what is a 'normal' feed force required from extruder motor? November 10, 2014 10:21PM |
Re: what is a 'normal' feed force required from extruder motor? November 11, 2014 01:33AM |
Re: what is a 'normal' feed force required from extruder motor? November 11, 2014 04:24AM |
Re: what is a 'normal' feed force required from extruder motor? November 11, 2014 11:20AM |
Re: what is a 'normal' feed force required from extruder motor? November 12, 2014 02:28PM |
Re: what is a 'normal' feed force required from extruder motor? November 13, 2014 06:07AM |
My problem was solved by replacing the motor with an expensive geared extruder motor,
if you want a cheaper solution you can probably also use a 3D printed gearbox design!
Re: what is a 'normal' feed force required from extruder motor? November 13, 2014 05:26PM |
Re: what is a 'normal' feed force required from extruder motor? November 13, 2014 07:01PM |
Re: what is a 'normal' feed force required from extruder motor? November 16, 2014 05:47PM |
Re: what is a 'normal' feed force required from extruder motor? November 18, 2014 03:43PM |
Re: what is a 'normal' feed force required from extruder motor? November 18, 2014 09:22PM |
Re: what is a 'normal' feed force required from extruder motor? November 19, 2014 08:30AM |
Re: what is a 'normal' feed force required from extruder motor? November 19, 2014 01:49PM |
Re: what is a 'normal' feed force required from extruder motor? November 21, 2014 02:41PM |
Re: what is a 'normal' feed force required from extruder motor? November 23, 2014 11:42AM |
