Re: Cherry Pi III Is Available March 20, 2015 03:06PM |
Re: Cherry Pi III Is Available March 20, 2015 03:15PM |
Re: Cherry Pi III Is Available March 20, 2015 05:33PM |
Re: Cherry Pi III Is Available March 20, 2015 05:36PM |
Re: Cherry Pi III Is Available March 20, 2015 05:43PM |
Re: Cherry Pi III Is Available March 20, 2015 05:44PM |
Re: Cherry Pi III Is Available March 20, 2015 07:45PM |
Re: Cherry Pi III Is Available March 20, 2015 08:43PM |
Re: Cherry Pi III Is Available March 21, 2015 02:55AM |
David J
Any chance of getting hold of the source file so that I can change the spacing? Assuming that it wasn't created in anything too obscure!
If I can change it then I'll post the new file here, for other builders.
Re: Cherry Pi III Is Available March 21, 2015 03:19AM |
gowen
I attempted calibration today, but got stumped almost straight away.
I worked out that I needed a baud rate of 115200 in Repetier-Host and I set a nominal circular build area of 200mm dia by 250mm high. Then to check my connection I used the manual controls to move the effector. When I tried to shift it horizontally, the Z carriage shot downwards, the Z effector strut went past horizontal and before I could pull the plug the struts started pinging off, much to the amusement of my colleagues.
Could someone tell me the Cherry Pi settings I need for Repetier host and possibly a short guide on running auto-calibration?
Re: Cherry Pi III Is Available March 21, 2015 09:04AM |
Re: Cherry Pi III Is Available March 21, 2015 10:39AM |
mrorange26
Is anybody any good at designing a fan duct to blow all round heat to cool plastic,I have had a mess around with tinkercad and im struggling with it.I want it abit like this,Would be much appreciated if someone could design it.
[www.thingiverse.com]
Re: Cherry Pi III Is Available March 21, 2015 10:47AM |
Re: Cherry Pi III Is Available March 21, 2015 11:02AM |
Re: Cherry Pi III Is Available March 21, 2015 04:11PM |
AndyCart
David J
Hi David
PM me with your email address and I'll send you the Sketchup file.
Andy
Re: Cherry Pi III Is Available March 21, 2015 05:25PM |
Re: Cherry Pi III Is Available March 21, 2015 06:41PM |
Re: Cherry Pi III Is Available March 22, 2015 04:51AM |
Re: Cherry Pi III Is Available March 23, 2015 05:59AM |
Re: Cherry Pi III Is Available March 23, 2015 10:27AM |
AndyCart
Hi Gary
The command to run auto calibration is G30 A but you need a connection to Z Min on RAMPS that changes state when the nozzle touches the bed. I have made up a long lead with croc clips on one end and the RAMPS end stop connector on the other. This fits temporarily whilst the machine is calibrating. It relies on you having a clean metal bed and a clean nozzle. Clip one lead to the hot end and one to the bed. Check it all out first with M119 and careful manipulation of the nozzle down to the bed.
Re: Cherry Pi III Is Available March 23, 2015 11:45AM |
Re: Cherry Pi III Is Available March 23, 2015 11:54AM |
Re: Cherry Pi III Is Available March 23, 2015 12:09PM |
Re: Cherry Pi III Is Available March 23, 2015 12:40PM |
Re: Cherry Pi III Is Available March 23, 2015 02:32PM |
Re: Cherry Pi III Is Available March 23, 2015 02:34PM |
Re: Cherry Pi III Is Available March 23, 2015 02:53PM |
David J
Does that work?! It only says that it's good for 3A.
and yes the delta rod tube is cut to 225mm|
Re: Cherry Pi III Is Available March 23, 2015 03:06PM |
AndyCart
David J
Works for meand yes the delta rod tube is cut to 225mm
Re: Cherry Pi III Is Available March 23, 2015 03:19PM |
Re: Cherry Pi III Is Available March 23, 2015 03:24PM |
