Re: Cherry Pi III Is Available August 12, 2014 10:53AM |
Re: Cherry Pi III Is Available August 12, 2014 11:18AM |
Re: Cherry Pi III Is Available August 12, 2014 10:07PM |
Re: Cherry Pi III Is Available August 13, 2014 08:51AM |
Re: Cherry Pi III Is Available August 13, 2014 11:03AM |
Re: Cherry Pi III Is Available August 13, 2014 11:16AM |
Re: Cherry Pi III Is Available August 13, 2014 05:05PM |
nka
Just a little improvement I would do on the Effector Clamp
Moving the nuts hole a little would help to reach the nuts and then tight without going into the wall of the other screw (in case of a too-long screw).
Re: Cherry Pi III Is Available August 13, 2014 07:30PM |
Re: Cherry Pi III Is Available August 13, 2014 08:00PM |
Re: Cherry Pi III Is Available August 15, 2014 05:13PM |
Re: Cherry Pi III Is Available August 15, 2014 05:44PM |
Re: Cherry Pi III Is Available August 15, 2014 06:41PM |
Re: Cherry Pi III Is Available August 15, 2014 09:58PM |
Re: Cherry Pi III Is Available August 16, 2014 01:27PM |
Re: Cherry Pi III Is Available August 16, 2014 01:50PM |
nka
Found a mirror to get me back on track, I'm calibrating right now. Hope people didnt think I was buying those to decorate, they are ugly... lol
Yesterday, I was looking at heatbed and I think the 220mm (180mm heated) heatbed used for the Orion could work very nicely (with some braket to hold it) : [seemecnc.com] . I might go this way if I dont go with the custom one.
I also got a question. I'm using the firmware for the Mini Kossel from Rich Cattell you provided me.
I was following this tutorial ( [www.youtube.com] ) to do a pre-calibration using M666.
I was ajusting the tower "X" at X-73.6 Y-42.5, I found that I touched the bed at 1.2mm, so I did "M666 X1.2", "G28" then "G0 X-73.6 Y-42.5" and used the Repetier-Host (also tried with the Pronterface) and I was touching the bed a 1.2 agains... I did this like 4 time, (I was at M666 X4.8) and I was still touching the bed at 1.2.
So I tried M500 and a reload... same thing.
It seems to be the same thing with the "M666 Hxxx". I was scraping the tape, so I removed some height and it was still scraping it... like it dosent use those? I Even tried "M666 H100" to see what would happen... and notthing. My max height is like 238.3 and I setted 240 into the firmware. Tried the same thing after a M502, M500 and reset of the printer.
What I was doing wrong? I'm lost.
I'm auto calibrating right now with the "G30 A", I'll tried to see if it does a better calibration than me!
Re: Cherry Pi III Is Available August 16, 2014 02:02PM |
Re: Cherry Pi III Is Available August 16, 2014 02:33PM |
Re: Cherry Pi III Is Available August 16, 2014 04:49PM |
Re: Cherry Pi III Is Available August 16, 2014 04:53PM |
Re: Cherry Pi III Is Available August 16, 2014 08:44PM |
Re: Cherry Pi III Is Available August 16, 2014 08:48PM |
Re: Cherry Pi III Is Available August 17, 2014 01:46PM |
maso
[attachment 36189 fanfit.jpg]
I can also confirm that the fan will work when it's that close to the magnet. Spins like a dream!
Re: Cherry Pi III Is Available August 17, 2014 05:15PM |
vreihen
maso
I am using 1/2 inch (12.7mm) spherical magnets, and just discovered that my E3Dv5 fan motor does *not* spin without a manual nudge with my finger to get it rotating. Even then, it only seems to be spinning at quarter of the speed it normally would.
Me thinks it's time to look at the non-magnetic setup again.....
Re: Cherry Pi III Is Available August 18, 2014 10:08AM |
Re: Cherry Pi III Is Available August 18, 2014 10:16AM |
nka
So I have about 20 hours of print now, I can say it's working fine. I managed to fix most of the problems I found.
I also did a 8 hours non-stop printing as a stress test to the printer. Everything when fine, except I notice those :
- The belt are slipping. No mather how hard I tight them, the belt+screw will turn and they will loose. I noticed that since at about the end of the print, I saw that there was some wierd move when changing direction. At the end of the print, I checked the belt and they were loose. At first, I was thinking it was just "normal", belt get extension... but then I notice that on the top, my "U" was now pretty small... almost out.
-- I'll try to add something to "squeeze" them more. But I'm also thinking of another design, so they dont slip and also a belt tensioner would be nice. This is pretty nice ( [www.thingiverse.com] ), but I'm not sure it would be working since we need to move it on the other side, might not be as solid... dont know.
- Dont thight the spring too much, dosent need that much force and will eat the plastic if you do (not that bad, but it does).
- Try to align the miniwheel so they fit prefectly into the extrusion slow. I had one not straight and the will got eated by the extrusion (But still functionnal).
Re: Cherry Pi III Is Available August 18, 2014 10:41AM |
Re: Cherry Pi III Is Available August 18, 2014 08:18PM |
Re: Cherry Pi III Is Available August 19, 2014 02:33PM |
nka
They are tooth to tooth, but I think they are not tight enough into the "slot". The lower one seems be okay, but not the upper one. If I pull very hard, I see them slip (even if the bolt is tight). I think that adding something to squeeze them more will help prevent the slip. As for the best tensioner. It's just becose it's easier than unscrewing the stepper! I'll also use a spring like this ( [cdn1.bigcommerce.com] ) to keep the tension and still allow some play.
The spring is tight, but not "too tight". Before, I had to push the effector for like 5cm to get the rods in. Now I push only about 2cm, it's tight, but not too much. I over did it the first time I think. I'll add some silicone grease! I was thinking of it, but wasnt sure about it... thanks!
Re: Cherry Pi III Is Available August 19, 2014 02:41PM |
Re: Cherry Pi III Is Available August 20, 2014 01:59AM |
