Re: Cherry Pi III Is Available June 10, 2015 02:30AM |
Re: Cherry Pi III Is Available June 10, 2015 02:57AM |
mrorange26
Has anybody managed to make a holder so I can use a e3d lite head on the cherry pi?
Re: Cherry Pi III Is Available June 10, 2015 06:18AM |
Re: Cherry Pi III Is Available June 10, 2015 09:34AM |
Re: Cherry Pi III Is Available June 10, 2015 11:17AM |
Re: Cherry Pi III Is Available June 10, 2015 11:20AM |
bower-andy
Andy,
Great, that's just what I need, thanks!
Should I have known about that diagram? Is there a site somewhere with more information like that or is it just this forum thread?
Best regards
Re: Cherry Pi III Is Available June 10, 2015 01:20PM |
Re: Cherry Pi III Is Available June 11, 2015 02:32AM |
Re: Cherry Pi III Is Available June 11, 2015 04:03AM |
bower-andy
Hi Andy,
On p17 (http://forums.reprap.org/read.php?178,361141,page=17) gowen shows some small bent wires used to attach the springs to the guides. Are these meant to be part of the kit (I can't find them) or can I just use a bent paperclip or similar?
Best regards
Andy Bower
Re: Cherry Pi III Is Available June 11, 2015 04:29AM |
Re: Cherry Pi III Is Available June 11, 2015 04:57AM |
bower-andy
Gary,
Thanks, I don't seem to have that coil of wire.
One more question - when fitting the toothed pulleys onto the motors do the screws go nearest the motor body or furthest away. I see that the Mini Kossel instructions from Think3DPrint3D show them furthest away.
Best regards
Andy Bower
Re: Cherry Pi III Is Available June 11, 2015 04:25PM |
Re: Cherry Pi III Is Available June 11, 2015 05:15PM |
Re: Cherry Pi III Is Available June 11, 2015 06:21PM |
Re: Cherry Pi III Is Available June 11, 2015 06:32PM |
Re: Cherry Pi III Is Available June 11, 2015 06:35PM |
Matt,Wheatley
It's an aluminium print bed at the moment.
It's an amazing little thing, really easy to set up. I have it connected to a ramps board which appears to be working great. You can tell the ramps is at it's limit though, if you try and use the encoder while it's printing you have a 5 second delay on the screen output.
Re: Cherry Pi III Is Available June 11, 2015 06:38PM |
Re: Cherry Pi III Is Available June 12, 2015 09:57AM |
Re: Cherry Pi III Is Available June 13, 2015 09:02AM |
Re: Cherry Pi III Is Available June 13, 2015 02:39PM |
Re: Cherry Pi III Is Available June 13, 2015 02:55PM |
Re: Cherry Pi III Is Available June 13, 2015 04:19PM |
Re: Cherry Pi III Is Available June 13, 2015 07:06PM |
Re: Cherry Pi III Is Available June 13, 2015 07:13PM |
Re: Cherry Pi III Is Available June 14, 2015 04:56AM |
Re: Cherry Pi III Is Available June 14, 2015 11:55PM |
Re: Cherry Pi III Is Available June 15, 2015 02:22AM |
Dejay
Hello Andy. this has probably already been asked and answered but this thread is long:
What made you switch over to the wheels in slots instead of the bearing rollers on the flat aluminium parts? Simplicity? Noise? Having one side free? Since V-slot or T-slot wheels still seem more expensive and a few more bearings. Maybe someone can point me to a place where this was discussed.
I started a thread here because I was thinking about buying V-slot (currently free international shipping costs) and "came up" with flat rollers on extrusions as a cheaper alternative. I most probably seen your carriage approach before but forgot about it
Did anyone find a good solution to making a wheel cap on the bearings? Heat shrink out of silicone or something seems like a good idea.
Re: Cherry Pi III Is Available June 15, 2015 02:25AM |
David J
I've managed to get the CherryPi printing quite well, but I'm having difficulty getting the print quality acceptable.
Here the white pieces are from the CherryPi, and the yellow ones from my Prusa i3. All I've done with the yellow pieces is trim off the brim.
The CherryPi is printing with 1.75mm PLA, hot-end temp 210C, bed 60C, moderate print speed - as you can see, the print is very blobby, especially around the cut-outs and apertures, and is quite distorted. The Prusa is printing with 3.00mm ABS, hot-end temp 240C, bed 100C. Both have E3Dv6 hot-ends, but the Prusa is non-bowden with the Wade extruder directly over the hot-end.
What should I look at to reduce the blobbing and distortion on the CherryPi? Temperature? Retraction amount? Anything else?
Disclaimer: I've spent a lot of time getting my Prusa to work the way I like, and I haven't yet put that much effort into the CherryPi! I would normally expect to get even better results from the Prusa with a bit of fiddling around - this was just for a comparison.
Re: Cherry Pi III Is Available June 15, 2015 02:31AM |
Re: Cherry Pi III Is Available June 15, 2015 05:21AM |
AndyCart
I had similar issues with blobby prints after changing to the latest version of Cura. I went back tonV 14 and the issue went away.
Andy
