Re: Cherry Pi III Is Available February 04, 2015 10:12AM |
Re: Cherry Pi III Is Available February 04, 2015 11:20AM |
mrorange26
So will have to run another pair of cables for the all metal hot end as currently my fan goes on and off
Re: Cherry Pi III Is Available February 04, 2015 12:11PM |
Re: Cherry Pi III Is Available February 04, 2015 12:20PM |
Re: Cherry Pi III Is Available February 04, 2015 12:22PM |
Re: Cherry Pi III Is Available February 04, 2015 01:38PM |
Re: Cherry Pi III Is Available February 04, 2015 02:41PM |
Re: Cherry Pi III Is Available February 04, 2015 04:43PM |
Re: Cherry Pi III Is Available February 04, 2015 05:05PM |
Re: Cherry Pi III Is Available February 04, 2015 05:09PM |
Re: Cherry Pi III Is Available February 04, 2015 05:14PM |
Re: Cherry Pi III Is Available February 04, 2015 05:49PM |
Re: Cherry Pi III Is Available February 04, 2015 08:43PM |
Matt,Wheatley
ABS Help
Has anybody managed to print ABS with their cherry pi. I want to print the new all metal hot end mount and appear to be having issues with layers being a little bitty. I was wondering if people had used ABS and if so what there print settings might be.
I have tried temp at 240, bed 110 with the fan off but the layers don't appear very even.
Re: Cherry Pi III Is Available February 05, 2015 03:57AM |
Matt,Wheatley
Well, the print looks much better at 270, I also put the print speed up. However as soon as the head got near the print bed the mirror cracked, might be time for a aluminium build plate :/
[drive.google.com]
Anybody know where to get 300mm diameter aluminium heat beds
Re: Cherry Pi III Is Available February 05, 2015 04:40AM |
Re: Cherry Pi III Is Available February 05, 2015 04:58AM |
Re: Cherry Pi III Is Available February 05, 2015 05:24AM |
Re: Cherry Pi III Is Available February 05, 2015 05:30AM |
AndyCart
You may be better looking at 230V silicone mats for the larger heated beds if you want to get to ABS bed temps. I switch mine, on my core XY machines, with a small relay and set the firmware to bang bang mode. The bed stays within a degree of target providing you have an aluminium sheet between the mat and the glass to act as a heat mass. The last one I bought was 400mm x 400mm 1000W 220V and cost about fifty quid shipped.
Re: Cherry Pi III Is Available February 08, 2015 04:47AM |
Re: Cherry Pi III Is Available February 08, 2015 04:53AM |
Re: Cherry Pi III Is Available February 08, 2015 05:21AM |
AndyCart
I may just pinch your rod carrier when it's out of beta!!!
Re: Cherry Pi III Is Available February 08, 2015 08:05AM |
Re: Cherry Pi III Is Available February 08, 2015 08:31AM |
nka
very nice les! I may switch to the smootie someday!
Re: Cherry Pi III Is Available February 08, 2015 08:43AM |
Pointy
I don't see any reason why they won't work, but you never know. You will sacrifice 10mm of build height though, as I had to make them taller to incorporate the adjuster.
Re: Cherry Pi III Is Available February 08, 2015 09:31AM |
Re: Cherry Pi III Is Available February 08, 2015 01:48PM |
Re: Cherry Pi III Is Available February 08, 2015 04:35PM |
nka
Re: Cherry Pi III Is Available February 09, 2015 03:33AM |
vreihen
Pointy
Would moving the ball sockets and spring retainer to the top of the carriage plate gain some of that 10mm back?????
Re: Cherry Pi III Is Available February 09, 2015 03:40AM |
AndyCart
mrorange26
Hi Andy what all metal hotend do you use and do you have a modified holder for it .
I use this hotend [www.aliexpress.com]
and this heated bed [www.aliexpress.com]
I'm very pleased with both of them
Re: Cherry Pi III Is Available February 09, 2015 11:13AM |
vreihen
Pointy
