Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 02:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 05:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 06:01PM |
NeckBon3
Ok i went through and calibrated my printer, going by the instruction Folger tech provided and it said i can now slice and print. So i got a test file to print, hit print and nothing happening, the extruder and hotbed got to temp and its not printing anything. Anyone know whats going on?? Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 06:36PM |
thevisad
NeckBon3
Debug communications and you will see something is most likely amiss and it's telling you whats happening. There is a 10 second count down prior to the print occurring that you will see in the window with debug on. My slicer would drop the temp to 230 from 235 during the auto level and then refuse to spin the temp back up to 235, which is what I wanted to extrude at. The printer would sit there for 5-10 minutes then suddenly decide to heat up the tip and print. One of the reasons I switched to Simplify3d.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 06:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 06:47PM |
NeckBon3
thevisad
NeckBon3
Ok my extruder is working. So now when I click on print nothing in moving, not sure what to do. FYI this is my first 3D printer and im still very new at all this.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 08:26PM |
thevisad
NeckBon3
thevisad
NeckBon3
Two things to look for, you should be able to manually extrude some filament by pushing with your fingers. If not, then check your path and make sure to straighten the filament as it exits the tubing into the effector. Second, at the back of the stepper where the extruder (black box) gears are, see if its turning against the filament. It is the cheapest extruder available and fails very quickly with the bearings they provide.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 10:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 12:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 09:50AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 08:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 08:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 10:29PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 10:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 19, 2015 10:49PM |
Plasticmonkey
I had that problem and posted it on here ... I increased the extruder stepper to .85 and solved the need to 'manually feed'. I also got this on ebay which added further improvement and easier maintenance..
[www.ebay.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 09:22AM |
You probably have a gritty linear rail. The rail grabs, the stepper slips, and the software thinks it's lower or higher than it actually is. Eventually it runs into the stop.Quote
NeckBon3
So my X axis is going into crazy left field when I try and print, it'll go all the way down to the end stop and you can hear it wants to keep going. How do I go about fixing this?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 10:14AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 10:27AM |
Mine delaminated when I drove in the screw. I welded it back together with a soldering iron and intend to print a new one. When it breaks again...Quote
Koenig
When I got to assemble the effector one of the "towers" that you snap in the servo between fell off...
Jam a small flat blade screwdriver next to the nut to hold it in place while you tighten the screw.Quote
Koenig
...never got to feel like it was "tight" at all.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 12:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 12:04PM |
Deguello
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 01:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 02:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 04:56PM |
fuerst1
Ordered mine on March 27th and received it Friday April 18th. Some of the 3D printed parts had fit issues and I was missing half a dozen t-nuts. Most of the screw holes were too small, the 2020 aluminum rods had to be "persuaded" into the slots and the hot end didn't fit into the effector plate.
I've finally got it running but the extruder motor keeps skipping. Is the solution just to increase the motor current? Right now I have the Vref at about 0.4V. Should I go higher?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 20, 2015 10:25PM |
Flish
Did anybody order the 20x04 LCD screen/SD reader, and or have a problem with it?
I tried to hook up my lcd screen and couldnt get it to work...
After messing around with the firmware for like days I discovered the plug in connectors on the adapter board, that plugs into the ramps -were soldered in upsidedown.
As I was about to de-solder then resolder them the correct way, I realized I could just uncrimp the cable ends and flip them around... and I did and it worked... but seriously, if it's not one thing it's another.
NeckBon3
Has anyone tried springs under the bed? Instead of the acrylic spacer they give you. In thought all you have to do is tighten and loosen to adjust the print bed
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 21, 2015 09:03AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 21, 2015 10:16AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 21, 2015 12:06PM |
mmcginnis9272
Djkingsley
I got the STL file off thingiverse and I am going to use a modification of these feet to lift my printer up to increase the air flow.
[attachment 53288 foot.jpg]
I'm happy to see someone likes me feet!!!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 21, 2015 12:45PM |
