Cherry Pi III Is Available
Posted by AndyCart
nka
Re: Cherry Pi III Is Available
August 01, 2014 11:33PM
I tried the "G30 A" on a 40mm bed (more than that, rods are disconnecting) until I get the new part. I runned for 17 time until I stopped it.
Does it run until all parameter are staying the same? Since my rods are not stable, that might cause some issue, but I was just wondering! smiling smiley
Edited 2 time(s). Last edit at 08/01/2014 11:35PM by nka.
- Sebastien Plante (nka)
August 02, 2014 01:45AM
nka
It runs for a while sometimes. I have had it converge after 23 iterations and once after 78! The better built your machine is the quicker it converges. How many taps, on average, was it doing before it moved on to the next spot? It needs to get 2 readings the same to move on, or if it doesn't after 7 taps, it takes the median reading. My machine normally do two or three taps in each location. This is a good indication that the probe is accurate. Also make sure that your Z probe offset is a little positive. I normally start with about 0.6mm. X & Y offsets are both zero. The M666 L command is really useful. It reads current values, each has it's own letter code and you can change values with the same code e.g M666 H232.4 will set your Z height M666 X-1.5 will set the X end stop offset. You can combine codes too M666 H232.4 X-1.5 R118.45, etc
nka
August 02, 2014 02:11PM
Oh so that's normal. I guess the software is trying to get the same result as the last test before calling it "Done". Can wait to try again with the new setup.
It was doing 2 tap on the middle, and 2-3 elsewhere, except at one spot, was keep doing 7 taps, but at the place the effector isn't leveled at all, almost disconnected.
August 02, 2014 05:18PM
i had the problem with much tapping too. in my case i set m y x y z steps per mm from 80 to 80.2 after that the auto leveling was tapping 10-15 times till the piont was stored.
with 80steps/mm the problem was solved.
August 02, 2014 06:28PM
hello Andy,
Realy love your job on this printer! I'm currently working on making one but i'm not gonna use magnetic arm , i have some traxxas Rod end and some carbon tube to make my arm. My problem is that i'm not really good for designing a part and i wanted to know if there is a chance to see a version of your effector with traxxas ball joint fixation like the kossel mini effector (same space beetwen the rods).
August 03, 2014 10:03AM
Last night, I had *another* spherical magnet break free of the CA glue on my effector plate mid-print! sad smiley My printer uses 1/2 inch (12.7mm) spherical magnets, and I used my ball end mill to ream the cups on the effector plate before gluing the magnets. Instead of using more CA this time, I put a dab of ABS juice (acetone and ABS filament) into the socket and clamped the sphere overnight. It has held up to 15 minutes of printing so far...but then two *different* magnets let go...one of them on a carriage this time.
I am starting to question my sanity here. My first printer (Delta RepStrap) used an M5 SHCS with the spherical magnet attached with CA as the attachment mechanism. It printed over a spool of filament without losing a magnet, and ultimately failed because the effector plate was printed in PLA and it melted down several times printing ABS to the point where it was fatigued and rubbery even at room temperature. I printed enough Cherry Pi parts to make a replacement printer, but used an early CP-I effector plate and Johann's continuous ball sliders (that did not work well for me) because they were printed before the first printer failed. Those parts held up enough to print three new complete V-roller CP-III carriages, a new CP-III effector plate, and about 1/2 spool of other stuff without incident. In the past week, it has not been able to run more than 1/2 hour without throwing a magnet for some reason.
Long story short, I have decided to rip all of the magnets off of the current effector/carriages, wash them in acetone, and then install them onto the new CP-III effector/carriages using either a different brand of CA or else ABS juice if the one that I re-attached with it instead of CA last night is the toughest to get off.....
nka
August 03, 2014 11:36AM
you should look some post above, there's a new solution without magnet.
In fact, this post : [forums.reprap.org]
Edited 1 time(s). Last edit at 08/03/2014 12:53PM by nka.
August 03, 2014 05:25PM
Cammi
hello Andy,
I don't really have time to produce another effector design they take quite a while in Sketchup. Why don't you build my new 'magnetless' (is that a word? Lol) effector and go with that one. Or you could use your Traxas joints in a Kossel. It looks like a great machine. I'm pretty sure some one has published a 2020 version of it somewhere.
