FSR sensors and heated bed October 16, 2014 02:24AM |
Re: FSR sensors and heated bed October 16, 2014 06:29PM |
Re: FSR sensors and heated bed October 16, 2014 07:17PM |
Re: FSR sensors and heated bed October 17, 2014 05:34AM |
Re: FSR sensors and heated bed October 17, 2014 07:54AM |
Re: FSR sensors and heated bed October 17, 2014 08:29PM |
wuz
If you use Johns FSR board [github.com] you don't have to reset it, as it adjust itself constantly.
Re: FSR sensors and heated bed October 18, 2014 06:14PM |
Re: FSR sensors and heated bed October 20, 2014 12:07AM |
Re: FSR sensors and heated bed October 20, 2014 02:12AM |
Re: FSR sensors and heated bed October 20, 2014 07:26AM |
sheepdog43
wuz
I think that's just part of his code in general as I think my Trinkets with his code does the same.
Re: FSR sensors and heated bed October 20, 2014 07:56PM |
You press a sensor light comes on, doesn't matter if there is one light or 3. We've had a few fail and it wasn't hard to diagnose.Quote
wuz
Sure, its just code, but then you only have one LED. I had one sensor not firing as a small piece of PLA got stuck next to the sensor, and I would have had a harder time to figure this out, if there is only one LED as the others chime in, at some point.
Also the board comes already programmed, so the install is very very easy.
Re: FSR sensors and heated bed October 21, 2014 06:57AM |
Re: FSR sensors and heated bed October 21, 2014 02:30PM |
Re: FSR sensors and heated bed October 22, 2014 04:57AM |
Re: FSR sensors and heated bed October 22, 2014 06:08AM |
Re: FSR sensors and heated bed October 22, 2014 03:22PM |
Re: FSR sensors and heated bed October 22, 2014 05:19PM |
sheepdog43
Endstops are ignored while printing.
If you plan on only heating one area, it will need to be boro, otherwise you will break the glass.
Re: FSR sensors and heated bed October 23, 2014 06:27PM |
You aren't heating the glass unevenly, or just one area because you are using a heat spreader, some heat difference is acceptable, it's not going to break because of a small difference.Quote
AndyCart
sheepdog43
Not necessarily. I have a similar setup on one of my core xy machines. I use a 200 x 200 MK2A heat bed pcb but my glass bed is 300 x 300. I have a piece of 1mm aluminium sheet between the pcb and the glass and the glass is held in place with bulldog clips to allow lateral expansion. The glass is normal 4mm window glass and has dozens of hours of print time with no issues.
I run it at 70 for PLA and 100 for ABS. The bed edges I.e not directly over the pcb are cooler than the centre but the aluminium helps even things out a bit. At 70 in the centre the edges are around 60.
Andy
Re: FSR sensors and heated bed October 23, 2014 09:10PM |
Re: FSR sensors and heated bed October 24, 2014 09:03AM |
Re: FSR sensors and heated bed October 25, 2014 04:11AM |
Re: FSR sensors and heated bed November 15, 2014 09:22PM |
Re: FSR sensors and heated bed November 18, 2014 06:06PM |
Re: FSR sensors and heated bed November 26, 2014 01:51AM |
