Curious delta problem: slanted prints July 23, 2014 05:14PM |
Re: Curious delta problem: slanted prints July 24, 2014 09:59AM |
Re: Curious delta problem: slanted prints July 24, 2014 10:03AM |
Re: Curious delta problem: slanted prints July 24, 2014 10:46AM |
Re: Curious delta problem: slanted prints July 24, 2014 11:00AM |
Re: Curious delta problem: slanted prints July 24, 2014 06:08PM |
Re: Curious delta problem: slanted prints July 25, 2014 03:29AM |
Re: Curious delta problem: slanted prints July 25, 2014 05:00AM |
Re: Curious delta problem: slanted prints July 25, 2014 05:10AM |
Re: Curious delta problem: slanted prints July 25, 2014 02:51PM |
Re: Curious delta problem: slanted prints July 27, 2014 02:06PM |
Re: Curious delta problem: slanted prints July 28, 2014 12:30PM |
Re: Curious delta problem: slanted prints July 30, 2014 08:17AM |
It was more like GT2-36, which I had earlier, means 44.4444 steps/mm and GT2-16 means 100 steps/mm which should result in less rounding errors see also [forums.reprap.org]Quote
squishyheadboy
RostockMini4tw,
Thanks for the info. It's interesting that your problem went away when you switched to a smaller pulley - that should mean more steps per mm movement, which in turn means bigger numbers of steps overall. My immediate thought is that overflow or rounding errors ought to be more likely. I have tried to use Repetier firmware, but it has a separate problem for me..
Re: Curious delta problem: slanted prints August 03, 2014 11:21AM |
jaguarking11
I just took a look at the pic. Your not cooling the hot end at all it looks like. I don't either. However I can say that from the pic it looks like the hot end is slanted. I bet your getting distortion on the hot end carriage. I had problems with distortion on my printer as well. Also it was unable to hold a z - axis height because the hot end was moving with heat. I cured it by using aluminum sheet. Dismount the carriage and inspect it for warping. To me the plastic used looks like PLA which distorts after about 55-60c.
Re: Curious delta problem: slanted prints August 06, 2014 05:36AM |
Re: Curious delta problem: slanted prints August 22, 2014 01:43PM |
Re: Curious delta problem: slanted prints June 10, 2016 02:20PM |
Re: Curious delta problem: slanted prints June 11, 2016 03:12AM |
Re: Curious delta problem: slanted prints June 11, 2016 05:57AM |
Re: Curious delta problem: slanted prints November 06, 2016 04:44PM |
