Cherry Pi III Is Available
Posted by AndyCart
Re: Cherry Pi III Is Available
June 15, 2015 07:43AM
Dejay
Thanks for the answer! I didn't realize you used Vslot wheels on normal extrusions. I've decided to just order some mini V wheels plus some V slot extrusions for the verticals only.
Andy is using Bosch/Rexroth 2020 T-slot extrusions, IIRC. The mini-V wheels ride inside the beveled edges of the slots, although not as nicely as they do in the proper V-slot extrusion.
As a caution, the mini-V wheels do NOT work that great in the slots of Misumi 2020 extrusions, as Misumi cuts their slots with more square edges and the wheel barely gets a bite in the slot.....
June 15, 2015 07:52AM
vreihen
I use V slot wheels on Motedis 2020 I-profile extrusions, and they work well. My original Mini Kossel kit used the same wheels on Mitsumi 1515 extrusions, and they worked well too.
June 15, 2015 09:39AM
I wish motedis would sell fitting delrin wheels for their aluminium profiles. It's a great shop with very fair prices in Europe!
Hmm I think we need is kind of an "inverse kickstarter". Customers request / pledge for certain items to be manufactured and companies can bid to make them! tongue sticking out smiley
June 15, 2015 10:16AM
Dejay
ooznest do the Delrin Openbuilds mini V-Wheels and ship out same day if in stock they also do V Slot extrusion at a fair price (Tho not as cheap as Motedis)
I tend to use them for linear rail type stuff and Motedis for all my other Extrusion/accessories.
wheels are arround 4.5 euros and the extrusion about 13 euros per meter length
Doug
June 15, 2015 11:10AM
David J
Interesting - I haven't tried slic3r yet with this printer, as I normally get quicker prints from Cura. Worth a try, as it won't cost me anything! smiling smiley
Well, I had a try, and made some progress. I processed the file in Slic3r without making any changes from those used with my Prusa.
The final result was a lot neater, but was slow to produce and very stringy. I went in and made some changes, increasing the speed and de-selecting the "use firmware retraction" checkbox that had been set previously for some reason. The result is quite decent, I think.
The top fill on the 4 corner steps isn't as nice as I'd like, being quite rough and messy. However, it's a big step forward from previous results. smiling smiley
I'm still having a few problems: I'm having all sorts of issues with calibrating the extruder, getting different results every time I try. Also, my 1.75mm E3Dv6 hot-end jammed up AGAIN, which is a real pain - I have a 3mm E3Dv6 on my Prusa, and I think I've had 1 jam since I fitted it, and that was only because the cooling fan failed and the heat got up into the body. I'm not sure I like working with 1.75mm filament...
Edited 2 time(s). Last edit at 06/15/2015 01:48PM by David J.
June 15, 2015 06:09PM
Hi David
If you send me the .stl you are printing I'll give it a try on my CPIII and see what I can come up with in terms of Cura settings.
Andy
June 15, 2015 09:57PM
the recent versions of slic3r 1.1.7 is much better than cura .. I have been using it on my 3dr and the parts are dimensionally more accurate
June 16, 2015 07:09AM
AndyCart
Hi David
Andy
Here you go...
open | download - Naze32Acro_bottom.stl (223 KB)
June 16, 2015 06:19PM
dougal1957
Oh thank you! I saw ooznest before on ebay but never checked out their online store where they are much cheaper than on ebay. About ~20% markup compared to openbuilds incl vat. 43.39 € for 9 mini v wheels including shipping. Well still expensive but YOBO right? (you only build once)
June 17, 2015 02:59AM
Dejay
dougal1957
YOBO I only wish that was true the mistakes I have made along the way.
My build actually uses 12 wheels 4 on each carriage with 2 on each being on eccentric spacer's to allow for tension adjustment (I think this makes a more solid carriage arrangement and has less Backlash in it) I am also using the Robotdigg Alloy Kossel Parts on mine as well and they make a huge difference in the solidity of the frame Robotdigg Alloy delta parts
Doug
June 17, 2015 06:27AM
Doug,
Do you have a picture of your carriages using the 4 v-wheels, you have peeked my interest.
Matt
June 17, 2015 06:32AM
Yeah I want to use 4 wheels for the carriage as well. But without the eccentric spacers.
June 17, 2015 08:57AM
Matt,Wheatley
Doug,
Matt
Here you go
If you want the Cad files I can post them as well and if you say what format you'd like I can try and export them (I Use Freecad).
Sorry bout the focus on the first 2 but you should get the idea the second one shows the Hexagonal Eccentric Spacer's (1/4 inch ones to replace the standard ones) and I have used the OpenBuilds V-Slot extrusion).
Doug
June 17, 2015 05:40PM
Thanks for the pictures! I'm going to try to 3D print the eccentric spacers. That belt tension system on the robodig parts looks nice also.
