Re: Cherry Pi III Is Available April 04, 2015 05:44AM |
Re: Cherry Pi III Is Available April 04, 2015 10:43AM |
Re: Cherry Pi III Is Available April 04, 2015 04:06PM |
Re: Cherry Pi III Is Available April 04, 2015 06:57PM |
Matt,Wheatley
Andy,
I noticed on your PrntQB V5 your using a graphic display, what controller board do you use for your Core XY, also are you using the marlin firmware for it.
Thanks
Matt
Re: Cherry Pi III Is Available April 04, 2015 07:03PM |
Zzyzxx71
OK new update - about ready to stab myself in the face after working on this for the last 4 hours or so.
The following is my latest M666 L:
04:17:30.479 : Current Delta geometry values:
04:17:30.479 : X (Endstop Adj): -4.00
04:17:30.479 : Y (Endstop Adj): -7.50
04:17:30.479 : Z (Endstop Adj): -5.75
04:17:30.484 : P (Z-Probe Offset): X0.00 Y0.00 Z0.80
04:17:30.484 : A (Tower A Position Correction): 0.00
04:17:30.484 : B (Tower B Position Correction): 0.00
04:17:30.489 : C (Tower C Position Correction): 0.00
04:17:30.489 : I (Tower A Radius Correction): 0.00
04:17:30.489 : J (Tower B Radius Correction): 0.00
04:17:30.489 : K (Tower C Radius Correction): 0.00
04:17:30.489 : R (Delta Radius): 120.00
04:17:30.494 : D (Diagonal Rod Length): 240.00
04:17:30.494 : H (Z-Height): 236.80
After I get script 4 to be appropriate, scripts 1/2/3 are above the platen - as in there is a "bowl" shape which needs to be compensated for.
Once I compensate for X/Y/Z, script 4 is now below the platen.
Any ideas?
Re: Cherry Pi III Is Available April 05, 2015 09:44AM |
Re: Cherry Pi III Is Available April 05, 2015 10:24AM |
Re: Cherry Pi III Is Available April 05, 2015 06:33PM |
Re: Cherry Pi III Is Available April 05, 2015 09:25PM |
Re: Cherry Pi III Is Available April 05, 2015 09:36PM |
Re: Cherry Pi III Is Available April 06, 2015 04:29AM |
Re: Cherry Pi III Is Available April 06, 2015 04:32AM |
Re: Cherry Pi III Is Available April 06, 2015 09:40AM |
pugzor
Would it be suggested to calibrate with blue tape on the bed too?
Re: Cherry Pi III Is Available April 06, 2015 11:54AM |
Re: Cherry Pi III Is Available April 06, 2015 05:10PM |
Re: Cherry Pi III Is Available April 07, 2015 07:37PM |
Re: Cherry Pi III Is Available April 08, 2015 02:44AM |
mikes3ds
I was looking at the schematic, so you say short R4 to ground (The 10K resistor)
Re: Cherry Pi III Is Available April 08, 2015 08:11AM |
Re: Cherry Pi III Is Available April 08, 2015 10:17AM |
Re: Cherry Pi III Is Available April 08, 2015 11:59AM |
Re: Cherry Pi III Is Available April 08, 2015 11:14PM |
Re: Cherry Pi III Is Available April 09, 2015 04:31AM |
Re: Cherry Pi III Is Available April 09, 2015 11:20AM |
Re: Cherry Pi III Is Available April 09, 2015 12:57PM |
Re: Cherry Pi III Is Available April 10, 2015 01:47AM |
pugzor
I have to ask and maybe you've experienced this Andy, but does Cura take a long time to go from home to the print bed? Mine takes like 3-4 minutes every time I start a print. In that time I get filament leaking, not to mention a lot of frustration.
Re: Cherry Pi III Is Available April 10, 2015 10:09AM |
Re: Cherry Pi III Is Available April 11, 2015 11:20AM |
Re: Cherry Pi III Is Available April 11, 2015 12:43PM |
Re: Cherry Pi III Is Available April 11, 2015 01:01PM |
mikes3ds
The video is pretty cool!!!
A couple questions--
Where did you get that probe from?
Is it better than using the other designs where it uses the effector as Z probe?
Is it worth having a Z probe? (Can you manually calibrate with the z-probe easily, I was not going to have z-probe on mine unless I thought it was useful)
Re: Cherry Pi III Is Available April 11, 2015 01:58PM |
