Re: Cherry Pi III Is Available March 23, 2015 04:53PM |
AndyCart
Auto calibrations can sometimes take up to 90 iterations!
Re: Cherry Pi III Is Available March 23, 2015 05:56PM |
Re: Cherry Pi III Is Available March 24, 2015 05:02AM |
Re: Cherry Pi III Is Available March 24, 2015 05:18AM |
David J
I've decided to experiment with the power input - I'm planning to use a 203W Xbox PSU to power the printer, so I've decided to take the obvious route and try to fit an Xbox power socket to match. This will have numerous advantages:
- I won't need to modify the PSU lead.
- It's built to take all the power the PSU can offer.
- I will probably be able to fit a switch to turn the PSU on and off remotely.
- I have the choice of powering the Arduino directly with 5v, rather than use the linear voltage regulator built into the Arduino/RAMPS, thus reducing heat output.
Of course, this means that I will have to build a nice enclosure to house the socket and switch (an enjoyable task) and I may have to design a PCB to keep it tidy (should also be fun).
I have ordered the socket on ebay, so watch this space!
Re: Cherry Pi III Is Available March 24, 2015 08:00AM |
Re: Cherry Pi III Is Available March 24, 2015 10:25AM |
Re: Cherry Pi III Is Available March 24, 2015 12:09PM |
Re: Cherry Pi III Is Available March 24, 2015 12:13PM |
Re: Cherry Pi III Is Available March 24, 2015 12:37PM |
Re: Cherry Pi III Is Available March 24, 2015 04:06PM |
David J
Andy,
Back on page 2 you uploaded a configuration.h file - would that still be a good starting point for me, or have things changed?
Re: Cherry Pi III Is Available March 24, 2015 04:22PM |
Re: Cherry Pi III Is Available March 24, 2015 06:16PM |
AndyCart
Re: Cherry Pi III Is Available March 24, 2015 06:59PM |
Re: Cherry Pi III Is Available March 24, 2015 07:02PM |
Re: Cherry Pi III Is Available March 24, 2015 11:42PM |
Re: Cherry Pi III Is Available March 25, 2015 02:49AM |
gowen
I'm using the version that came supplied on the SD card with the kit. I can't tell you the exact version at the moment.
Re: Cherry Pi III Is Available March 25, 2015 12:23PM |
AndyCart
It may be worthwhile downloading the latest version from Rich Cattell's Githib, link above.
//Diagonal Rod Adjustment - Adj diag rod for Tower by x mm from DEFAULT_DELTA_DIAGONAL_ROD value #define TOWER_A_DIAGROD_ADJ 0 //Front Left Tower #define TOWER_B_DIAGROD_ADJ 0 //Front Right Tower #define TOWER_C_DIAGROD_ADJ 0 //Rear Tower // Z-Probe variablesAnd appear after the Tower Radius Adjustment values and just before the Z-probe variables. With this added it compiled and installed fine although I did get these messages.
Sketch uses 121,982 bytes (48%) of program storage space. Maximum is 253,952 bytes. Global variables use 6,386 bytes (77%) of dynamic memory, leaving 1,806 bytes for local variables. Maximum is 8,192 bytes. Low memory available, stability problems may occur.It seemed to work OK though.
Re: Cherry Pi III Is Available March 26, 2015 01:13AM |
Re: Cherry Pi III Is Available March 26, 2015 04:16AM |
Zzyzxx71
Any chance someone could post up their firmware folder for a working Pi III? I have the bed/hot end and display working, Extruder is working correctly, but up/down/left/right isn't working and I can't seem to find a resource for getting that setup anywhere.
edit: I don't have autocalibration setup, was planning on manual calibration.
Thoughts? Thanks.
Re: Cherry Pi III Is Available March 26, 2015 06:02AM |
Re: Cherry Pi III Is Available March 26, 2015 08:43AM |
Re: Cherry Pi III Is Available March 26, 2015 08:49AM |
Re: Cherry Pi III Is Available March 26, 2015 08:57AM |
David J
A question about heat - relates to delta printers in general, not just the Cherry Pi.
Most deltas tuck all the motors and electronics within the base, thus restricting the air flow quite a lot. Then people go and put a heated bed on top (some of which are quite powerful) which must radiate some heat downwards.
As I intend to have some form of heated bed on my printer, should I be thinking about putting a fan in there somewhere, to help keep the RAMPS & Arduino boards cool?
cheers,
David
Re: Cherry Pi III Is Available March 26, 2015 09:06AM |
AndyCart
David J
cheers,
David
I've never needed a fan under the bed but I always use fairly low wattage heated beds. I have also stuck a piece of 3mm cork to the underside of the bed on some machines to insulate it a little. There is very little power required to move the carriages on a CP. The effector is very light and the carriages run very smoothly. My steppers usually draw about 0.75A. The things that get hot are the MOSFETs for the nozzle heater and the heat bed but they don't radiate excessive heat normally. All that said it can't hurt to add a fan. A tweak to the standard RAMPS mount would probably suffice as all you really need to do is circulate air around under the build plate. The fan could sit next to the RAMPS board and blow air down away from the bed.
Re: Cherry Pi III Is Available March 26, 2015 09:17AM |
Re: Cherry Pi III Is Available March 26, 2015 06:39PM |
Re: Cherry Pi III Is Available March 26, 2015 07:15PM |
David J
Andy,
Am I right in thinking that you recommend doing the mod on the StepStick motor drivers - shorting out R4, I think? I'll be starting off by using your configuration.h file, so I'll need to match your setup as much as possible. I will be using the 3 links under each driver board.
I have the right soldering kit to make this mod, but I only want to do it if it's a real benefit.
Re: Cherry Pi III Is Available March 26, 2015 07:19PM |
Zzyzxx71
Making a little progress here, have the firmware installed, for some reason had to invert the end stop logic for x/y/z for it to report correctly (M119).
When I select home, the X and Z (right and left forward towers) work correctly, the rear tower (y) just shimmy's down about 1cm.
That being said, when I manually raise/lower via the Z axis in Repetier, everything does up and down correctly, so I don't have a stepper pins flipped the wrong way.
Ideas?
Re: Cherry Pi III Is Available March 26, 2015 08:29PM |
AndyCart
Your tower designations and I assume your stepper and limit switch RAMPS connections are incorrect. X is front left, Y is front right, Z is the rear tower. If you get those correctly connected it may just spring into life!
