Re: Cherry Pi III Is Available March 18, 2015 03:15AM |
mrorange26
Stopped print halfway through its abit better but still a few lines how do I adjust stepper motors.
Re: Cherry Pi III Is Available March 18, 2015 05:05AM |
Re: Cherry Pi III Is Available March 18, 2015 06:55AM |
Re: Cherry Pi III Is Available March 18, 2015 07:07AM |
AndyCart
Hi Doug. It's just a normal 12V 40A relay 25mm cube with spade terminals. I soldered a reverse biased diode across the coil terminals to stop back emf and connected to the D8 heated bed connection on RAMPS. You need to disable PID for the heat bed and just use bang bang. It works great
Re: Cherry Pi III Is Available March 18, 2015 07:11AM |
Re: Cherry Pi III Is Available March 18, 2015 07:47AM |
dougal1957
Thanks Andy so just a automotive relay then. I Have an SSR that I got for it and it appears to be faulty ie it aint switching.
Re: Cherry Pi III Is Available March 18, 2015 08:15AM |
vreihen
dougal1957
Make sure that you are using bang-bang and not PID, even with an SSR. They do not like switching at frequencies higher than 20 hertz from what I've read, and the result is that the SSR doesn't switch. (Does RepRapFirmware support bang-bang?) I know that Smoothieware has a setting for maximum hertz to use in PID with an SSR, which is how mine (24V DC) is set up and working.
Another thought is to verify that your SSR is an AC/DC and not DC/DC part number. Apparently the type of power being switched is important when buying an SSR.....
Re: Cherry Pi III Is Available March 18, 2015 09:58AM |
dougal1957
Yes definitely the correct type even tested the Duet with a DCDC one I have and that lights up when on but the AC one I have doesn't so pretty much proves it I think and DC42's Firmware by default is BangBang for the Hotbed.
Re: Cherry Pi III Is Available March 18, 2015 11:45AM |
Re: Cherry Pi III Is Available March 18, 2015 11:57AM |
dc42
dougal1957
Yes, unless you change it in config.g.
I presume you connected the input terminals of the SSR the right way round?.
dc42
I purchased an SSR-10DA to control the mains-voltage heated bed of my enlarged mini-Kossel. These are widely available in the UK. They have an LED that lights up when they are energised, and a protective plastic cover to help keep things from touching the terminals. Personally, I wouldn't use a mechanical relay for this, since SSRs are ideal for controlling heaters and don't create so much interference as they turn on and off.
Re: Cherry Pi III Is Available March 18, 2015 01:24PM |
Re: Cherry Pi III Is Available March 18, 2015 01:26PM |
Re: Cherry Pi III Is Available March 18, 2015 02:27PM |
dougal1957
Yes Did have it right way round first thing I thought of tried reversing the input connections and led didn't light either way tested with a DC DC one that I have and that did light up in sympathy with the Heatbed O/P Led on the Duet.
AndyCart
I've never had much luck with solid state relays. I wasn't aware of the 20Hz limit though. Mine were rated at 50A. I had one AC one and one DC one. I would be surprised if either could sink more than 10A without overheating though.
Re: Cherry Pi III Is Available March 18, 2015 03:02PM |
Re: Cherry Pi III Is Available March 18, 2015 03:28PM |
dc42
dougal1957
Unless the SSR has input reverse polarity protection, applying more than about 5V to the input terminals may might damage it, because both the visible and IR LEDs are likely to break down. I suggest connecting the SSR input to the EXT_FET terminals on the Duet instead of the heated bed output terminals, to avoid this risk.
Re: Cherry Pi III Is Available March 18, 2015 04:17PM |
Re: Cherry Pi III Is Available March 18, 2015 05:02PM |
Re: Cherry Pi III Is Available March 18, 2015 05:22PM |
Re: Cherry Pi III Is Available March 18, 2015 06:59PM |
David J
I'm making really good progress with printing the plastic parts and collecting the bits & pieces, and hope to start assembly very soon. However, I still have three quick questions:
What size and type of screws should I use to fasten the rod carrier to the mini_v_wheel carriage? M3 screws into the undersized holes, or self-tapping screws?
What sort of screws should I use to fasten the covers to the top brackets?
How far should the extrusions extend above the top brackets?
All answers gratefully accepted!
Cheers,
David
Re: Cherry Pi III Is Available March 19, 2015 05:05PM |
Re: Cherry Pi III Is Available March 19, 2015 05:55PM |
Re: Cherry Pi III Is Available March 19, 2015 06:03PM |
Re: Cherry Pi III Is Available March 19, 2015 06:27PM |
Re: Cherry Pi III Is Available March 20, 2015 11:18AM |
Re: Cherry Pi III Is Available March 20, 2015 11:24AM |
Zzyzxx71
Is there a version of Andy's effector for metal hot ends for struts with 10mm ball bearings?
I printed out the version posted on page 14, but the sockets for the ball bearings in the effector seem unusually small, almost as if they're for 8mm ball bearings.
Additionally where can I find this calibration guide? I've seen multiple people reference it, but haven't found a link anywhere.
Thanks in advance.
Re: Cherry Pi III Is Available March 20, 2015 11:44AM |
Re: Cherry Pi III Is Available March 20, 2015 12:42PM |
Zzyzxx71
Re: Cherry Pi III Is Available March 20, 2015 12:47PM |
Re: Cherry Pi III Is Available March 20, 2015 01:00PM |
Zzyzxx71
I took Andy's updated 8mm all metal hot end effector and Maso's 10mm ball bearing effector and merged them
Re: Cherry Pi III Is Available March 20, 2015 02:38PM |
