Re: Cherry Pi III Is Available August 20, 2014 08:03AM |
Re: Cherry Pi III Is Available August 20, 2014 08:34AM |
Re: Cherry Pi III Is Available August 20, 2014 08:36AM |
Re: Cherry Pi III Is Available August 20, 2014 09:56AM |
Re: Cherry Pi III Is Available August 20, 2014 12:10PM |
Re: Cherry Pi III Is Available August 27, 2014 08:14PM |
Re: Cherry Pi III Is Available August 28, 2014 06:29PM |
Re: Cherry Pi III Is Available August 28, 2014 07:37PM |
Re: Cherry Pi III Is Available August 29, 2014 10:11AM |
Re: Cherry Pi III Is Available August 29, 2014 01:24PM |
Re: Cherry Pi III Is Available September 04, 2014 06:38PM |
Re: Cherry Pi III Is Available September 05, 2014 02:46AM |
Re: Cherry Pi III Is Available September 06, 2014 08:35AM |
Re: Cherry Pi III Is Available September 06, 2014 10:08AM |
pugzor
Was just wondering, do you guys think the aluminium tubing is strong enough? I noticed a few people are using carbon fibre rods... Would it be worth filling the aluminium tubing with resin or something just to give it some added rigidity, or is the system fairly sensitive to the weight of the rods? The rods I've got are fairly light duty so I'm a tiny bit worried I guess... Wall thickness is less than 0.4mm.
Re: Cherry Pi III Is Available September 06, 2014 06:33PM |
Re: Cherry Pi III Is Available September 06, 2014 10:08PM |
Re: Cherry Pi III Is Available September 07, 2014 03:35AM |
Re: Cherry Pi III Is Available September 07, 2014 08:42AM |
Re: Cherry Pi III Is Available September 10, 2014 12:23AM |
Re: Cherry Pi III Is Available September 10, 2014 10:37PM |
Re: Cherry Pi III Is Available September 11, 2014 01:05AM |
pugzor
Out of interest, is there anything really stopping us adding extra height to the build volume? I'm guessing the main limitations would be the amount of v slot and -gt2 belt you've got to play with, along with wiring length, but is there anything else? Was just playing with the idea of trying to make the print envelope 300mm high instead of 250mm.... Is that achievable?
Re: Cherry Pi III Is Available September 13, 2014 09:03AM |
Re: Cherry Pi III Is Available September 13, 2014 09:39AM |
Re: Cherry Pi III Is Available September 14, 2014 08:30PM |
Re: Cherry Pi III Is Available September 14, 2014 08:54PM |
Re: Cherry Pi III Is Available September 15, 2014 02:53AM |
pugzor
Nice! Yeah, that's what I was thinking too vreihen. [www.jaycar.com.au] Think I might build it with a hard-wired mains cord to begin with, but once I can print out some parts, I'll make a nice little add-on box to mount an IEC connector onto.
Andy, do you think there'd be enough belt in the quoted "4 metres" to add that extra 50mm of height? I got my V Slot today and I just want to make sure before I cut, haha. I'm not too worried if I don't, I'd prefer to build with a lower build height than have to acquire more GT2 belt at this stage!
Re: Cherry Pi III Is Available September 15, 2014 03:03AM |
Re: Cherry Pi III Is Available September 15, 2014 07:03AM |
pugzor
I think it's going to be REAL close on whether I can do this or not with my existing GT2 belt... I think it mostly depends on whether or not I have exactly 4 metres.
Re: Cherry Pi III Is Available September 15, 2014 08:22AM |
pugzor
A quick question and it's not terribly related to the Cherry Pi, but one of my pulleys from OpenBuilds is slightly damaged. 2 of the teeth have chunks missing on them (I'd say it reduces the height of the teeth by 1mm but for only 1/3 to 1/2 of each tooth). Should this still be fine to use?
Re: Cherry Pi III Is Available September 16, 2014 12:37AM |
