Kossel upsize
May 27, 2014 11:34AM
I'm going to build Kossel (2020 alu version) I want 220mm diameter of print area. Anyone know how to upsize it please?
tru168
Re: Kossel upsize
May 27, 2014 07:22PM
Well the beauty of the Deltas is that upsizing is simpler than with cartesian printers. There is an exel file floating around with lets you calculate the base triangle, arm length and height etc for any diameter bed.
I myself are working on an upscale wolfstock and I had my size only limited by the length of available Vrail extrusion, but since the brackets stay the same and the alu extrusion doesnt bend under its own weight, you´re good.
Re: Kossel upsize
May 27, 2014 10:33PM
Thanks for info. I googled around and can't find any resize calculator excel file . do you have any link for that please?
Re: Kossel upsize
May 27, 2014 11:42PM
Search "Kossel Frame Calculator"
Re: Kossel upsize
May 28, 2014 01:15PM
I have a copy of the excel file, however its cumbersome to use. I have been using this for my calculations. Take things with a grain of salt though and add a coefficient of error. [www.thinkyhead.com]
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
Re: Kossel upsize
May 28, 2014 09:20PM
Thanks for info, it works !
Regards,
Ew
