Re: Cherry Pi III Is Available October 11, 2014 11:13AM |
Re: Cherry Pi III Is Available October 11, 2014 07:30PM |
Re: Cherry Pi III Is Available October 12, 2014 05:33AM |
nka
very nice! it's a good printer!
Andy (or someone else), I'll have to reprint the wheels carriage to match my spring loaded carriage. I have MISUMI extrusion, what version should I use?
Re: Cherry Pi III Is Available October 12, 2014 05:45AM |
nka
Re: Cherry Pi III Is Available October 12, 2014 08:36PM |
Re: Cherry Pi III Is Available October 13, 2014 03:23AM |
Re: Cherry Pi III Is Available October 13, 2014 06:06AM |
AndyCart
Could you add a 45 degree chamfer on the slots with a square file?
Re: Cherry Pi III Is Available October 19, 2014 11:14PM |
Re: Cherry Pi III Is Available October 20, 2014 02:30AM |
ekaggrat
@andy
what is the size of springs you are using? I tried this on my 3dr ( made new carriages and micro platform ) .The problem i face is that if i hit the rods by mistake while adjusting something on the printer the rods pop out of the socket and then everything goes flying here and there. Is this normal or are my springs not strong enough?
Re: Cherry Pi III Is Available October 20, 2014 03:43AM |
Re: Cherry Pi III Is Available October 20, 2014 11:16AM |
Re: Cherry Pi III Is Available October 20, 2014 12:44PM |
Re: Cherry Pi III Is Available October 20, 2014 01:24PM |
Re: Cherry Pi III Is Available October 25, 2014 08:20PM |
Re: Cherry Pi III Is Available October 26, 2014 02:20AM |
pugzor
Mine is nearly together! Just need to install the extrusion module and wire the associated connections. Unfortunately my clumsiness cost me one of my microswitches so that won't happen for a couple of days. Everything else is looking good with only a few hiccups. I still need to find a build plate (I tried cutting glass for the first time... fun but I still need to find a build plate haha).
How did you guys determine how much tension was appropriate for the drive belts? I think mine have a nice amount but it's hard to describe... They don't have much slack at all, but they're not so tight as that they might cause the tower caps to creep down over time.
I think the only way I'm really deviating from the original design is that I'm not going to pass the wiring for the extruder/feeder through the extrusion; I'm just going to run it under. Is there any issue with that or was there a specific reason (other than aesthetics) that they pass through the extrusion in the original design?
While I'm here, is there anything I should keep in mind for wiring? From the perspective of looking toward the LCD screen, I've assigned the tower on the left as X, the tower on the right as Y, and the tower at the back (with the extruder stepper) as Z. I think my main concerns are a) have I assigned the right positions for the microswitches (are they connected to the min or max pins?), and b) if I've wired my steppers correctly (everything I've seen seems to indicate that the wires are in the same order leaving the steppers as they are entering the board... for example, looking at the stepper motor connector on the motor, it might go green, red, grey, yellow, and on the RAMPS board they enter the receptacle in that order too).
EDIT: I've tried creating a new set of arms too and these seem much more equal length, so I'll give them a shot. Carbon still seemed to be the way to go for economy reasons.
Re: Cherry Pi III Is Available October 26, 2014 08:37AM |
Is there anything else a bit tricky that I will need to do for the config?
Re: Cherry Pi III Is Available October 26, 2014 09:50AM |
Re: Cherry Pi III Is Available October 26, 2014 06:42PM |
Re: Cherry Pi III Is Available October 26, 2014 10:23PM |
Re: Cherry Pi III Is Available November 01, 2014 12:57AM |
Re: Cherry Pi III Is Available November 01, 2014 01:49AM |
Re: Cherry Pi III Is Available November 01, 2014 07:24AM |
I can flash the firmware fine but giving it commands isn't doing anything. It just says "x Command Waiting" where x can be any number of commands I try to give it. |
Re: Cherry Pi III Is Available November 01, 2014 10:00AM |
Re: Cherry Pi III Is Available November 01, 2014 12:44PM |
Re: Cherry Pi III Is Available November 01, 2014 05:54PM |
Re: Cherry Pi III Is Available November 02, 2014 01:07AM |
Re: Cherry Pi III Is Available November 02, 2014 01:11AM |
Re: Cherry Pi III Is Available November 02, 2014 03:10AM |
Re: Cherry Pi III Is Available November 02, 2014 03:35AM |
