Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2015 02:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2015 06:32PM |
jculver09
This sounds very interesting greggo, any chance you could post up a couple pictures.
@3D52
I ordered my kit the first week in March. Before I did I asked about pulleys and they said it would come with 36 tooth, and that the change to 20 tooth had not happened yet (I think they are going to deplete their inventory before they change).
The correct width is 7mm for these pulleys.
EDIT: For those of you looking at ordering, seriously consider the expedited shipping. In hindsight I wish I would have picked a faster shipping.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 26, 2015 04:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 26, 2015 05:29PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 12:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 12:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 12:54AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 10:31AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 08:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2015 11:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 12:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 01:16AM |
vorpal
The manual currently states 230mm for the Diagonal rod assembly. I have seen various other recommened lengths thoughout the forum. Does someone know if there is there a formula for this dependant on the frame size?
Also is the 700mm height really requied? there seems to be a fair bit of space above the endstops not being utilised.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 02:42PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 03:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 04:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 05:59PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 08:18PM |
mmcginnis9272
vorpal
That extra space above the endstope gets used when you install 250mm diag rods. I get 200mm Diameter by 245mm height build with these. In reality, the 245mm height is only in the center of the bed as when you get towards the top, the build area becomes more cone shaped, as it is with all lenghts of rods. Along the edges of the build area, my build height is about 205 mm.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 08:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2015 11:02PM |
vorpal
mmcginnis9272
vorpal
Is it the total length you have at 250mm or just the carbon rod itself? Are the rails raised an additional 20mm to compensate for the additional length?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2015 12:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2015 05:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2015 06:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2015 06:20PM |
Flish
Hi, I'm new to 3D printing, this will be my first printer can't wait for it to get here!
I ordered my Kossel from Folger tech on March 10... I emailed on about the 25th and by the 27th they emailed me back and said that -they received the wrong T nuts - and that there was 16 orders in front of me -and my order should ship by the end of next week (today is the 1st day of the week -so end of this week I guess) just a headsupdate for those of you also waiting...
Also, I was planning on building this "stock" like it was intended in the build guide... but I'm concerned about the carbon fiber rods... - I like that they leave you the option of the rod length by having you cut and assemble but, this thread seems to be the only resource I can find that mentions the rod length and build area... I need to have somewhat of a grasp of hows and whys of the rods to build area ratio or I wont be able to cut my rods happily...
the link to the spreadsheet posted by rtideas was 'page not found' for me... Does anybody have this link or some more insight into the push rod dimensions?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 08:37AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 08:53AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 09:01AM |
kirkm
Got my kit in the mail yesterday evening and everything looks in order.
After sorting out the hardware bag my son and I started the build using the V2 instructions on the google drive site. For putting the base together (stepper and base extrusion assembly), 8MM length screws are called for. However, there are only 30 8MM screws in the hardware bag per the inventory list, The base alone uses 36 screws. Looks like the 10mm screws which there are 90 screws would work. I dont see 10mm screws called out in the instructions . The big question is there places later in the build where only 8MM screws will fit?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 11:53AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 12:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 31, 2015 03:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 02:06PM |
