How critical is the accuarcy of the different arm lengths ? August 28, 2014 05:43AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 07:29AM |
First, I would advice you to use a large caliper, and if you don't have such a tool, a simple tape measure.Quote
ianmcmill
+/-1 mm (measured with double meter stick)
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 07:33AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 08:02AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 10:36AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 11:03AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 11:15AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 11:37AM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 06:02PM |
Re: How critical is the accuarcy of the different arm lengths ? August 28, 2014 10:40PM |
hercek
Marlin firmware can be easily updated to support different rod length for each tower (Repetier even supports this out of the box). But rods connecting to the same tower must be the same.
Wildcard
do not use solvent as you are more likely to erode the resin (polyester of epoxy) that is keeping the carbon fabric together. You can use heat, to a certain degree (200 F.), but the best option is to cut them off
Re: How critical is the accuarcy of the different arm lengths ? August 29, 2014 10:02AM |
hercek
The best approach is to use right threaded screw on one side of a rod and left threaded screw on the other. Glue the screws to the rod. Then screw the ball joints at the screws. This allows you to adjust the rod length precisely. Otherwise (if you would use the same threads on both sides of a rod) you can set the rod length with the precision of pitch/2 only (that means 0.25 mm for M3, not very good).