PS: Sorry Andy for going off topic grinning smiley
June 17, 2015 06:55PM
His carriages (like Andy's CP-III ones) look an awful lot like the OpenBuilds mini-V plate that these wheels were originally intended for:
http://openbuildspartstore.com/mini-v-wheel-plate/
I'm not a huge fan of this design in general, as the OpenBuilds plate and eccentrics will not provide me with enough adjustment range to take all of the slop out of the wheels on their V-slot extrusions.
FWIW, Andy's CP-IIIs rod holders fit just about perfectly on the OpenBuilds mini-V plates.....
June 17, 2015 07:15PM
Well that's a real bummer vreihen... But I want to build a delta with 4020 verticals so I'll need to print my own "plate" anyway. Still some time off though.
June 18, 2015 03:05AM
vreihen
Vreihen
You are absolutely right and I have a set of those plates
The reason I didn't use them is the hole pattern on them (For mounting the Rod Carrier's) was not quite right (I could have got them to fit but would only of used 2 holes and ofset from the joint centres which I didn't want) hence I took the openbuild design and extended the height by 10 mm and put my own bolt pattern in for the carriers.
I find that there is plenty of adjustment in them for the Openbuilds V-Slot rails which is after all what they are designed for.
I have managed to get them set up with no descernable backlash in fact I may have them a little to tight.
Dejay ooznest have engineering drawing's of the plates on there website.
Doug
June 18, 2015 08:09AM
dougal1957
vreihen
You can see in the picture above what I wound up doing. I drilled two holes from the back, and used a pair of low-profile SHCS to attach the plate. (The screws are also black, and coincidentally wound up with the tips being flush with the printed rod mount if you look inside the belt holder and the dimple in the big open space.)
When I ordered the set from OpenBuilds (1.5 years ago), they recommended two eccentrics and two standoffs for the four wheels. When I crank the eccentrics all the way in, I am *barely* getting a play-free carriage on their V-slot. Maybe they adjusted the plate or are recommending 4 eccentrics now, but the parts that I received were marginally usable. Plus, I don't think that they ever considered the off-center carriage shift of a few millimeters when using the eccentrics. I'm still planning to use them on my spin of the HotBot2 (as pictured), but will probably replace them with a new design as soon as I can use it to print ABS without warping.....
June 18, 2015 08:23AM
vreihen
dougal1957
vreihen
I think that they did consider the offset carriage and dimensioned everything from the non Eccentric holes see Mini Vee Wheel carriages Drawing (Openbuildpartstore done seem to have this published) and it is this drawing I used to do my own and altered the vertical spacing of the wheels by I think 10 mm which helps to run a little truer as well must admit that mine are also close to the limit of adjust ment and maybe reducing the width between centres of the holes from 31.9 to something more like 31.5 may have been better.
I printed mine in ABS and made them 10 mm thick.
Printer seems to be doing ok at the moment still a little bit of fine tuning to do but I am printing at 100 mm/s at the moment next job will be an enclosure for ABS Printing.
Doug
June 18, 2015 02:35PM
I'm starting my build now, and I want to use all the 220mm of the MK3 round aluminium heated bed.
What is the calculation I need to do in order to know the length or the rods I need to cover all this area?
I'm using 10mm balls and not 8mm.
In the BOM at thingierse, Andy says that the build area is about 190x190 mm, and he cut to rods to 225mm.
Also, I want to get 300mm build height, 650mm extrusion will be enough with the longer new rods?
I know I can cut 270mm rods and use 700mm extrusion and it probably fit my needs, but arms longer than I need will reduce the printable height, and I want my printer to be as small as possible.
Thanks!
June 18, 2015 05:55PM
itaysp
Thanks!
There's been quite a bit of discussion on rod length but I always use a length that is 80% of the distance between tower centres, or thereabouts.
June 18, 2015 07:39PM
A good rule of thumb is that the rods should be at 30 degrees to the vertical when the effector is centred, which means the rod lengths are twice the delta radius. Slightly shorter is OK, e.g. I have 300mm printable diameter, 180mm delta radius, and 350mm rods.
Edited 1 time(s). Last edit at 06/18/2015 08:01PM by dc42.
June 19, 2015 03:30AM
I did some calculation for 220mm printable diameter, but I didn't know if i'm correct.
After you said you are using 350mm arms for 300mm printable diameter I think they might be right smiling smiley
Arms length: 248.21mm
Degrees between arms and tower: 33.87mm
lost height: 206.17mm
This is the length of the arms when they are at the end of the 220mm bed, and the arms are 90 degrees with the tower, which I don't think is good.
Adding 9% to the arms will give me:
Arms length: 270.55mm
Degrees between arms and tower: 30.72
Lost height: 224.75
For 300mm printable diameter my calculation gave 314mm rods, so I did the right calculations.
Here is my calculator:
[docs.google.com]
I don't sure about all the distances and length I used in the calculator, but it's a good estimation I think.
Thank you!
Edited 2 time(s). Last edit at 06/19/2015 04:03AM by itaysp.
