Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 10:58AM |
mmcginnis9272
jculver09
mmcginnis9272
Haydn only sells rods in 288mm lengths. I asked him for shorter ones and he said he only has one jig that is set for 288mm.
If his lead time is three weeks, this is new, as he shipped mine out the next day.
Emailed him yesterday about this and he said that custom lengths are available up to 490mm, but they're more expensive.
I also found out the lead time is because he is waiting for a new batch of studs from the manufacturer.
That explains it. He must have decided start making custom lengths recently as well. Cool.
gowen
Day 6
I have finished off the extruder. getting the pipe fitting to bite took some effort.
[attachment 50286 IMG_20150302_132533.jpg]
The effector and hot end assembly went ok, especially once I found MrOrange26's picture back on Page 16 and Andy's on Page 14. I'm not sure about running the wires up beside the E3D It looks like it is stretching the heater wires at the bend. Should I have routed them under the effector plate and then up?
[attachment 50287 IMG_20150302_133002.jpg] [attachment 50288 IMG_20150302_140156.jpg] [attachment 50289 IMG_20150302_140231.jpg]
I opted to attach the fan with zip ties rather than CA. By putting them in backwards, I was able to use the ratchet block as a stand off to keep the fan near vertical.
[attachment 50290 IMG_20150302_140305.jpg]
I got the hole drilled to pass the extruder wiring from outside to inside. Tomorrow I plan to do the full frame mechanical assembly. Are there any cable runs that I need to do first?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 11:00AM |
Koenig
mmcginnis9272
jculver09
mmcginnis9272
Just ordered a set of 250mm rods from him!
And I haven't even received my Kossel from Folger tech yet...
Already have a few mods in mind, these rods, a proximity sensor for the autocalibrating plus 16 tooth pulleys (better accuracy with Haydn's rods).
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 11:10AM |
thevisad
Koenig
mmcginnis9272
jculver09
mmcginnis9272
I am upgrading to an prox sensor as well I believe, this way I can eliminate the mechanical part. One thing I have noticed is the steppers are blindingly hot, might want to consider adding a fan shroud to your upgrades.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 11:33AM |
Koenig
You have 16 tooth pulleys?
I was sort of thinking, since you use less torque (I think like 25% less torque) with 16 tooth the temp would stay about the same, losing some speed though.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 12:02PM |
thevisad
Koenig
I currently have 20 tooth pulley, I am considering moving to 16 tooth for the better precision. I am beginning to think I have an issue with the RAMPS, since I powered the board last night and the motors got hot just sitting there holding the effector in place. They are set to the 0.35mv which is stated in the manual to use. I have been reading that's a bit low as these chinese clones are supposed to need +1mv, I guess. It has also burned out two servo motors now, I bought one at a RC store last night, threw it on to replace the old one and after 10 minutes it stopped working. At the 23 minute mark in this video you can see what the servo is doing (http://www.twitch.tv/thevisad/b/647284258) This starts immediately after sending power to the hothead, rattling back and forth. I have double and triple checked all the wiring and plugs. The servo works, it goes up, it goes down, this one is the Hitec h5-55 instead of the TowerPro SG90. Each time it does this "jump" the LCD panel dims, causing a flashing to occur. At some point the powersupply decides it has had enough and powers the entire unit off, terminating the USB connection to the machine as well. Removing the servo eliminates the issue completely, Folger sent me a replacement for the that burned out in the kit, but this has now burned out a second one so I will not that on until I test. I have a second RAMPS spare and will test with that later tonight.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 03:20PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 03:44PM |
thevisad
Hmmm, did I underpower the servo then, burning it out? I will remove that jumper and add a step down power supply to the line and power it that way. Thanks for that tip, that will save me some headaches.
I am adding fan mounts and already have the 3 fans set aside for it. I found a nice fan cap that will slide right over the top of the motors, but I think I might redo the motor mounts to include some directional jets to vent the air out the side of the channels. I am wiring those directly up to the 12v rail so they come on when the power supply does. This way I can eliminate any of the heat associated, plus I can play with a secondary arduino and some led's.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 03:57PM |
mmcginnis9272
The concensus in the R/C modeling world (of which I am a part) seems to be the when a servo motor is underpowered it causes a momentary brown out in the servo circuit board. Not enough power on hand causes the voltage to drop in the circuit. This causes the servo circuit to shut down. When the power to the coils in the motor stop all at once, a backwards EMF (voltage spike) of many times the applied voltage occurs. Once the circuit detects the proper voltage again, it starts back up and applies voltage again to the motor, only to shut down all over again. Normally the circuit can handle the normal occuring spikes that occur when voltage is removed from the motor coils under normal shutdown, but during this brown out phenomenon the system switches on and off many times a second. This causes several spikes per second back into the protection circuit causing it to fail. I remember as a teenager in shop/electronic class how we use to wire up coils from the lawn mower engines so that some unsuspecting victim would get the "you know what" shocked out of them when we found creative ways to cause them to absorb the collapsing voltage spike. This is the same priniple that those gimicked shocking cigarette lighters and ball point pens and such work off of. Seems strange that underpower something can actually burn out a board, but the magic of electronics theory proves it can and does happen.