August 03, 2014 05:42PM
If you go back to page one, you can see who planted the seed for this idea: smiling smiley
http://forums.reprap.org/read.php?178,361141,361905#msg-361905
...and what happened when I tried it: sad smiley
http://forums.reprap.org/read.php?178,361141,366738#msg-366738
Based on Andy's success having the ball attached to the rod instead of to the effector like I was trying to do, I may take the 1/2 inch Delrin balls that I purchased for my original testing and drill them out to insert my CF rods into and try it his way. I am still convinced that thin parachute shock cord will work for the spring.
My first priority is getting back to having a functional printer, so that means that I will need to use the magnets and parts that I already have printed for now. When breaking the magnets off, the one attached with ABS juice was not as secure as some of the ones held on with CA. I cleaned my ball end mill with brake cleaner to remove any residual oil, cut clean 1/2 inch cups into the effector and carriages, and will use a different brand of CA to attach my 1/2 inch spherical magnets once they are done soaking in acetone to remove the old CA residue. Then, it is back to re-calibration since everything but the rod length will have changed.....
nka
August 03, 2014 06:08PM
As FYI, I use Gorilla CA Glue. Work very nicely and I love the content.
In fact, I also have wood glue and "normal?" glue from them.
August 04, 2014 02:26AM
I always use high viscosity CA it's the consistency of maple syrup and stinks to high heaven but it sticks pretty good. Roughing up the plastic helps too. The ones that I have had fail seem to let go of the ABS first. I always clean the magnets in acetone before I glue them.
nka
August 04, 2014 03:00PM
If your doing the magnetless effector, seems that motherboard/harddrive screw work just fine into it ! smiling smiley
nka
August 05, 2014 02:10PM
Got the new "magnetless" effector installed. It seems pretty much more stable than the magnet (from "manual" mouvement). It's pretty much easy to build too. Just not sure about the balls milling (how did you do it Andy?).
I hope I'll have time to test it soon ! I'm pretty sure I'm at only some hours from printing something. Hope calibration will be okay (It should, x-y-z are moving at exact distance after calibration and same for extruder). I'll test a 10x10 cube tonight if I can.
August 05, 2014 02:30PM
Well done Sebastien. I knew you would get there :-) As far as milling the 4mm diameter hole 4mm deep in the 8mm diameter stainless steel balls goes. I would like to say that it's due to my superior cnc, milling, lathe and general engineering skills. But that wouldn't be quite true. The fact is I cheated and bought them on ebay :-)
Here's the link [www.ebay.co.uk] they are not a bad price at £8.25 (inc postage in the UK) for 50. As I'm building quite a few printers now having 38 spare wasn't a problem!
Can't wait to see the 'first print'video.
Andy
nka
August 05, 2014 09:41PM
Calibration finished after 99 time. I guess it's not "normal". Everywhere, the printer tap 2-3 time, except for the middle point between x and y, she's always tapping 7 times (not sure for the last want, I wasnt there).
20:58:45.880 : Iteration: 99
20:58:45.880 : Adjusting Endstops..
20:58:54.727 : | -0.0376 -0.0251 -0.0251 		Exact Match: -0.0251	Range:  0.0125 mm
20:58:57.972 : |  0.0249  0.0499  0.0374  0.0374 		Exact Match:  0.0374	Range:  0.0250 mm
20:59:00.618 : |  0.0124 -0.0251 -0.0251 		Exact Match: -0.0251	Range:  0.0375 mm
20:59:03.874 : | -0.0001  0.0374  0.0249  0.0249 		Exact Match:  0.0249	Range:  0.0375 mm
20:59:09.014 : |  0.3624  0.3249  0.2499  0.1749  0.0999  0.0249 -0.0376 		Mode/Median:  0.1749	Range:  0.4000 mm
20:59:11.657 : | -0.0251 -0.0376 -0.0376 		Exact Match: -0.0376	Range:  0.0125 mm
20:59:13.684 : | -0.0376 -0.0376 		Exact Match: -0.0376	Range:  0.0000 mm
20:59:13.684 : |	Z-Tower			Endstop Offsets
20:59:13.688 : | 	 0.0374			X:-3.31 Y:-4.23 Z:-1.39
20:59:13.688 : | -0.0251 	-0.0376		Tower Offsets
20:59:13.692 : | 	-0.0251			A:0.01 b:-0.44 C:0.42
20:59:13.692 : |  0.0249 	-0.0376		I:0.75 J:0.00 K:-0.12
20:59:13.697 : | 	 0.1749			Delta Radius: 119.9016
20:59:13.697 : | X-Tower	Y-Tower		Diagonal Rod: 233.2116
20:59:13.701 : Auto Calibration Complete
20:59:13.701 : Issue M500 Command to save calibration settings to EPROM (if enabled)
21:38:15.068 : echoconfused smileyettings Stored
I'll install my E3D soon, and I'll be able to recalibrate and test printing ! smiling smiley
What is the best way to "tight" the belt?
