Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 02:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 04:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 06:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 07:20PM |
Djkingsley
I received my delta kit from Folger today, ordered on March 10 so almost 30 days including shipping.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 10:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 06, 2015 11:55PM |
SnapFracturePop
What speeds are you seeing on these, and what reliability once you get them up & running?
Thanks,
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 12:16AM |
jculver09
--I bent up two of the teeny tiny molex connectors trying to crimp them with pliers and all I had to use in place was the piezo speaker connector out of my computer, soldering is easier anyways.
--I made the rods 250mm and put the rails all the way up as high as I could, and now the effector will not reach the entire build plate. I get a 160mm circle at the plate but about 4cm up it is much larger. Tomorrow I will be moving the rails back down a little so that I can use the entire build plate.
--Two of my glue joints on the rods broke this morning because one of the rails began binding very very badly. The x axis linear bearing would catch and stick in place so the belt jumped teeth on the pulley and messed up the print. I read a comment here about using copious amounts of wd40 to de-gunk the rails then I used motor oil in an eye dropper to lightly oil the bearings and rails. They are now much smoother and have not had the issue repeat. Only time will tell the interval I need to repeat this on, planning on doing it weekly or before I start any really long or important prints.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 04:06AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 07:44AM |
jculver09
There is a calculator posted earlier in this thread (posted by vorpal on page 13). I dont think it is 100% perfect for predicting the outcome, but at first glance it seems to be close. I planned on measuring my current setup, checking it against the calculator, and using the difference I find to give me an improvement on the calculators prediction to determine if it is worth it to do the upgraded length.
As I understand it, the longer the rods the wider the diameter of your usable area on the build plate (assuming your rails and lower stops are low enough to allow it). However, the longer your rods are the more useful area is lost at the top and upper sides.
I think of the usable volume as somewhat egg shaped with the egg standing up on the rounder end and the point straight up. The longer the rods, the shorter and fatter it will be the shorter the rods the taller and narrower. One thing to keep in mind, no matter the length of your rods, accuracy decreases near the edges so building well within the available dimensions is a good idea.
Part of the reason I want longer rods is because I intend to eliminate the linear bearings in favor of running delrin wheels on the extrusion using new carriages. Doing this will move the axis on which the carriage moves vertically out a couple cm and partially take up that extra 38mm rod length vs. what I have now. And in the extreme future I could always purcahse the extrusions to make the side rails 360mm and with the 288mm rods I would be able to utilize a much larger build volume then I can currently
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 10:56AM |
mmcginnis9272
I instead found some magnetic effector and rail mounts on Thingiverse and modified them to acccept Haydn's ball mounts. I uploaded my modified parts to thingiverse here: [www.thingiverse.com]
I initially setup everything this way with his 288mm rods. This ended up not working very good as my effector now could reach 2 to 3 inches outside my build plate, included easily smacking my power supply. In addition to this, my build height was reduced drastically.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 11:17AM |
thevisad
mmcginnis9272
Awesome, thanks! I will look over those, the magnets I bought look like a flat disc with a angled hole in the middle to accept the ball, so a little different then your design. They look more like the original then some of the other parts on the site.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 11:42AM |
mmcginnis9272
thevisad
mmcginnis9272
Yeah, the problem with those is that the ball is in direct contact with the donut magnet which caused a lot of friction. Besides stressing the system from the friction, the chrome coating on the magnets will not last long. Haydn's design creates a fraction of a millimeter spacing between the magnet and ball, and the ball rids in the plastic cup on the end of the rod.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 12:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 12:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 01:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 01:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 01:47PM |
cman8
Just spread out my parts. Looks to be complete. I did get the 36 tooth not the 20 tooth. Do you guys suggest I order the 20 tooth instead? Also what are most of you cutting your rods at? I know a lot of people have been saying the length on the manual is no good. Is this the case?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 01:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 04:19PM |
thevisad
How does your's hold up under high speed printing?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 04:39PM |
jculver09
Thank you mmcginnis. This answers just about every question I had about setting these up.
The geometry of the effector and carriages is what I think the calculator I mentioned is missing.
So you would recommend I order 200mm long rods (I am assuming this is still measured center to center on the balls). I may order them from him or make them myself because he has a 3 week lead time, it looks like when you shortened the rods you still used the ends he provided, I was thinking these would be glued in is this not the case?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 04:51PM |
cman8
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 07:17PM |
mmcginnis9272
cman8
It is really up to you to decide but I recommend the 20T pulleys as they give more resolution at the expense of slower printing. The 36 tooth ones will give you the opposite. Also, 36T cause your motors to be more likely to skip than does the 20T. If you run 36T, you will want to increase your motor voltage to provide more power to overcome the skipping, causing them to run hotter. Without heat sinks and/or fans, you then run the risk of the PLA motor mounts melting. I personally use 20T pulleys, run a higher voltage to my motors, and have heat sinks and cooling fans. I am probably overly concerned about skipping than I need to be, but that being said, I have not had a single motor skip in over 4 spools of filament since I set it up this way.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 08:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 08:50PM |
3D52
mmcginnis9272
cman8
It's a shame these machines can't print HDPE. It's very stout and the steppers wont melt it, My CNC Machine has HDPE motor mounts and my Nema 23's get pretty hot, hot enough you can't hold your hand on them.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 09:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 09:33PM |
Vanbot
I had the same experience with Folger. I ordered mine on March 9 and still haven't got it. I did complain, politely, to Danny at Folger and got lots of apologies and excuses. I'm sure they're busy but they really shouldn't be telling people they ship in ten days. The delays are much longer and they know it and they just don't tell anyone because they don't want to lose orders.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2015 11:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 01:20AM |
mmcginnis9272
Haydn only sells rods in 288mm lengths. I asked him for shorter ones and he said he only has one jig that is set for 288mm.
If his lead time is three weeks, this is new, as he shipped mine out the next day.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 08:58AM |
3D52
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 08:59AM |
jculver09
mmcginnis9272
Emailed him yesterday about this and he said that custom lengths are available up to 490mm, but they're more expensive.
I also found out the lead time is because he is waiting for a new batch of studs from the manufacturer.
