Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 02:26PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 02:29PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 03:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 03:44PM |
ADecker
Got my kit. No hardware kit. Not even crossed off on the check list. Kinda pissed. Send them an email (Kind) hopefully I get my hardware kit ASAP
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 03:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 05:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2015 08:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 02, 2015 02:15AM |
kirkm
I found out the hard way what the 8mm screws should be used for. I used several for the base and now I am short.
Make sure you save the 8mm screws for mounting the rails, which you need 27 of them. 10mm ones are too long to mount the rails and your rails will not tighten.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 02, 2015 05:07AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 02, 2015 06:30AM |
Two out of three rails on mine were rough. I used WD-40 and soaked the snot out of them and ran them back and forth several times. Then soaked them again. After 5 or 6 soakings and constant running them back and forth theyn got real smooth. I then let them dry and lubed them with a few drops of 5W-40 Diesel oil. They have been smooth as butter for over 2 months now. The chinese are not good at cleaning up after themselves, it would appear.Quote
vorpal
Ive started to build as well. Also used all of the 8mm for the base as per instructions. Have alot of 10mm two types of heads. but a thought would be to uses washers to space if needed, or drill through profile into center cavity.
One of my rails is very rough running, tried grease not helping. I have heard some cheap rails have missing balls, maybe the case here. The words "You get get what you pay for" are starting to come to mind.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 02, 2015 06:38AM |
3D52
Is the LCD Controller worth buying, if so which one?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 02, 2015 08:03AM |
Either works fine with Reptier firmware--not certain with Marlin. The graphic one seems to be a little snappier for me.Quote
3D52
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2015 05:48AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2015 10:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2015 10:16AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2015 10:49AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2015 11:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 04, 2015 11:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 04, 2015 05:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 04, 2015 06:20PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 04, 2015 08:38PM |
gfrantz
greggo,
I have no idea if this is what's wrong or not, but AFTER you flash the firmware, manually send a M502 and then M500. That will force your newly updated firmware to load. I fought a similar problem on one of my machines for nearly a month before I found a hint that this might be my problem. It was!
Use whichever control program you use (I use Pronterface and Repetier Host). From the manual entry line, just enter each of those commands and see what the results are from each.
This is assuming that you have turned on the EEPROM in the firmware. It certainly bit me.
Gary
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 05, 2015 02:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 05, 2015 08:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 11:41AM |
jculver09
Be careful with those values it caused my machine to skip belts and go to points off the print bed. It seems that these represent the difference between the nozzle and the point where the z probe measures. So it may work for some if your end effector orientation is the same. Not sure I am new to the gcode and software stuff.
The x and y settings that came with the firmware worked for me, z is setup during configuration.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 11:53AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 12:14PM |
juicev85
jculver09
What I did to find those values: I marked the 0,0 point where the nozzle touched the bed, then I deployed the probe, then I moved the probe until the switch was on my mark and I noted the X and Y values. Then you must invert those values...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 12:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 12:49PM |
ADecker
Got my printer built and just got it calibrated.
Kit was missing the hardware -- Got that in the mail.
Kit is missing one of the top 3D printed pieces -- I took the bearings that I had left and put them on a bolt, used a TNut and attached them to the top of the vertical support, should allow me enough time to print the corner piece.
Heated bed doesn't work, going to check the solder joints and the polarity, maybe I screwed up??
Everything else went together well, have not attached the Z Probe yet, going to do that next.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 01:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 01:28PM |
