Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 06:11PM |
thevisad
This is the same exact thing I have an issue with. It is the servo motor causing the issue, drawing too much power and crashing the ramps machine.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 10, 2015 10:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 11, 2015 01:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 11, 2015 07:54PM |
rotten_carrot
Finally we have lift-off - atleast in a postal sense. Placed my order on the 23rd March through ebay. To my surprise, Shipping notice issued on the 8th April and would you believe it today it's on the move..........
Just thought that I would share my ordering timescale incase it's helpful to someone
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 12, 2015 07:42PM |
3D52
rotten_carrot
Ordered mine on the 18th March, got my shipping notice on the 8th of April and mine was on the move yesterday, should have it Monday morning,hope everything is in the box.....
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 07:12AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 08:45AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 08:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 09:22AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 09:49AM |
Deguello
thevisad
In my case it's not a matter of drawing too much power, but the arm hitting the end effector and not able to complete the motion. I mounted my servo so it stores alongside the hotend rather than sticking out the back. I had to adjust the X and Y in Z_PROBE_OFFSET accordingly.
Deguello
. Kicked off a new print. Watched the bed heat up (a bit quicker), then it ran autolevel, then started heating the hotend. About that time pronterface lost communication.
After watching it crash every time the hotend started heating, I decided I must have fried either the Arduino or the RAMPS. I had the new set from Folger, so I swapped first the Arduino, then the RAMPS. Same problem every time./quote]
Actually, this is the same exact problem. I have sorted it out already, but glad your issue is different
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 10:27AM |
vorpal
Thought id give some feed back on my build.
The printer arrived all parts included except for the extra 10mm screws as mentioned though didnt pose a problem. There are difference between the pdf manual and the online video ie; the direction stepper motors are wired, the probe arm, etc
The extruder need a bit more voltage as mentioned in earlier posts, deffinately calibrate your stepper drivers mine were all about .65mv by default(no heating problems for me). Also the extruder was slipping which was a result of the gear not being tight enough on the shaft, eluded me as not very noticable at first. Also honed the extruder injected housing to give plenty of room for gear as it was rubbing.
I didnt have alot of success with the auto calibration, to many variations in the results i think there is to much slack in the server arm. Also switched to a version of marlin that supports the m666 m665 command [github.com] with better success , though still not accurate enough. ( for me)
Added springs between bed and frame to give more granular calibration and followed this guide: [www.youtube.com]
After doing manual calibration not only did I gain valuable knowledge but have had excellent results. dosnt take long and far greater accuracy than auto leveling.(for me)
Glue stick has been giving good result for first layer adhesion.
I should mention that one of the rails was running rough, followed and earlier suggestion and cleaned with wd40, then cleaned and applied white lithium grease to rails so far no problems.
After a long wait due to delays, I was knocking out prints a couple days after arrival. all in all pretty happy.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 11:00AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 11:05AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 11:28AM |
vexon
I cant get anywhere close to X – 0.350V closest I can get is like 0.003v
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 12:05PM |
vexon
no i dont, i honestly feel like redoing all of the underbelly and putting the board in a seperate case.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 13, 2015 12:14PM |
vexon
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 01:01AM |
vorpal
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 07:30AM |
jculver09
vorpal
I tried to convert to the RC Marlin as well. Got it almsot all the way there, switches all worked, and it would home fine. When I run the G30 A D250.0 command to autocalibrate it would probe and probe and probe and after about 2 minutes it times out saying it is aborted because my Z endstops were too far apart (listing values of -17.xx, -17.xx, and 25.xx). I went to start a test print and it drove the effector down into the bed on the 2nd probe point, as if it thought the bed were tilted at something like a 45 degree angle, luckily no damage as the arm slipped on the servo gear, and I had put cardboard over my bed to protect it.
This is where I stopped because it was 4am and I needed to sleep, did you run into this issue? Would you care to share your config.h so I can take a shot and see what happens because I am sure I missed something somewhere as I am still new to arduinos and programming.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 01:53PM |
jculver09
vorpal
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 09:25PM |
thevisad
jculver09
vorpal
That seems really weird and makes me think things are wired up wrong. I would check your wiring and by that I do not mean just your wiring runs, but the pins at the plugs. Possibly one of them got inserted wrong.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 09:29PM |
jculver09
thevisad
jculver09
vorpal
It is definitely the firmware, because I can re-upload the original marlin provided and it works just fine. I was just tinkering with this newer version because I was not happy with autocalibration results either. I know my bed is not perfectly flat and I can see in the first layer where it is incorrectly interpolating and leaving some spots too high, or making some so low the nozzle scuffs the surface of my blue tape. This is really only apparent when I set my layer height to .1mm which I rarely use because of how slow the prints are.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 14, 2015 10:27PM |
thevisad
Also, found that there are known issues with the A4988 drivers they are using that are causing skipped steps. I am investigating this right now and a solution to this problem that should cause ultra smooth prints. Add this to the Simplify3d Upgrade I did yesterday and I am hoping the print quality will go through the roof.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 01:46AM |
mmcginnis9272
thevisad
Care to speak more about your problem and possible solution to this? I personally have never noticed skipped steps since I run my motor currenst high with heat sinks and fans.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 07:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 08:34PM |
vexon
Hey guys,
So i accidently Juiced my setup ( i ruined the ramps board through missadventure )
does this look like a decent price to replace the parts?
[www.amazon.ca]
I understand that i might not need to replace everything but i want the extra parts for future use in case they do work.
edit: cant communicate with arduino either : <
Edit 2 : folger sells it for 50 ish (american so the exchange will do me harm )
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 08:45PM |
thevisad
vexon
Hey guys,
[www.amazon.ca]
If you can deal with waiting 2-3 weeks to save 30ish then buy these. I paid 25.16 for the last set from these guys and have ordered dozens of things from them.
Ramps 1.4
Mega 2560
a4988 Drivers
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 09:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2015 09:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 04:52AM |
