Re: Cherry Pi III Is Available November 26, 2014 01:50AM |
Re: Cherry Pi III Is Available November 26, 2014 09:38PM |
Re: Cherry Pi III Is Available November 26, 2014 09:45PM |
Re: Cherry Pi III Is Available November 28, 2014 05:55AM |
Re: Cherry Pi III Is Available November 28, 2014 07:15PM |
Re: Cherry Pi III Is Available November 28, 2014 08:09PM |
Re: Cherry Pi III Is Available November 29, 2014 05:08AM |
Re: Cherry Pi III Is Available November 29, 2014 07:50AM |
Re: Cherry Pi III Is Available November 29, 2014 11:17AM |
Re: Cherry Pi III Is Available November 29, 2014 12:12PM |
Re: Cherry Pi III Is Available November 29, 2014 12:30PM |
Re: Cherry Pi III Is Available November 29, 2014 05:51PM |
Re: Cherry Pi III Is Available November 29, 2014 09:16PM |
Something I'll do when I get a chance, but it shouldn't be affecting the machine's ability at this point in time.Quote
AndyCart
Yes the hot ends I supply are 0.4mm. The bearings were designed into the extruder for a reason! If I were you I would swap the washers. It's simple and cheap and is another thing you don't need to worry about
Yeah, I think it's all fine with that. It was difficult to push filament through by finger so it might just need more heat. Mind you, in Slic3r (within Repetier) my settings were 3mm filament and 0.5mm nozzle diameter, so that might have had something to do with why things weren't working out so great.Quote
vreihen
With the extruder open and hotend at temperature, you should be able to push the filament through the nozzle with just your fingers and moderate force. Simplest test that you can do to figure out if the filament pusher is at fault or if the problem is further upstream at the hotend (or excessive friction in the Bowden tube). Are you sure that the filament is going all the way into the hotend and not getting hung up at the top near the bowden tube connector?????
Re: Cherry Pi III Is Available November 30, 2014 02:19AM |
Re: Cherry Pi III Is Available December 01, 2014 02:17PM |
Re: Cherry Pi III Is Available December 02, 2014 03:11AM |
Re: Cherry Pi III Is Available December 02, 2014 08:02AM |
Re: Cherry Pi III Is Available December 02, 2014 08:28AM |
crazyhorseX
thanks ...
I am gonna build one
the Git or the thingiverse page for the latest files of this machine ?
chX
Re: Cherry Pi III Is Available December 02, 2014 08:33AM |
crazyhorseX
Andy,
been studying your machines on thingiverse ...
excellent work ... and thanks for sharing ..
one doubt i wanted to confirm before i get cracking...
Cherry Pie IIIs - driven by Spectra fishing lines
Cherry Pie III - driven by GT2 belts & pulleys ...
are they any other differences like the build volume, etc etc ??
thanks a lot in advance
chX
Re: Cherry Pi III Is Available December 06, 2014 05:16PM |
Re: Cherry Pi III Is Available December 06, 2014 05:24PM |
Re: Cherry Pi III Is Available December 07, 2014 02:26PM |
Re: Cherry Pi III Is Available December 09, 2014 06:36AM |
Re: Cherry Pi III Is Available December 09, 2014 09:29AM |
pugzor
Out in the sun. Yeah... ends up hot cars and thermoplastics don't mix too well. Who would have thought?
Re: Cherry Pi III Is Available January 01, 2015 11:02PM |
Re: Cherry Pi III Is Available January 02, 2015 03:58AM |
Re: Cherry Pi III Is Available January 02, 2015 08:27AM |
Re: Cherry Pi III Is Available January 03, 2015 07:17AM |
Re: Cherry Pi III Is Available January 03, 2015 07:59AM |
Re: Cherry Pi III Is Available January 03, 2015 08:14AM |
