Heated bed on Delta mini
Posted by Replace
August 24, 2014 04:36AM
I ordered a circular heated bed on ebay, to put on my 3dprinterczar Rostock Delta Mini Pro.
Now I need to take care not to harm the acrylic base, so i am thinking of an aluminium circular plate, on stands, under which I will attach the silicone heater.
Than I will put exchangeable circular glass beds on top to print on.
(I do that with my orca: print on the heated glas, exchange the glass and continue on the next one while the other cools down.)
Has anyone built an heater on this type of acrylic machine ?
How much distance to the base plate ? What insulation between the heater and the base ? What construction ?
Advice is appreciated
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Heated bed on Delta mini
August 24, 2014 11:42AM
10mm to 12 mm insulation foam ( the kind they use in wall insulation ) works best ... if you access to glass wool ( 5-8 mm ) that works best
August 24, 2014 03:51PM
1/4in (5 or 6mm) of cork board works well as insulation.
Beware, many cork boards now sold are not solid.
Pretty sure this is what I used:
[www.target.com]
August 25, 2014 07:58AM
Ahh cork,
that is a conveniant idea. It will be nicely shaped when I cut it alongside my bed.
Thanks
August 26, 2014 04:58PM
I was going to use cheap cardboard for my kossel,
is that insulating enough or should I upgrade to cork?
RS-Online Ormerod #263, Kossel mini with Minitronics, Prusa i3 MK2
open | download - 20140826_001.jpg (520.9 KB)
August 26, 2014 08:05PM
I used a cardboard box flap under my old Mk2 heatbed as the insulator. It would not reach 100C without it.....