Kinda sounds like you are a typical guy like I am. You should get some of those really loud cooling fans from a rack mount server that sound like a jet taking off. If you can find a way to make it work better and make it louder in the process all the better. Just like our cars.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 04:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 04:35PM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 05:47PM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 06:20PM |
mmcginnis9272
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 10:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2015 11:15PM |
thevisad
Ok, makes less and less sense. I pulled a 12v to a step down to 5v and put that to the RAMPS 5v rail. The servo powers up and the LCD panel doesn't show that flickering. However, as soon as I turn on the hothead, it immediately starts the twitching again. I tested the voltage coming out of the line and it is 4.94 volts on the 5v at the servo and the signal (?) line is running 0.14 volts regardless of it being on or off.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 12:04AM |
mmcginnis9272
thevisad
You do see a small voltage on the signal line when it is disconnected. I never looked to see where is bleeds in from. You shoud test the 5v line when the hot end kicks on as 5V is easy to obtain with no load. What exactly did you use to frop the 12v line to 5v? You might try an external 5v supply, completly separate from the printer power supply. As 3D52 daid, a UBEC is the best, but I doubt you have one of those on hand as they are pretty much am R/C gizmo. Do you have a 5v USB charger that outputs as least 1A? You can butcher an extra USB cable to use for powering this line so you don't have to dedicate the charger to the printer.
You might also, just for grins, temporarily unplug your LCD and see how it works. You might have a weak RAMPS board as it does supply the 5V line that powers the MEGA processor. It is possible the extra load from the servo twitching for an extended time may have done a number on the RAMPS 5v supply. If this is the case, RAMPS boards are like $15.00 or less from a USA supplier on eBay.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 07:01AM |
thevisad
mmcginnis9272
thevisad
I am using a adjustable buck power regulator, LM2596 dialed down to 5.1 volts, I popped it up to 5.35 volts. At that range it can handle 2 amps stable. I popped off the LCD screen for a while and did some testing and it is still doing it with that off. I have extra RAMPS boards, drivers and duinos laying about with a few more coming in. I have decided I want to eliminate the entire servo/button approach and move to a prox sensor of some form. I have several different sensors on hand and it could mount out of the way if it works properly. It's small and unobtrusive so it will work.
I just eliminated the RAMPS 5v rail as the issue, I powered the servo off the buck converter directly. As soon as I triggered the hothead the servo started jumping. It honestly looks like it is jumping in time to the LED blinking on the RAMPS while heating the bed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 09:59AM |
mmcginnis9272
As far as the prox sensor.... I've wondered about these as I have no experiance with them: Do they trigger at a precise enough distance to accuratly calibrate bed height? I didn;t know they were that precise.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 10:18AM |
mmcginnis9272
We are dealing with a known good servo right now, correct?
If the servo jitters with good clean 5v supplied to it from externally, then the issue has to be either a bad servo or a signal failure from the arduino/RAMPS combination on servo signal D11. The signal simply passes through the RAMPS board from the Arduino directly to the servo lines D4 D5 D6 and D11. This would indicate the Arduino is loosing power and it gets that power from the RAMPS board.
Does the hotend come on and communication stays open to the arduino with the servo removed? If so, what if you add back in just the LCD?
It might still be a weakened RAMPS or, one of your main power supply 12v legs might be weak, as that ultimatly generates the power for the RAMPS to convert to 5v.
Check your 12v from the power supply when the servo jitters to see if both 12v legs stay level at 12v. I doubt this is the problem.
Or bet yet, do what you said and scrap the servo. I personally use the original bouncing hex key method with good success
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 10:22AM |
Koenig
mmcginnis9272
They might not fit this purpose, it seems that the object that is to be sensed have to be very dense, aluminium might not do it....
