Magnetic Joints October 11, 2014 08:30PM |
Re: Magnetic Joints October 12, 2014 02:13PM |
Re: Magnetic Joints October 12, 2014 05:11PM |
Re: Magnetic Joints October 12, 2014 06:39PM |
Re: Magnetic Joints October 12, 2014 08:25PM |
is here [forums.reprap.org]
Re: Magnetic Joints October 12, 2014 08:40PM |
If only that statement were true.Quote
plastik
Hercek, thank you for the link you made up my mind is too much trouble doing the traxxas I am going the magnetic route.
Re: Magnetic Joints October 13, 2014 01:01AM |
Re: Magnetic Joints October 13, 2014 05:22AM |
Re: Magnetic Joints October 13, 2014 05:42PM |
Re: Magnetic Joints October 14, 2014 06:56AM |
AndyCart
Another alternative is to use the system I use on my Cherry Pi IIIS models. It has all the benefits of magnetic attachment, precision, ease of removing the effector, etc but none of the draw backs. It's also really inexpensive to implement. Basically you have a drilled 8mm ball bearing on the end of each delta rod and a length of Spectra line attached to a spring to hold it all together. It works great.
[forums.reprap.org] (about half way down the page)
Andy
Re: Magnetic Joints October 15, 2014 02:35AM |
plastik
Hi AndyCart, thank you for the info, do you know if those ball bearings are still for sale in eBay? I am guessing that it would be a bitch to drill those out, not only because of the shape but ball bearings I am going to assume they are extremely hard. Thank you.
Re: Magnetic Joints October 27, 2014 02:18PM |
