Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 01, 2015 05:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 01, 2015 06:14PM |
thevisad
Great post and good on finding that out. How and where did you locate the balls that were the proper size?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 01, 2015 06:20PM |
llamatrails
Are you talking about the thin 1mm red end caps? Can we just remove them while they are still on the rails? Will the screws still hold the green sections in place?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 01, 2015 10:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 01, 2015 10:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 02, 2015 01:02AM |
Deguello
I bought this one from Amazon, but IR doesn't work with the mirrors I use for my build surface, so I didn't spend a lot of time on it. I eventually removed the autoprobe altogether and calibrated the endstops and radius.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 02, 2015 03:19AM |
Sven.L
DC42, can you give me a list of the parts you exchanged with new ones? And where did you get those new parts? Please let me know, so I can order from the same locations. What is now your printing area size?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 02, 2015 03:35AM |
Koenig
Deguello
His IR-sensor is modulated though, plus uses 2 diodes at different height, and should work with any surface (except mirrors) there's even a video of him doing a autocalibration on glass-surface.
[youtu.be]
I haven't even put my kit together yet, I was so displeased with the rails, and the replacement rails I got, that I ordered some rails from igus (about 3 veeks delivery), but you know the thoughts of modding it never ends...
I've also glanced at this electronics kit from ebay: [www.ebay.com]
But I thought I could get it working with the shipped electronics first as I have constructed a few other mods that I need to print as well.
Where should one look for firmware for that electronics?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 02, 2015 08:06AM |
dougal1957
IMHO Don't even consider the Ramps-FD setup
There are several posts in the Ramps controll sub Forum re this the most recent being Ramps-FD
Plus you can get a DUET from Replikeo (This is what DC42 uses) for $79.99 DUET OK there is no LCD display as standard but you could use one of DC42's PaneDUE kits (They are superb) or just go with the Webinterface which is also Superb.
Doug
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 03, 2015 01:54AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 03, 2015 09:11AM |
matthew900
Attached are the pictures of the bars I removed with red arrows pointing to them. In the picture of the slide you can see how bearings are missing. I also included a picture of the slide with bars removed before being reinstalled on the guide rail. Please note it will not just slide on without the bars. You must put something in the middle to hold the bearings in then slide it out as you slide in the guide rail.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 04, 2015 12:41PM |
rotten_carrot
Thanks very much for your posts regarding the rails - and of cause the all important pictures. It would seem that you've cracked it! I've just finished cleaning and lubricating my own. Two weren't too bad but one was completely seized and took a good soak in gun oil for the slider to shift at all. I'm sure that it will come as no surprise that all three are missing one bearing on each side. The gun oil has made an unbelievable difference but although I'm quite happy with the results I'm not sure if I would describe them as butter smooth - sliding at speed yes but slowly no so much. And so, finally to my question and the point of this post, how easy is it to reinstall the sliders back on to the rails and how easy is it to damage them? Essentially what I'm thinking is do I stick or do I twist?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 04, 2015 12:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 04, 2015 01:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 04, 2015 11:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 05, 2015 09:16AM |
Junestronger156
Your delayed unit might be a blessing in disguise. You have doctors figuring it out for you. So as a patient, you have less mistakes to worry about. I'm not saying I'm a doctor, but I sure have vested a lot of time putting it together, and some of my notes here should help. The Blomker's assembly guide is very helpful since Folgers is not ready with their guide yet.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 05, 2015 09:44AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 05, 2015 03:17PM |
DonSz
I purchased the Folger Tech Kossel and I am beginning the assembly of the carbon rod ends. The rod ends seem to be quite stiff. Do they loosen up in use or do they need to be lubricated somehow? Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 05, 2015 07:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 06, 2015 05:26PM |
Wittmason
I just posted some adjustable spool holder arms for our Kossel made from the "Spool holder that uses Emmet's gear bearing".
Adjustable spool holder arms for Emmet's gear bearing spool holder
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 09:28AM |
bluesmike
Ok I have a weird issue that Im having a hard time figuring out. Small print jobs print fine but large print jobs the head lifts on one side of the job and stays about an inch above the bed. So lets say that the object is 180x50x20. The print job will start at y90,x-90 and start to move to y-90,x90 after the head passes y0,x0 it steadily lifts until it is about an inch off the bed at y-90,x90. I had removed the autolevel routine from the gcode before hand but have since added it back in. Im stumped!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 10:48AM |
bluesmike
bluesmike
Ok I never got this resolved. I recalibrated the printer and it will print small jobs fine. On large jobs it still lifts about 1" from the bed and thinks its printing fine. It does this with both stock firmware and TheVisads firmware. Any ideas on what to do next?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 02:44PM |
llamatrails
bluesmike
bluesmike
Since small jobs are fine, when do you see the height increase start? Is the increase always when your piece is taller than X? Does it increase slowly or jump?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 02:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 03:57PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 07, 2015 11:15PM |
greggo
which way does the heat break go? does the PTFE liner side face away or towards the nozzle?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 08, 2015 07:03AM |
bluesmike
I haven't measured but lets say I print a flat square that is 50X50 - it prints fine. If I try to print a flat square that is 100X100 it starts to lift as it traverses from y to x steadily. It doesn't seem to jump just slowly rises.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 08, 2015 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 08, 2015 02:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 08, 2015 04:07PM |
cislom
Is the only place I have to tweak the DEFAULT_AXIS_STEPS_PER_UNIT in configuration.h file? I think the default is 84mm (189/2.25 with the 20 step gears). i was going to tweak these out a bit, but i was wondering if there is another spot to do it, or if there are multiple spots?
Thanks again everyone!