[forums.reprap.org]
EDIT: But then again, some have tried and succeded: [groups.google.com]
Small video of it in action: [youtu.be]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 11:07AM |
thevisad
I think they identified an issue with it detecting glass though?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 11:18AM |
Koenig
thevisad
Seems so, but appears to be fixed by putting aluminium-foil underneath the glass.
Overall there seems to be some issues, but the sensors are not very expensive so I might end up giving it a try anyway. (I have yet to assemble my printer, have not arrived as of now - ordered march 6th, they sent it april 2nd)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 11:35AM |
thevisad
Koenig
thevisad
I picked up the following three sensors (IR ones) 2-10 digital : 0.5 - 5 digital : 2 - 15 analog
The one that I have seen (in addition to the one you linked and as an upgrade to that one in particular) is the Fotek PS-15N, I am ordering a couple of those today and hope to have those in early next week. These are just massive compared to everything else.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 02:40PM |
Koenig
Impressive!
Might one ask where you are ordering from?
EDIT: Quite big and sort of real heavy... 126g...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 11:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2015 11:37PM |
ADecker
Extruder motor skipps a bunch and doesn't extrude..itll be fine for a few seconds to a minute then skip skip skip skip fine fine fine skip fine. up the voltage to as high as I date (~.9V) and same story, took apart the gear housing and flipped the gear around (maybe its the teeth) still no dice. Thinking its my hotend or something at this point. got an e3d v6 in the mail hopefully here tomorrow and I can see if its the motor or my hot end.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 03:33PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 04:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 05:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 05:39PM |
Deguello
I finally got my Folger Kossel printing after a couple of hiccups. The first was the M4 T-nuts, then trying to find the red and black Z-probe wire mentioned in the build manual (kit had 4 lengths of gray cable for both Z-probe and fan - had to mark one of them with a Sharpie), then when it was all together I gave it G28 and watched X and Z move up to the stops while Y went down.
The first troubleshooting step was to swap X and Y (both steppers and endstops). The problem moved to X. Then I swapped Y and Z. The problem moved to Z. Pretty sure that's a RAMPS problem.
I sent a detailed email including all of the troubleshooting steps, and got back "check the endstops". After several rounds of John not reading the email for content, he finally said "Looks like you have a bad RAMPS or Mega. I'll send you a new set."
In the meantime I moved the Y stepper to the E1 position, modified the firmware accordingly, and went about my business.
Yesterday I finally got ABS printing fairly well, but it took quite a while to get the bed hot enough, so I put a couple of layers of cardboard between the bed and the Arduino. Kicked off a new print. Watched the bed heat up (a bit quicker), then it ran autolevel, then started heating the hotend. About that time pronterface lost communication.
After watching it crash every time the hotend started heating, I decided I must have fried either the Arduino or the RAMPS. I had the new set from Folger, so I swapped first the Arduino, then the RAMPS. Same problem every time.
Then I remembered what I tell my students when I teach hardware and software troubleshooting: "Only make ONE change at a time." The last thing I did before it started crashing was to add autolevel to my startup G-code. I realized that the crash was occuring at the end of autolevel (sometimes just before it finished), not the start of hotend heating. Commenting out autolevel got it back in operation.
From reading this thread I realize that running the servo at the same time as the heaters is probably playing havoc with the bus voltages. When this print finishes I'll try running autolevel before the heaters. If that doesn't work I'll put springs under the bed and adjust it manually. The main reason I want autolevel is to compensate for the AquaNet glass I use for ABS.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 05:40PM |
Flish
Well, after a couple times bitching and 30 days later my kit has arrived!...
I'm still building but I think I received all the parts and my box didn't seem too beat up. Everything is packaged and labeled real well but, the mixed bag of hardware (screws nuts washers...) can lead to trouble unless you take the time to sort the fasteners beforehand...
It was mentioned before a few pages back but, if you follow the Googledrive build manual, it tells you to use M3 8mm screws to assemble the corners.This step should all be done with M3 10mm screws not8mm. 8mm will work but it seems they dont supply you enough. Most of the 8mm screws are for mounting the 3 linear slides.
I put all my corners and extrusion together with 8mm -only to remember reading about the slides after the fact.
Working with the corners and screwing from the inside has got to be the most tedious part of this build -you don't want to do this twice ...trust me. I only had the option to swap out the screws because these are hard to find locally. M4 seems the smallest available, at least at my local hardwares.
*A 2.5mm ball end Allen/Hex wrench is a must for these corners.*
