Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 02:43PM |
ohecht
OK, I spent the day adjusting the end stops and changing the Smooth Rod Offset to get the printer to print on a flat plane even with out autoleveling...so far so good on my first large test print, but the nozzle is staying at the same height all the way across the print. I ended up with these offsets at 180mm, which seems huge, but that's the number that allowed me to get the print head the same distance off the bed near each of the 3 towers and in the middle with no concave or convex areas between the 3 outer points and the center of the bed...
Here are the new problems I'm having:
- I'm using Slic3r within Repetier Host, and the custom code for the autolevel is in the configurations there, but it's not going into the G-code when I slice the files.
- When I try to use the autolevel, it looks like it's trying to go off the print bed. I also have objects start off way outside my print area when I bring them into Repetier...I have to zero out the X, Y, and Z axes to get the objects near the middle of the print area...I wonder if these two are related somehow I'm still not sure I have all my print area dimensions right, even though I've been through the configuration manual and screen shots many times by now.
- I noticed I can't move the print head less than .2mm during all of my calibrations. Is this the limitation of the 36-tooth pulleys and why most people seem to prefer 20-tooth pulleys?
Thanks again for all the help...I'd just like to get the autolevel working to fine-tune my already close physical calibrations and then learn how to use the software more effectively with positioning objects, etc.
Olivier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 04:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 05:28PM |
Oliver,Quote
ohecht
Thanks Unnokeng. I gave up on the auto-level function for a while since I don't seem to need it now that I got my "flatness" problem physically calibrated. I went through the routine of moving the endstops ever so slightly and adjusting the Smooth Rod Offset (ended up at what seems like a huge number...180mm), but the end result is that I can print perfectly flat across the build platform. Now I'm focusing on temperature calibrations...I have it dialed in perfectly for white PLA, but the black stuff (also a different brand) was not feeding reliably so I need to add a few more colors to my bag of tricks by getting the right temp settings everywhere. I was using G29, but the probe was trying to run off the platform. I think I need to double-check the probe points, but it's not a priority now as I don't seem to need it too much. One thing I never understood about G29 was whether it was just running the autoprobe function and gathering the data points, or if it was also changing the actual settings in the firmware or elsewhere to compensate for those readings...I never got a clear answer on that although it reads like G29 just takes care of it all.
About the .1mm resolution...are you saying that you never used 36-tooth pulleys because you knew it would prevent you from making .1mm changes?
Thanks again,
Olivier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 06:11PM |
mmcginnis9272
Strange, the extruder motor feed coupler and the effector coupler are identical on mine.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 06:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 06:30PM |
ohecht
Thanks again Unnokeng. I'd love to know more about your geared extruder in terms of where you got it (or the files to print it) and what other changes you made to make it work...I was looking at those when I was struggling with the black PLA before giving up for a while and printing in white again. My extruder will skip if I look at it funny, so anything that will give me a more reliable feed would be great.
Olivier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 08:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 02:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 02:52PM |
My box was 32" x 10" x 7" and guessing about 16-20 lbs.Quote
ibonneau
Hey guys,
Just a quick question, thinking of buying this kit when I come for a visit late in March to the US. anyone can tell me the weight of the package and dimensions - Need to see if I can fit it in my luggage.
Thx
p.s.
tried calling and writing the Folger guys but no answer as of yet.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 03:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 03:59PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 04:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2015 04:54PM |
ohecht
Thanks, Maker. Looking forward to those improvements. I was able to get my printer to print flat without using autolevel and with just the acrylic spacers under the bed by adjusting the end stops and the smooth rod offset.
I am also running the LCD and haven't noticed any power issues, although the LCD seems to only come on when I connect the USB cable and stays on even when the main printer cable is unplugged. I may have to look into that when I want to try stand-alone printing from the SD card...
Olivier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2015 12:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2015 01:21AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2015 08:26AM |
rtideas
Possibly the contrast dial on the back is turned down? I bumped mine and thought it was not working and the contrast was just too low to see.
Attached is my config file, but take it with a grain of salt. Some things have change -- you can change eprom settings directly with Repetier-Host. And I rerouted my power for D10 to D9. And my arm length is 272mm--wanted maximum bed reach.
Hopefully it helps a bit.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 18, 2015 10:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 11:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 05:09PM |
iceman62
Hey Makerfront
The Cura ini file you uploaded to the google drive do I have to install the full version of Cura to use it
or is there a way to import them into the Cura Works slicer built into Repetier Host?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 06:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 08:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 08:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 08:21PM |
ohecht
Hello again...quick question for anyone who's tried (and hopefully succeeded) printing the kosselblend.stl file from the Google drive. I'm trying to print some spare parts, and this is the only STL file I've been completely unable to print.
See the attached screenshots. First, the object comes in what looks to be to be upside down...it would need tons of support material to print and even then it doesn't look feasible. I've tried rotating it 180 degrees on the y-axis, which gets it into an orientation that appears more logical for printing but, either way, the g-code is only coming up for part of the object to print. It's as if the main body of the object is below the surface of the print bed and only the code to print the "exposed" portions is being generated by Slic3r. This happens whether I rotate the object or not. I'm also getting a warning from Slic3r that says "Warning: The input file contains a hole near edge 7.075377,-2.733208,16.049738-7.086314,-2.650162,16.049938 (not manifold). You might want to repair it and retry, or to check the resulting G-code before printing anyway.", but I have no idea what that means or what to do about it. I've even tried shifting the object to float above the print surface to try to trick it into generating the right code without any change in results.
Every other STL file I've tried from any source has had the G-code visualization (and resulting print) look like the object in the Object Placement screen. I have tried printing this a few times, and it does follow the G-code visualization (until I stop it).
Thanks,
Olivier
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 08:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 08:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 19, 2015 10:58PM |
juicev85
Just ordered one of these a couple days ago, I am really excited to catch up to all you guys! I noticed that some people were complaining about the heated bed not heating up fast or high enough... could this be partially caused because there is no insulation on the back? When I get my kit in I am planning on gluing a piece of 3mm cork rubber gasket material to the back. This is a common recommendation for these types of heaters.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2015 09:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2015 03:40PM |
putnam777
Apologies for the double-post...
I haven't gotten the autolevel to work with Marlin FW at all. When I was using the Repetier FW, it worked fine, yet it didn't print nearly as well as the Marlin FW does. When I enter the G29 code, the steppers go nuts and the head swings wildly. It clearly isn't working properly... I've changed the grid size from 20 to 0 in the config.h file, yet I'm still having the same issue.
What gives?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2015 05:32PM |
It does have voltage adjustment, but it's still nothing comparable to other heatbeds. Say at 12volts with 2.2ohms, you're getting 65 watts of power. Bumping the voltage to 14 will only get you 90 watts. Other heatbeds are rated at 1ohm, which gives you 144 watts at 12 volts.Quote
juicev85
Does the included power supply have a voltage adjustment on it? The RAMPS board and MEGA should be fine up to 14V. If you could bump up the voltage it would help with the higher resistance...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2015 06:14PM |
