Auto Level problems
Posted by Arachne
Auto Level problems
May 01, 2014 06:52AM
I took the challenge to build a Kossel myself. Thanks to all the stuff that can be found it is not as hard as I expected.
But one thing that is bugging me now for several weeks is that I cannot manage to get the auto level working.
I took the “old” version with the Allenwrench and the micro switch, I managed to deploy the Z_Probe what took me some patience because I changed the geometry that I got a wider bed (took 300mm instead of 240mm profiles).
If I do the G29 it does deploy the probe, does one probing and after that continues to probe up in the air.
Is it because I changed the geometry? All the necessary information are put in the config.h (I believe).
Or is it anything else I missed?
I appreciate every Idea, and that you read this.
Re: Auto Level problems
May 03, 2014 07:38PM
With the probe retracted send a M119 command and copy/paste your results.
May 06, 2014 10:58AM
SENDING:M119
Reporting endstop status
x_max: open
y_max: open
z_min: TRIGGERED
z_max: open
Thanks for trying to help!
May 06, 2014 11:41AM
Have a look at these threads for your answer.
[forums.reprap.org]
[groups.google.com]
