End Stop Woes... Homing issues. August 21, 2014 03:42PM |
// ################ Endstop configuration ##################### #define ENDSTOP_PULLUP_X_MIN true #define ENDSTOP_X_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_X true #define ENDSTOP_PULLUP_Y_MIN true #define ENDSTOP_Y_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_Y true #define ENDSTOP_PULLUP_Z_MIN true #define ENDSTOP_Z_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_Z true #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_X_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_X false #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_Y_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Y false #define ENDSTOP_PULLUP_Z_MAX true #define ENDSTOP_Z_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Z false #define max_software_endstop_r true #define min_software_endstop_x false #define min_software_endstop_y false #define min_software_endstop_z false #define max_software_endstop_x true #define max_software_endstop_y true #define max_software_endstop_z true #define ENDSTOP_X_BACK_MOVE 5 #define ENDSTOP_Y_BACK_MOVE 5 #define ENDSTOP_Z_BACK_MOVE 2 #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_X_BACK_ON_HOME 1 #define ENDSTOP_Y_BACK_ON_HOME 1 #define ENDSTOP_Z_BACK_ON_HOME 0 #define ALWAYS_CHECK_ENDSTOPS 1 // ################# XYZ movements ################### #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 #define INVERT_X_DIR 0 #define INVERT_Y_DIR 0 #define INVERT_Z_DIR 0 #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR 1 #define X_MAX_LENGTH 200 #define Y_MAX_LENGTH 200 #define Z_MAX_LENGTH 855 #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0
Re: End Stop Woes... Homing issues. August 21, 2014 04:25PM |
Re: End Stop Woes... Homing issues. August 21, 2014 08:01PM |
Re: End Stop Woes... Homing issues. August 22, 2014 02:34AM |
If you're wiring your endstops into the X3's min connectors, the nice locking ones, you'll need to change the pin assignments in pins.h. I forget what the min pin assignments are but if you search in the groups there's a message which says which the right ones are. You'd probably be better off wiring into the header pins behind the min pins. That way you won't have to remember to change pins.h everytime you grab a new copy of marlin.
I used the low pins, so I didn't have to move the screw terminals, but I'm using repetier and I had to swap the pin numbers in pins.h
#define X_MIN_PIN 3 = now is -1 to disable
#define X_MAX_PIN 2 = now is 3 to enable on the low pins on the board
Re: End Stop Woes... Homing issues. August 22, 2014 07:14AM |
Re: End Stop Woes... Homing issues. October 10, 2014 09:05AM |
Re: End Stop Woes... Homing issues. October 10, 2014 11:49AM |
Re: End Stop Woes... Homing issues. October 11, 2014 08:35AM |
Re: End Stop Woes... Homing issues. October 17, 2014 12:51PM |
