Auto level probe question (Kossel Mini)
Posted by WZ9V
April 28, 2014 01:25PM
I may just be missing something but I'm confused about auto level on a Kossel Mini.
Mine is pointed towards the stepper labeled as X, should I rotate everything to point it toward Z instead?
I dug out a diagram and instructions that say the switch is plugged into Z-Min but it wasn't clear if the probe needed to be pointed toward the Z-tower or not.
Re: Auto level probe question (Kossel Mini)
April 28, 2014 02:55PM
If you mean, how it's mounted on the effector, yes toward the Z (center rear tower). Be aware, the use of a microswitch and a bent wire has been abandoned as unreliable.
April 28, 2014 07:08PM
Thanks. I may just yank it off then. It didn't seem too stable and I'm putting in a heated bed anyway.
April 28, 2014 11:55PM
I have a blog post and a video on how to calibrate if you need them
[reprapandme.blogspot.com]
April 30, 2014 09:54PM
That's helpful, thanks.
