Mini Kossel wont register endstops August 23, 2014 03:21PM |
Re: Mini Kossel wont register endstops August 23, 2014 09:27PM |
Re: Mini Kossel wont register endstops August 23, 2014 11:46PM |
Re: Mini Kossel wont register endstops August 24, 2014 06:39AM |
Re: Mini Kossel wont register endstops August 24, 2014 08:34AM |
Re: Mini Kossel wont register endstops August 24, 2014 10:56AM |
Re: Mini Kossel wont register endstops August 24, 2014 11:24AM |
Reporting endstop status x_max: open y_max: open z_min: open z_max: open okFor my Minitronics board I had to swap the MIN and MAX pins in pins.h:
#define X_MIN_PIN -1 #define X_MAX_PIN 5 #define Y_MIN_PIN -1 #define Y_MAX_PIN 2 #define Z_MIN_PIN 6 #define Z_MAX_PIN 6Z_MIN_PIN is in conflict in my situation,
Re: Mini Kossel wont register endstops August 24, 2014 11:58AM |
T3P3
This is a slight modification on Johann's firmware (modifications just for our mini kossel changes) which you can try:
[github.com]
It works well with our mini kossel kit
Cheers
Tony
11:35:21.892 : Reporting endstop status
11:35:21.896 : x_max: open
11:35:21.896 : y_max: open
11:35:21.896 : z_min: open
11:35:21.896 : z_max: open
Re: Mini Kossel wont register endstops August 24, 2014 12:18PM |
Re: Mini Kossel wont register endstops August 24, 2014 12:21PM |
Re: Mini Kossel wont register endstops August 24, 2014 12:31PM |
T3P3
Check the pins.h in the think3dprint3d version for the correct endstop in numbers for RAMPS. Also if it wont connect then have you set the baud rate in Repetier to 115200?
Re: Mini Kossel wont register endstops August 26, 2014 09:41AM |
Re: Mini Kossel wont register endstops August 26, 2014 11:39AM |
Re: Mini Kossel wont register endstops August 26, 2014 03:28PM |
Wildcard
It acts as if the endstops are not working.
When you run an M119. Manually trigger the endstops and see if they report triggered when you are holding it. And make sure that on the ramps, the endstops are in the correct location: the min enstops. From the left to the right, the endstops go x min, x max, y min, y max, z min, z max.
Re: Mini Kossel wont register endstops August 26, 2014 04:33PM |
Re: Mini Kossel wont register endstops August 26, 2014 07:06PM |
Re: Mini Kossel wont register endstops August 26, 2014 08:02PM |
Re: Mini Kossel wont register endstops August 27, 2014 07:36AM |
