Is this the effect of missing steps on a delta? May 28, 2014 10:45AM |
Re: Is this the effect of missing steps on a delta? May 28, 2014 02:43PM |
Re: Is this the effect of missing steps on a delta? May 28, 2014 04:35PM |
Re: Is this the effect of missing steps on a delta? May 28, 2014 04:52PM |
Re: Is this the effect of missing steps on a delta? May 28, 2014 05:05PM |
Re: Is this the effect of missing steps on a delta? May 28, 2014 05:28PM |
I assumed he did it:Quote
imyz
For deltas you should pass the paper test at 4 points.
But if not, he should check 7 points and not only 4: [forums.reprap.org]Quote
Zedsquared
I'm pretty sure I have calibration down OK and can see flat movement when I jog the head around at low height above the bed using the LCD and selecting X or Y movement.
Re: Is this the effect of missing steps on a delta? May 28, 2014 06:18PM |
Re: Is this the effect of missing steps on a delta? May 29, 2014 02:39AM |
Re: Is this the effect of missing steps on a delta? May 30, 2014 06:54AM |
Re: Is this the effect of missing steps on a delta? May 30, 2014 03:32PM |
Re: Is this the effect of missing steps on a delta? May 30, 2014 04:28PM |
Re: Is this the effect of missing steps on a delta? June 05, 2014 09:43AM |
Re: Is this the effect of missing steps on a delta? November 28, 2014 04:25PM |
Re: Is this the effect of missing steps on a delta? December 01, 2014 08:19AM |
