Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 11:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 01:10PM |
Deguello
I drilled another hole in the acrylic and turned the RAMPS 90 degrees. Secured the long screws to the acrylic with locknuts, then added acrylic washers under the RAMPS.Quote
gaddcasey1
How are people mounting the ramps? If i follow the instructions i cant use the usb port.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 03:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 04:11PM |
What values do you have for Z_PROBE_OFFSET in configuration.h?Quote
gaddcasey1
after auto level the printer starts 10mm above bed, how do I fix?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 09:08PM |
Deguello
gaddcasey1
In mine:
#define Z_PROBE_OFFSET {-29.35, 18, -2.8, 0}
-29.5 means the probe is 29.5mm to the left of the hotend
18 means it's 18mm behind the hotend (toward the Z tower)
-2.8 means the probe is 2.8mm lower than the hotend
All of these numbers are when the probe is deployed with M280 P0 S5.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 09:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 09:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 22, 2015 09:52PM |
Assuming your Z max is set so that a piece of paper just drags at Z0:Quote
gaddcasey1
Is there any way to probe an exact point to test my measurements?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 23, 2015 04:07AM |
Deguello
gaddcasey1
G1 F4000 X0Y0Z10 ; stop 10mm above the bed
M280 P0 S5 ; deploy the probe
Use the -Z button in Pronterface (or whatever you use) to lower a little at a time, alternating with M119 to show the endstop states.
SENDING:M119
Reporting endstop status
x_max: TRIGGERED
y_max: TRIGGERED
z_min: open
z_max: TRIGGERED
When the probe gets close, start lowering 0.1mm at a time until you see z_min: TRIGGERED. At that point issue M114 to report the current position. Make the Z value negative and put it in the 3rd position of Z_PROBE_OFFSET.
Next, make a pencil mark directly under the extruder, then jog X and Y until the probe switch is on your mark. Use M114 again to get those offsets. Just remember to negate the X value if your probe is to the left of the extruder, and negate the Y value if it is in front (away from the Z tower).
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 23, 2015 09:50AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 23, 2015 10:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 12:56AM |
Deguello
Run M503 and post the response.Quote
gaddcasey1
...10mm above the bed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 07:49AM |
rotten_carrot
Finally we have lift-off - atleast in a postal sense. Placed my order on the 23rd March through ebay. To my surprise, Shipping notice issued on the 8th April and would you believe it today it's on the move..........
Just thought that I would share my ordering timescale incase it's helpful to someone
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 09:25AM |
gaddcasey1
Deguello
gaddcasey1
SENDING:M503
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 11:43AM |
rotten_carrot
rotten_carrot
Arrived in the UK on the 14th April, customs clearance on the 16th and payment requested (works out as VAT plus an £8 handling fee) via a letter through my door on the 18th. Fees paid and happily delivered yesterday
Well, it was just like Christmas. So far screws sorted, bags opened, linear slides sniffed and a good time had all round. The box was in decent enough condition, considering its journey, on the outside but more more importantly was fine on the inside. Everything would appear to be there by my reckoning though two of the printed parts were not as good as the rest but I'm sure will still do the job (possibly I'm being over crytical).
Let the fun and frustration begin................................
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 11:47AM |
gaddcasey1
rotten_carrot
rotten_carrot
my printed parts where vary bad, spent hours sanding them so they would fit together.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 11:50AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 11:54AM |
Here's a good place to start: http://delta-calibration.s3-website-us-west-2.amazonaws.com/Quote
gaddcasey1
How do you properly correct kossel flatness? I can paper test the center but it will crash into the bed on the sides of the bed when i do a g1 y85xx.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 12:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 05:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 24, 2015 05:37PM |
3D52
When building my arms, I noticed that the ball joints were very stiff, which could possibly cause binding and miss steps, to solve this, take a pair of pliers and carefully squeeze the plastic all around the ball and it will free it up and make it smooth. I learned how to do this in my RC helicopter flying days, where binding is not an option....
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 25, 2015 01:46AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 25, 2015 09:08PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 25, 2015 10:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 26, 2015 11:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 26, 2015 11:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 08:59AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 09:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 10:10AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 01:23PM |
