Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 03, 2015 04:06PM |
I'm using 0.92 Repetier firmware.Quote
iceman62
Are you getting anything to work in the Repetier FW like Auto Leveling or the LCD cause I could not get either to work under Repetier FW.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 03, 2015 05:32PM |
rtideas
iceman62
The X and Y direction were swapped. I swapped the X- and Y-motor and the X- and Y-stop wiring. BUT I could have just swapped the angles for the columns--210 with 330 and vice versa.
I realized from the configuration wizard drawing that my towers were wrong from what was suggested in the build manual.
I have some weird limits when the head is at its lowest.
Currently, manually controlling it for testing using Reptier-Host and -Server on my iMac.
The 2004 LCD Display Controller does work fine.
The connector for D10 broke so I rerouted the hot end to D9 and soldered the hotend fan directly to D10. I altered the pins.h file to get it to work. And my config file for the fan.
The one of the biggest hurdles with Repetier was the EEPROM. Very confusing to start. Still confused. ALWAYS check the EEPROM settings to make the settings take.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 03, 2015 06:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 03, 2015 07:47PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 04, 2015 10:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 06:58AM |
Excellent. Thank you!Quote
Drago
"Yeah, no auto-leveling yet. Still getting the regular movements dialed in. My extruder to moving about 4x the distance it is supposed to. telling it to move 10mm, actually moves about 38.5mm of filament."
With the folger tech extruder and 1/16 microstepping. Set the extruder to 95 steps/mm
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 08:44AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 08:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 09:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 11:15AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 11:19AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 11:36AM |
kylaris
I had the servo working on the marlin FW, but removed the servo all together. The servo has 3xmm 3xmm X Y offset( I forgot the actual measurement ).
On my 190mm building area , it probes about 130mm of it.
Anyone printing at descent speed without the extruder skipping/slipping? like >35mm/s?
Tried increasing temp, lubing the filament with canola oil, increasing the extruder motor volt, but still skips
BTW why is everyone using the Repetier FW? Is it better?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 02:10PM |
iceman62
kylaris
I am trying both Firm Ware's because I want my auto leveling to work. I have only been able to print with Marlin though. With the Marlin FW I have the LCD
working and I can get movement with the auto leveling (but it's not working correctly) and I can print if I don't add the G-Start code for the auto leveling. I'll
attach a couple pics of something I have printed with Marlin FW.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 04:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 05, 2015 04:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2015 09:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2015 08:34PM |
djfriz
I am a little unclear about total rod length and would appreciate any insight i could get. I cut the rods at 250mm which I read here somewhere but that makes the total length center to center 300mm. It that too long and should I cut them to get a total center length of 250mm or 280mm.
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2015 10:42AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2015 11:15AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2015 06:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2015 11:11PM |
mmcginnis9272
Step 27 in the v2 build manual states that the bed leveling servo arm is attached in the configuration manual. I do not see an updated configuration manual, nor do I see anywhere in the existing configuration manual where this is described. Any ideas?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 02:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 10:02AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 10:06AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 04:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 05:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 08:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 08:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 08:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 09:13PM |