Bonus video (it was only doing a G30, was testing some change in the firmware)
[www.youtube.com]
Edited 2 time(s). Last edit at 08/05/2014 09:49PM by nka.
August 06, 2014 02:33AM
Looks great. Best way to tighten the belts is to loosen the screws on the steppers and lift them to the top of the slots. Pull the belt loop into the rod carriers as tight as you can get it and then screw a 10mm M3 SHCS into the 'loop' the belts will be fairly tight at this point. Push down on each stepper to fully tighten then tighten up the stepper mount screws. You will be able to 'twang' them now!
nka
August 06, 2014 11:05AM
I feel stupid now... didnt think of loosen the stepper... lol
If I'm lucky, I already have them on the "TOP", so I will be able to loose them and push them to the bottom! grinning smiley
btw, you think my calibration look great? Isnt 99 the "maximum" of interation ?
August 08, 2014 04:20AM
I finished my printer last night!
Here's the first print:
YouTube
I was trying to test out how to set the z-offset for home and kicked off the print just to see what it would do. The head went slightly too low (I must've forgotten to compensate for the tape), so it plowed right through the tape and kept on printing.
I never expected the first print to be so successful! Very happy.
Great design, Andy!
Now I just have to figure out that auto-probe stuff.
(Oh, and due to it being re-fit for NEMA 23s I figured it needed a new name. Enter the Cherry Pit!)
August 08, 2014 10:56AM
hey,
the print quality of my pi is not bad, but if i print larger pieces, the problem is that the nozzel still scrubs on the last layer. i have tested g30a but still the same.
i think the problem is when the printer make a direction change, the nozzel lifts ca 0,1 mm up. i made a video [youtu.be] , what do you think could the reason for that?
August 08, 2014 06:18PM
lines11
hey,
What are your delta segments set too?
August 09, 2014 02:51AM
To 200.
August 09, 2014 04:01PM
I´ve tested the segments per mm, parameter, but with no succsess. i played with acallaration and jerk, too, nothing better.
At the moment i have no idea what the reason could be sad smiley.
i made a triangel to all three towers, i go to tower a, b to c and to x0y0 always ca 0.2 nozzel lift. But from x0y0 to tower c it is fine.
i made one more video [youtu.be] .
At the moment i would nothting rather doing than print with a perfect adjusted cherry pi, because i love the desing.
i also made a test without the spring, same result.
thank you much
KtB
August 09, 2014 06:37PM
Are you sure the glass is actually flat a lot even mirrored is not.
Also are all 6 arms exactly the same length ?
Like the precision cutting of the mirror btw grinning smiley
Edited 1 time(s). Last edit at 08/09/2014 06:38PM by KtB.
August 09, 2014 07:23PM
Yes I'm sure all arms are exactly same length, all are between +-0.05mm.
I know the mirror is not the accurarest thing I made,but it's functional, and flat. The directions watch makes a turn on every direction change, the cuvre goes
Steep up and shellows during the move down to the same point of start.
Hope you understand me spinning smiley sticking its tongue out
KtB
August 10, 2014 10:17AM
Only other thing i can think of it play in the belts.
I have some belt tensioners on mine made from peg springs as i found it very hard to get the belts all tensioned the same.
August 10, 2014 04:49PM
KtB
It should be fairly easy to get consistent belt tension. Just loosen the stepper mounting screws and push the motors down before you re tighten them. You could also move the top vertex up a bit but you would then have to re level the bed. I've built a lot of Cherry Pi machines now and it's never been an issue. The trick is to get them as tight as you can before you alter the stepper height.
Andy
nka
August 10, 2014 05:02PM
Hum, maybe this could be a idea, the to idler could be spring loaded to always give a tension.
KtB
August 10, 2014 07:12PM
AndyCart
KtB
Andy
I just found it very hard to get the belts tight enough to begin with just using the steppers and the belt end mounting points and found using spring tensioners works well
August 11, 2014 05:24PM
nka
It may be easier to spring load one of the belt attachment points on the rod carrier. I'll have a look when I get a spare hour or two
August 12, 2014 10:47AM
Andy, can you give a link to where you found the 8mm ball bearings with the 4mm hole? I'm having no luck finding them.
