Perfect Build Surface For PLA? June 20, 2014 01:08PM |
Re: Perfect Build Surface For PLA? June 23, 2014 10:10AM |
Re: Perfect Build Surface For PLA? June 23, 2014 07:00PM |
Re: Perfect Build Surface For PLA? June 24, 2014 08:06AM |
sheepdog43
There is a guy who goes to events at my hacker space who used acrylic all the time.
The problem is, it can sometimes stick too well, and then there's the times where the head hits and digs a track through it. Last I saw, he was back to using glass with a glue stick.
Re: Perfect Build Surface For PLA? June 24, 2014 05:44PM |
Re: Perfect Build Surface For PLA? June 24, 2014 10:55PM |
Re: Perfect Build Surface For PLA? June 25, 2014 08:03PM |
Re: Perfect Build Surface For PLA? June 26, 2014 12:16PM |
Re: Perfect Build Surface For PLA? July 02, 2014 02:15AM |
AndyCart
Each to his his own then. I'll stick with this until something better comes along. I've never had a head crash and I have a roll of 200mm wide kapton with about another 25M on it. The biggest benefit i have found with this method is that I seem to be able to print again and again on the same tape.
Re: Perfect Build Surface For PLA? July 03, 2014 10:44PM |
Re: Perfect Build Surface For PLA? July 04, 2014 06:03PM |
Re: Perfect Build Surface For PLA? July 06, 2014 09:37PM |
Re: Perfect Build Surface For PLA? July 07, 2014 10:38AM |
Re: Perfect Build Surface For PLA? July 08, 2014 09:36PM |
Re: Perfect Build Surface For PLA? July 10, 2014 03:35PM |
Plastic type materials do tend to not steal as much heat as glass does.
Re: Perfect Build Surface For PLA? July 11, 2014 02:38PM |
ekaggrat
did you try the vinyl on aluminum plate... The vinyl worked perfectly for me on a glass plate but strangely on a aluminum plate it just wont stick for more than 3 to 4 layers of print... Well back to blue painters tape i guess... or maybe vinyl on acrylic....
Re: Perfect Build Surface For PLA? July 17, 2014 09:51PM |
Re: Perfect Build Surface For PLA? July 17, 2014 11:43PM |
Re: Perfect Build Surface For PLA? July 18, 2014 03:51AM |
Re: Perfect Build Surface For PLA? July 18, 2014 09:11PM |
Re: Perfect Build Surface For PLA? July 18, 2014 09:33PM |
Re: Perfect Build Surface For PLA? July 19, 2014 07:23AM |
Re: Perfect Build Surface For PLA? July 20, 2014 12:30PM |
Re: Perfect Build Surface For PLA? July 21, 2014 10:09PM |
Re: Perfect Build Surface For PLA? July 21, 2014 10:44PM |
Re: Perfect Build Surface For PLA? July 21, 2014 11:51PM |
Re: Perfect Build Surface For PLA? July 22, 2014 12:34AM |
Re: Perfect Build Surface For PLA? July 22, 2014 07:48AM |
Re: Perfect Build Surface For PLA? July 22, 2014 08:06AM |
Re: Perfect Build Surface For PLA? July 22, 2014 08:39AM |
