Idea: A RepRap Hanging From the Ceiling April 23, 2014 11:16AM |
Re: Idea: A RepRap Hanging From the Ceiling April 23, 2014 11:30AM |
Re: Idea: A RepRap Hanging From the Ceiling April 23, 2014 05:21PM |
Re: Idea: A RepRap Hanging From the Ceiling April 24, 2014 05:39AM |
Re: Idea: A RepRap Hanging From the Ceiling April 24, 2014 05:53AM |
Re: Idea: A RepRap Hanging From the Ceiling April 24, 2014 08:29AM |
Re: Idea: A RepRap Hanging From the Ceiling April 24, 2014 05:51PM |
Re: Idea: A RepRap Hanging From the Ceiling April 24, 2014 10:51PM |
Re: Idea: A RepRap Hanging From the Ceiling April 25, 2014 05:56AM |
Re: Idea: A RepRap Hanging From the Ceiling April 25, 2014 01:17PM |
Re: Idea: A RepRap Hanging From the Ceiling May 15, 2014 05:29PM |
Re: Idea: A RepRap Hanging From the Ceiling May 15, 2014 08:45PM |
Re: Idea: A RepRap Hanging From the Ceiling December 15, 2014 06:39PM |
Also, a little design work have been collected in a Github repo.|
Re: Idea: A RepRap Hanging From the Ceiling December 15, 2014 07:37PM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: Idea: A RepRap Hanging From the Ceiling December 16, 2014 03:46AM |
Re: Idea: A RepRap Hanging From the Ceiling December 16, 2014 04:05AM |
Re: Idea: A RepRap Hanging From the Ceiling December 16, 2014 04:25AM |
Re: Idea: A RepRap Hanging From the Ceiling December 16, 2014 05:00AM |
tobben
... What was it that made you abandon the idea?
Re: Idea: A RepRap Hanging From the Ceiling December 16, 2014 05:44AM |
tobben
What you're desicribing sounds similar to the SkyDelta without the springs?
Re: Idea: A RepRap Hanging From the Ceiling December 17, 2014 07:26PM |
Re: Idea: A RepRap Hanging From the Ceiling December 17, 2014 08:03PM |
Re: Idea: A RepRap Hanging From the Ceiling December 18, 2014 12:34PM |
Re: Idea: A RepRap Hanging From the Ceiling December 18, 2014 02:58PM |
Re: Idea: A RepRap Hanging From the Ceiling December 18, 2014 07:29PM |
Here is the link to the marlin firmware kinematic function: [github.com]|
Re: Idea: A RepRap Hanging From the Ceiling December 19, 2014 05:14AM |
Re: Idea: A RepRap Hanging From the Ceiling December 19, 2014 05:56AM |
Re: Idea: A RepRap Hanging From the Ceiling December 19, 2014 06:52AM |
Using really organic shapes. Not sure if you can use clay but maybe a type of cement. Or something that extrudes good. You could install it outside in a large area. But if you scale it up you'd probably have to compensate for the "slop" of the cables. Just dreaming of course! The biggest hurdle would be overhangs and printing ceilings. Of course the material costs for printing a large scale house would be high. But generally this is the best concept for DIY house printing because you don't need large heavy and stiff frames or cranes. |
Re: Idea: A RepRap Hanging From the Ceiling December 19, 2014 07:51AM |
I plan on having the motors on the platform. This makes the design more compact too.Quote
Dejay
You have to make the print head extra heavy.
That's why I think three action lines downwards (lines from print platform towards wall/floor) is a good idea. The one action line going to the roof could be made triple and attached to each corner of the triangular print platform to handle forces downwards. Three lines of equal length towards the roof would help keeping the platform flat, and would have no syncing issues since they are driven by the same motor. If this would allow us to skip the paralellogram lines downwards, that would be a nice simplification (no need for bearing at wall/anchor point).Quote
Dejay
The main problem seems to be though that during extrusion the extruder normally "flattens" the extruded material and "scrapes" a bit over the stuff. This is normal but with wires this causes forces upwards and creates slop.
Absolutely, but I think there is a possibility to make the homing process much cheaper and simpler. I sketched it out on the wiki-page. It's basically just putting a detectable point on each of the lines. This procedure forces the linefeed-mechanism to be slack tolerable (which it should be anyways).Quote
Dejay
They mention an automatic homing system. There are tracking solutions for PC games using web cameras and IR LEDs. That could be used to automatically calibrate and supervise the printing process.
Re: Idea: A RepRap Hanging From the Ceiling December 19, 2014 06:11PM |
Re: Idea: A RepRap Hanging From the Ceiling December 27, 2014 12:50AM |
