Re: Cherry Pi III Is Available March 04, 2015 06:00PM |
Re: Cherry Pi III Is Available March 04, 2015 06:02PM |
Re: Cherry Pi III Is Available March 04, 2015 06:09PM |
Re: Cherry Pi III Is Available March 04, 2015 06:18PM |
Re: Cherry Pi III Is Available March 05, 2015 07:10AM |
Re: Cherry Pi III Is Available March 05, 2015 09:44AM |
Re: Cherry Pi III Is Available March 05, 2015 10:32AM |
gowen
Day 9
Good session today. It's really starting to look like a delta 3d printer. The re-soldered micro switches are attached with the "magic sauce" and their cables run. Before bonding, I checked the micro-switches were the correct way round to be activated by the carriages. I had five minutes to spare so fixed the RAMPS board as well.
[attachment 50478 IMG_20150305_134406.jpg] [attachment 50479 IMG_20150305_135552.jpg]
[attachment 50480 IMG_20150305_135634.jpg] [attachment 50481 IMG_20150305_135646.jpg]
One quick question, what are the t-nuts for on the outside of bars C & D?
[attachment 50482 T-Nut_Placement.jpg]
There will be no building tomorrow as I have an opticians appointment, but I'll take the effector arms home to get the balls attached. The M4 grub screws look to work well for this.
Re: Cherry Pi III Is Available March 05, 2015 10:38AM |
Re: Cherry Pi III Is Available March 05, 2015 10:55AM |
I'm near Taunton in Somerset, UKQuote
dougal1957
Where are you by the way
Re: Cherry Pi III Is Available March 05, 2015 11:15AM |
gowen
I think I found what goes on the mystery screws. I'd forgotten about this power connector in my small parts box. I'm wondering why the counter bores are on the socket side though. I assume I need to take the socket out and put it back the other way after soldering on the connections.
[attachment 50484 IMG_20150305_152955.jpg] [attachment 50485 IMG_20150305_153037.jpg]
dougal1957
Re: Cherry Pi III Is Available March 05, 2015 12:43PM |
Re: Cherry Pi III Is Available March 05, 2015 02:01PM |
pugzor
Hey Andy, is it just me or are the wrong top brackets loaded to the Thingiverse page for the CPIII? I've just tried fitting mine and the microswitches seem set too far away from the carriages, so much so that the microswitches don't even touch the carriages at max height.
Re: Cherry Pi III Is Available March 05, 2015 02:04PM |
Re: Cherry Pi III Is Available March 05, 2015 06:38PM |
AndyCart
pugzor
They may be. I did change them a while ago. Did you download from the newer CP IIIS page? You can still use them. Drill a 2.5mm hole on the rear of the carriage where the switch lever would touch if it was longer. Then screw an M3 SHCS into the hole. The head should engage the switch lever. I'll upload the newer design to TV when I get a chance. The problem stems from my first batch of switches having longer levers!
Re: Cherry Pi III Is Available March 06, 2015 05:36AM |
Re: Cherry Pi III Is Available March 06, 2015 08:33AM |
AndyCart
Hey Guys
Pugzor dropped me a PM to ask about the possibility of an effector design for Cherry Pi that would allow the use of the new Cyclops hot end from E3D. I've tweaked the effector design this morning and attached the .stl. Please feel free to use it for a dual extrusion Cherry Pi. I look forward to the ingenious ways you will come up with for attaching the second extruder. I've been using a Cyclops for a few weeks on a new core XY design I've been working on. It's a terrific piece of kit. It's amazingly small and light and, as you would expect from E3D, the engineering is superb. For anyone who hasn't seem it take a look at the E3D website.
[e3d-online.com]
[attachment 50543 EffectorForE3DCyclopsHotEndV2.stl]
Regards
Andy
Re: Cherry Pi III Is Available March 07, 2015 05:11AM |
Re: Cherry Pi III Is Available March 07, 2015 06:21AM |
Re: Cherry Pi III Is Available March 07, 2015 06:26AM |
Re: Cherry Pi III Is Available March 07, 2015 11:36AM |
Mylation
I'll start by prefacing that I'm an absolute newbie at this whole thing. I really want to build a delta and have been looking at a few kits now but some of the cheaper kits out there scare me a bit. A kit has the advantage that I don't have to find all the parts. But I'm not to keen on sourcing everything. Can someone give a bit of advice on what someone in NA might pay on average for the BOM (total)?
Re: Cherry Pi III Is Available March 07, 2015 03:59PM |
Re: Cherry Pi III Is Available March 07, 2015 05:15PM |
Re: Cherry Pi III Is Available March 08, 2015 03:41AM |
Re: Cherry Pi III Is Available March 08, 2015 07:26AM |
pugzor
(Professor Farnsworth voice) Good news everyone!
It really looks like it wasn't an issue with my bowden. Further more it wasn't my nozzle being clogged either. It was in the hot end though! The sleeve between the plumbing fitting and the nozzle was clogged with filament (some had melted and completely filled it). The filament had even kinked just on the other side of the plumbing fitting.
Anyway, I cleared it out. Will calibrate it later and see how it goes.
Is it possible it's trying to feed in filament too fast?
Re: Cherry Pi III Is Available March 09, 2015 10:35AM |
Re: Cherry Pi III Is Available March 09, 2015 12:14PM |
Re: Cherry Pi III Is Available March 10, 2015 11:15AM |
Re: Cherry Pi III Is Available March 10, 2015 02:06PM |
Re: Cherry Pi III Is Available March 10, 2015 02:10PM |
Re: Cherry Pi III Is Available March 10, 2015 05:41PM |