June 19, 2015 03:55AM
itaysp
Arms length: 269.76mm
Degrees between arms and tower: 36.31
lost height: 217.36mm
Arms length: 294mm
Degrees between arms and tower: 32.91
Lost height: 236.92
For 300mm printable diameter my calculation gave 337mm rods, so I did the right calculations.
Thank you!
Doing the sums for my printer, the angle of the rods to the vertical works out as 31 degrees. So your 32.9 degrees is still a little high compared to my build, and you might want to make the arms a little longer still.
A few useful formulae:
Delta radius = horizontal distance spanned by each of the 6 arms when the effector is in the centre of the bed
Print radius = delta radius - horizontal distance spanned by a pair of rods to the closest tower when the effector is as close to the tower as it can get
Therefore, if the geometry allowed the rods to become vertical when the effector is close to a tower, you would have print radius = delta radius. In practice, the effector can''t usually get that close, so the print radius is less then the delta radius (by 30mm in my build). If the arms are long enough and the joints have enough movement, you may be able to print out to more than the "print radius" as I have defined it above when the effector is between the nearest towers.
June 19, 2015 04:06AM
Hey,
I edit my calculations and put a link to the calculator (in my last post).
Now the degree is about 30.72 (If my calculations are correct)
I edit the previous post but you made your comment while I was editing :/
Edited 2 time(s). Last edit at 06/19/2015 07:40AM by itaysp.
June 19, 2015 07:43PM
andy can your printer print as fine as the ultimaker 2 ie as high as 20 microns
June 19, 2015 07:53PM
Hi All,
I have just put a duet controller into my Cherry Pi and I am having a strange issue. If I move the motors, everything moves okay but once the motor stops at the correct place it is still making a noise for 10+ seconds after. If I hit the emergency stop the noise stops. I have taken a video of it here:-
[drive.google.com]
Anybody know what I have done wrong?
I have the motor ratings in the config.g file set to 1700, which is what the stepper motors are supposedly rated for, but setting this at 1000 doesn't appear to make a difference to the noise after move.
Thanks
Matt
Edit:
Reading around about stepper motors and I think I understand. The noise when the motor is not moving is because you have to keep the stepper energised to stop in moving. I never heard this on the ramps, but I guess the voltage to hold the motor was different in the drivers I had on the ramps.
Edited 1 time(s). Last edit at 06/19/2015 10:54PM by Matt,Wheatley.
June 20, 2015 02:13AM
Matt,Wheatley
Hi All,
[drive.google.com]
Thanks
Matt
Edit:
Hi Matt,
Running the motors at their rated current is not necessary and not a good idea. Both the motors and the drivers will get hot. If the motors are 48mm long Nema 17s like mine (which are also rated at 1.7A), then 800mA is probably enough (I use just 500mA for my extruder motor). If they are shorter, you may need 1000mA to 1200mA. Your RAMPS drivers will have been set much lower than 1.7A - if you know what voltage you had them adjusted to, you can work it out.
After editing new values into the M906 command in config.g and uploading it, you need to restart the machine to make it read config.g again. The easiest way to do this is to use the Emergency Stop button on the web interface. You can also adjust current on the fly sending the M906 command to the printer. Sending M906 with no parameters causes the existing values to be echoes back.
The reason it goes quieter after a while is that after 30 seconds of inactivity, the firmware reduces the current to the idle hold value. By default, this is 30% of the normal current. You can adjust it using the I parameter in the M906 command, e.g. M906 I50 will make the idle hold current 50% of the normal current.
June 20, 2015 12:04PM
Thanks David, That makes sense, I have dropped the current on all the motors now.
The Modulated IR sensor I have , which I have set to P1 only appears to report 0 or 530, which I guess is fine, and the calibration runs but I appear to get wildly different result after each run:-
4:29:42 PMM665
Diagonal 304.33, delta radius 149.95, homed height 137.65, bed radius 130.0, X -0.5°, Y -0.6°
4:29:25 PMG32
Calibrated 7 factors using 10 points, RMS error before 0.10 after 0.03
4:27:30 PMM665
Diagonal 290.97, delta radius 146.14, homed height 137.58, bed radius 130.0, X -1.9°, Y -2.0°
4:25:53 PMG32
Calibrated 7 factors using 10 points, RMS error before 0.17 after 0.02
4:24:20 PMM665
Diagonal 327.20, delta radius 156.63, homed height 137.63, bed radius 130.0, X -1.2°, Y -1.0°
4:24:10 PMG32
Calibrated 7 factors using 10 points, RMS error before 0.81 after 0.04
Anything I should be looking at.
Thanks
Matt
Edit, it actually looks like the calibration isn't running fully. It only probes all the points once then homes, which I thought might mean its finished, however I just had it probe all the points twice then just stop and not home.
Edited 1 time(s). Last edit at 06/20/2015 01:25PM by Matt,Wheatley.
June 20, 2015 01:37PM
Just on a side note, I have created a spreadsheet to give the X Y Z, XY, YZ, ZX coordinates for the probe positions. Just put your printer bed radius in A1 and your done.
[docs.google.com]
