Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 01:52PM |
gaddcasey1
I found the printed parts made from aluminium here at [www.robotdigg.com]. I ordered some and will post when they arrive. has anyone ordered these parts before?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 01:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 02:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 02:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 02:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 03:22PM |
Dan_FolgerTech
Deguello, we are going to be offering the aluminum corners for around $48 and shipped from the US. The ones I have right now are not anodized so they are just plain aluminum. If you want more info, shoot me an email or watch our website for the listing when I get the time to put them up!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 07:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 08:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 08:23PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 09:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 11:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 27, 2015 11:57PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 07:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 08:25AM |
bluesmike
EMailed customer support at Folger Tech yesterday and had a tracking number for the new PSU before end of day. But with my ATX power supply I took out of an old computer to use in the meantime the magic never happened.![]()
If I G28 to home, it homes fine. I loaded the Folgertech slic3r settings and sliced an stl and exported the gcode. Loaded the gcode file in pronterface and fired it off. I'll paste the first couple of lines of code below. Whenever I g29 (autolevel) near the end of the cycle it homes and slams against the stops and the motors keep going making the whole thing shudder and vibrate like crazy. After the autolevel cycle it does a move to center and pauses at X0 Y0 Z5 . Once the extruder is up to temp it moves to what appears to be X-76 Y-76 Z0 and crashes the print head. It ratchets the nozzle against the heatbed and pretends to be an engraver. If I let the print job continue at that point it tries to print like the print bed is on a 45 degree angle. And it never extrudes anything
A little help please....
Sample of the gcode Im sending to print:
G21 ; set units to millimeters
M190 S40 ; wait for bed temperature to be reached
M104 S210 ; set temperature
G28 ; home all axes
G1 Z15 F5000 ; move Z to 15mm height
M280 P0 S5 ; deploy servo
G29 ; perform auto level routine
M280 P0 S120 ; retract servo
G1 X0 Y0 Z5 F5000 ; Move to center
M109 S210 ; wait for temperature to be reached
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
M106 S255
G1 F2400.000 E-4.00000
G92 E0
G1 Z0.200 F6000.000
G1 X-37.575 Y19.901 F6000.000
G1 E4.00000 F2400.000
G1 X-42.826 Y9.987 E4.37313 F2400.000
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 09:33PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 09:42PM |
bluesmike
Following the steps here (http://delta-calibration.s3-website-us-west-2.amazonaws.com/) helped a ton! I tried a test print and ended up with a gunked up nozzle .I'm thinking the bed temp was too low (95) for the ABS I picked up at Microcenter. I've reset the temps to 110 for the bed and 245 for the extruder. Fingers crossed, its taking a LONG time to get the bed up to temp. Im not using Kapton or anything on the bed at this time. Aside from Kapton what else could I use?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 11:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2015 11:49PM |
bluesmike
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 03:19AM |
bluesmike
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 03:34AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 09:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 09:47AM |
bluesmike
Wow! A lot of great tips guys. Thanks for the quick replies! My print never happened, the bed wont heat above 96°. Im positive its the old ATX PSU that Im using. Its only a little 110Watt that I pulled from a parts bin. Once my replacement from Folger Tech gets in I'll be all set (I Hope!). In the meantime I'll spend a little more time researching other Hot Bed tips and tricks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:35AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:40AM |
Deguello
I was wondering about getting a 24 volt and found this one that can use either 24VDC or two 12VDC connections. Has anyone tried it? Geeetech Round PCB Heated bed for Delta Rostock
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:46AM |
bluesmike
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:50AM |
Deguello
Yeah, if I do it I'll go with the American one. I'm working on adding an inductive proximity sensor, so I need to keep an aluminum surface. I guess I could unsolder the leads from the original bed and lay the PCB under it with silicone grease between.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:58AM |
