Re: Cherry Pi III Is Available January 03, 2015 08:26AM |
AndyCart
Hi Les
The KJN profile that ships isn't the same as the diagram on the website! The image below shows the KJN profile on the right and the Open Builds V slot on the left :-
[attachment 46290 20140920_092711.jpg] [attachment 46291 20150103_124846.jpg]
If you use a different V wheel than the OpenBuilds Mini them the spacing on the tower carriages may be incorrect!
Regards
Andy
Edit: Added a better image of the KJN profile. The step is actually there but the reality is that it is much less pronounced than the CAD drawing would lead you to believe.
AndyCart
Hi Guys
I just printed this as a test print for my new effector and Chinese E3D V5 hot end clone. It came out great. It's Adalina the singing dragon from Thingiverse at 50% scale
[attachment 46292 20150103_125630.jpg]
Printed at 0.3mm layer height with a 0.4mm nozzle, 2 perimeters, 10% in fill. 80mm/s print speed.
Andy
Re: Cherry Pi III Is Available January 03, 2015 09:20AM |
Re: Cherry Pi III Is Available January 03, 2015 10:03AM |
Re: Cherry Pi III Is Available January 03, 2015 10:05AM |
Re: Cherry Pi III Is Available January 03, 2015 04:11PM |
Re: Cherry Pi III Is Available January 04, 2015 05:58AM |
Re: Cherry Pi III Is Available January 04, 2015 08:41AM |
AndyCart
Hi Guys
I've uploaded a video of Cherry Pi IIIS Metal printing at 120mm/s [www.youtube.com]
I've also put together a calibration guide (attached) hopefully you will find it useful for setting up your machines.
Andy
Re: Cherry Pi III Is Available January 04, 2015 09:16AM |
Re: Cherry Pi III Is Available January 04, 2015 10:05AM |
AndyCart
Hi Guys
Andy
Re: Cherry Pi III Is Available January 04, 2015 02:52PM |
nka
Andy, would you print directly on the aluminium?
I got a cheap mirror right now I need to change cause it's not flat, I would get this even without using the heated but wish I could use glue like I do now.
Re: Cherry Pi III Is Available January 04, 2015 08:56PM |
Re: Cherry Pi III Is Available January 05, 2015 05:06AM |
Zzyzxx71
Anyone have any recommendations for sourcing 8mm threaded balls and 4mm id/6mm od aluminum tubing in the states?
I can't seem to find them at my typical sources - I'm also willing to buy direct if someone sells them as a kit.
It's the only hardware I can't find from my normal sources.
Re: Cherry Pi III Is Available January 05, 2015 11:19PM |
Re: Cherry Pi III Is Available January 23, 2015 05:04AM |
Re: Cherry Pi III Is Available January 23, 2015 05:41AM |
Pointy
I finally got all the required parts this week and begun the assembly of my CPIII. Here's where we are at....
[attachment 47703 delta1.jpg]
I just have the electronics to finish off, which includes making some mounting brackets for the Smoothieboard. Here are some notes on the build so far
- The Motedis aluminium profile looks exactly the same as the parts supplied with my Ormerod and the carriages appear to run nicely.
- I am using a genuine E3D V6 hotend and tweaked Andy's mount and effector design to suit.
- I am using 50lb stainless trace wire with crimps and a couple of small split rings to attach the springs.
- I have 40mm adjustable feet screwed in to the bottom of each tower. (this made it a little more awkward to run the endstop wires)
I will post some better pics and files for my tweaks/additions once everything is up and running.
Regards,
Les
Re: Cherry Pi III Is Available January 23, 2015 06:07AM |
dougal1957
Is that slot cap strips I see in the extrusions? think I should have ordered some of them and some feet as well?
Re: Cherry Pi III Is Available January 23, 2015 09:27AM |
Re: Cherry Pi III Is Available January 23, 2015 10:54AM |
Re: Cherry Pi III Is Available January 23, 2015 10:58AM |
Re: Cherry Pi III Is Available January 23, 2015 02:05PM |
AndyCart
I don't fit feet to my designs as it does make wiring the endstops more difficult. I just stick two 20mm diameter felt pads to the base of each stepper mount. The mount has a 10mm 'foot' designed in to give clearance for either the on board PSU for non heated bed builds and/or the RAMPS board.
Re: Cherry Pi III Is Available January 24, 2015 09:26AM |
Re: Cherry Pi III Is Available January 24, 2015 01:32PM |
Pointy
Well that was a bit of a failure.
First off the brackets are no good, there isn't enough room to get the USB cable in, so I am currently printing mark 2.
Next up, all of my end switches were broken, so I had to replace them. I was trying to keep things neat with heatshrink, but the heatshrink obviously didn't want to bend when I put the caps on and damaged the switches instead. (Really glad I put connectors at the top end so I didn't have to rewire the whole lot)
After testing the new switches, I managed a quick hotend test and it all seemed to work as expected. While I wait for the new mounts to print I shall start wiring up the motors.
Regards,
Les
Re: Cherry Pi III Is Available January 24, 2015 03:45PM |
Re: Cherry Pi III Is Available January 25, 2015 04:45PM |
alpha_trim -4.350 # software trim for alpha stepper endstop (in mm) beta_trim -5.800 # software trim for beta stepper endstop (in mm) gamma_trim -6.250 # software trim for gamma stepper endstop (in mm)
Re: Cherry Pi III Is Available January 26, 2015 07:04AM |
Re: Cherry Pi III Is Available January 26, 2015 09:36AM |
Re: Cherry Pi III Is Available January 31, 2015 03:45PM |
Re: Cherry Pi III Is Available February 01, 2015 08:25AM |
Re: Cherry Pi III Is Available February 01, 2015 08:58AM |
nka
If print is bad, its not releated to the slicer, but more to the calibration. (Hard to tell without the part).
If you think the calibration is good, then try to lower the speed to somewhere 40-50 mm/s with perimeter around 30 and travel at 60-70. If you don't get a nice print with that, there's a problems on the hardware and/or calibration.
Re: Cherry Pi III Is Available February 02, 2015 01:59AM |
