing - and thats it grinning smiley homing very smoothly
THANKS AGAIN
/// imyz
u'r right, first it's always showing on my lcd an error about temp so i connect my thermistor and hotend to my ramp (its ready why not to connect grinning smiley)
really thank you all for your support and fast responce
(off corse i'll come back soon with calibration issue and update) cool smiley
April 10, 2014 11:24AM
No problem. Glad to help. If you print a z probe and install Rich Cattell's Marlin fork your printer will calibrate itself!
Andy
April 11, 2014 09:34AM
Andy
sure i will once mine get printing grinning smiley .
i have a problem now
my printer consider center of the bed as origin
where should i adjust this??
don't know if its on marlin or pronterface or when generating g-code!!!
thanks
April 12, 2014 01:16PM
Andy,
Great job. What would cause all switches to be triggered when one is triggered though?
Here is my issue where M119 shows all open, then I hold down X and M119 shows all triggered. Are they connected to the board wrong or share some sort of grounding issue?
Here is my post with video showing how odd my machine is: http://forums.reprap.org/read.php?178,336014
Thanks,
Mike
April 12, 2014 07:41PM
Hi Mike
That's weird! They must either be connected incorrectly or your pins.h file is designated wrong. I have a Sanguinololu board in another machine and the pins are different to RAMPS for the end stops. On RAMPS it's a centre pin and an outside pin that go to C and NC on the microswitch on Sanguinololu it's the outside two pins. Check your connectors with a meter before you do anything else. Good luck
Andy
April 12, 2014 07:45PM
Hi LB-3D
The origin should be the centre of the bed I.e X0 Y0 Z0 should have your hotend about 0.1mm above the centre of the build plate. Marlin will set it up that way and you need to set Pronterface the same in your machine config options.
Andy
April 13, 2014 05:40AM
Dear Andy
i tried to configured pronterface without any success
still considering center of the bed as origin
so i adjust slic3r and put a command in the starting of the G-code
G1 X -100 Y -100
eye rolling smiley
and it works smiling bouncing smiley
maybe this is not the right way but at least i enjoined last night plotting with my printer with a pen (did't get my plastic yet yawning smiley )
Really its amazing
i will retry to adjust pronterface later and i will update
thanks again
April 13, 2014 05:49AM
Dear Mike
hope that you will figure out whats wrong soon, and you can start enjoying yours
once i get time i will try to give a hand (i am new to this grinning smiley)
keep us updated
and take care
April 13, 2014 03:26PM
Okay, I'm much better now. Going back to my post to comment. Basically though, there are 4 wires on my endstop board and I am ignoring everything but the GND and the S and getting better results.
April 13, 2014 03:42PM
Andy,
Yep, you are right again. I'm using the following Sainsmart endstops and I just needed to choose one of the two GND wires in the middle to connect to my SIG and GND wires on the board.
Now I must figure out why my motors move way to harsh and far. The darn thing is going to vibrate off my table. Searching internet now...
Thanks again,
Mike
April 13, 2014 06:02PM
Hi Mike
I suspect it's because you don't have the jumpers installed that tell your drivers what micro stepping mode you are using. If you have A4988 drivers and have set your steps per mm in Marlin to use 1/16 micro steps you need all three jumpers populated on the Sainsmart board. I believe they ship without them.
Or you have your homing federate set too high. Default in most Marlin forks is 200*60 changing hat to 100*60 for x,y and z may help
Andy
Edited 1 time(s). Last edit at 04/13/2014 06:04PM by AndyCart.
April 13, 2014 08:00PM
If Sainsmart's RAMPS board is anything like their Megatronics kit, they didn't ship it with DIP jumpers and you will need to buy three for each stepper driver to set the correct micro-stepping rate.....
April 13, 2014 08:11PM
Here's a post from today, showing the RAMPS board with the micro-stepping jumpers installed:
http://forums.reprap.org/read.php?262,336883,339384#msg-339384
Edited 1 time(s). Last edit at 04/13/2014 08:12PM by vreihen.
April 15, 2014 06:42PM
Andy & vreihen,
You both are awesome! Missing jumpers were the issue. I must have been running full steps and almost vibrating my machine apart.
I know how this happened, too. I'm new to the board and the use of the Polu boards so I stuck them right in when I got the kit and had since then forgot that there are jumpers under the stepper boards.
Ran out to Radio Shack, bought the jumpers for 2 bucks and now it is running very smooth and homes well.
Next step for me is to configure the homing settings as I do not have a sensor for auto leveling. Perhaps I should invest in that as it seems that everyone uses one.
Thanks again you two!
Mike
April 15, 2014 06:48PM
You are most welcome sir.
If you are running Rich Cattell's Marlin then manual calibration is very easy as all the required values, endstop offsets, z height, delta radius and delta rod length can be changed from Pronterface with an M666 command so you don't need to continually upload changes via the IDE.
Check out this website for info on how to calibrate [minow.blogspot.co.uk]
Andy
July 12, 2014 10:20AM
Dear friends
First I want to thank you all for your support and for this Forum
Special thanks for JOHANN, RICHRAP, ~Russ and ANDY CART.
This is a fast log about my build and its capabilities for now (still improving) cool smiley
Supplier of my kit forget 1 pulley and the belt is short confused smiley
I find myself stack for 2 week until supplier send missing parts
Once received – installed – ready – and I face homing issue
After getting your help and pointing to missing jumper under stepper driver
Fix them and voila homing very smooth
I start,cool smiley and first print was the cube 20*20*20
As you see in pic cube is almost very nice (H) is exact 20 but (L) 20.65 and (W) 20.25
The second print was 30*30*30 hollow cube and I was surprised with bridging quality but in that phase too much ooze from hot end going from side to side but it’s easy to clean with a knife (later after enable wiping and retract, problem solved)
Both print speed 60 mm (default silc3r setting)
My third print is hollow pyramid
Trying to reprint a cube, hot end temp increasing reach 140 and suddenly start decreasing
What’s wrong? Don’t know
After inspecting everything without noticing any loose in wiring I decide to check heater itself !!!
Yes, it’s burned out with hole in middle!!!
((No thermal paste between heat block and heater, I think it suffer very high temperature to heat my hot end and die early))
Again find myself waiting for parts
((I learned in a hard way to buy lot of replacement parts, and this what I did eye rolling smiley))
After getting replacement (cover with aluminum foil) I continue my calibration
All printed parts I bought from e-bay are very week and start broken very easily even I am not working with it and without tightening screws.
So first things I decide to do is reprint my parts even without good calibration (I successes: D)
Now this is what my printer look like for now and what it can do grinning smiley
((bearing is moving directly))
((yes i am using the cover grinning smiley))
Sorry for long post
Many thanks
LB-3D
July 12, 2014 06:35PM
Well done
July 14, 2014 08:30AM
Edit: I see your solution was found. good luck.
Edited 1 time(s). Last edit at 07/14/2014 08:31AM by umdpru.
