Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 09:59AM |
jculver09
Koenig
What I gather from this thread is that the extruder included in this kit is no good so I'm thinking of getting an "all metal" extruder, like this: [www.ebay.com]
Would that be a good choice or does anyone have a better recommendation?
As far as the extruder, I am still using the original hotend, only issue I have is that changing filament is a PITA because internally things dont line up well enough to use the extruder stepper to reverse old out and push new in. I have been eyeing the E3D V6 but cost for me is the prohibiting factor so the lite6 has also been on my mind. I am not 100% convinced the hotend in our kits is a major issue if you are just using PLA (as I am) and I am not sure how much of an upgrade the lite6 would be since it has a PTFE liner as well.
The cold end on the other hand was ok to get me started, but did not last more than 3kg of filament through it. I picked up an ez-struder from here: [seemecnc.com] I have put 2kg through it so far and I am very happy with it. The install was a piece of cake, just make sure if you order one you get the push connect fitting too as it does not come with the ez-struder unit.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 11:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 12:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 12:41PM |
Koenig
matthew900
Well we finally got everything together, uploaded the 20 tooth firmware with the Arduino program, but we're getting an error in Pronterface. We get a bunch of random symbols when we try to connect. I've attached a screen print of what's happening. Does anyone have an idea what could cause this or have suggestions for what to try? I'm using the USB cable it came with and I've tried every USB port on my computer, and re-uploading the firmware a number of times. Any help would be greatly appreciated. Thanks!
I think you need to change the speed that pronterface communicates with the printer to 250k.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 01:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 02:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 02:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 02:41PM |
There is a minimum temp that the extruder must be at before it will extrude, probably 170. Make sure you turn the extruder on and let it come to temp. Then tell Pronterface to extrude 100mm. If you don't do this first... you'll bang your head trying to determine why it wont extrude. I know... that was 6 months ago and I still have a bump.Quote
tadawson
Using something like Pronterface, enter '100' in the length box, and hit the 'extrude' button . . . . Others should be similar. Considering that there are multiple printer interface packages, myself, I can't fault Folger for not documenting things they didn't write, sell, support, or ship . . .
And, unless the drive gear on your extruder is a different dimeter than what came with the kit, extruded length should not change . . .
- Ti
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 02:44PM |
mmcginnis9272
There is a minimum temp that the extruder must be at before it will extrude, probably 170. Make sure you turn the extruder on and let it come to temp. Then tell Pronterface to extrude 100mm. If you don't do this first... you'll bang your head trying to determine why it wont extrude.Quote
tadawson
- Ti
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 02:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 03:18PM |
matthew900
If they included instructions for the part they shipped I would have a starting point which is my complaint.
I tried to put in the 100mm in that box but then it started freaking out about the hot end not being heated. Is there a line command to just feed the filament or a way to bypass the hot end safety protocol?
Just noticed the hotend question was answered while I typed this. Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 03:28PM |
tadawson
Or simply comment that out in Configuration.h for the duration of calibration, setup, and testing . . . "PREVENT_COLD_EXTRUDES" or close, IIRC . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 04:08PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 04:21PM |
tadawson
I would have liked a few other angles on the photos, but that's it. What part of the kit did you feel the documentaion overlooked?
-Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 04:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 04:36PM |
matthew900
tadawson
-Tim
Everything past calibrating the axis. There's nothing on loading the filament, calibrating the extruder, calibrating the temperatures on the hot end and hot bed, loading and printing the test print, and how to make adjustments based on the test print. I know these seem like simple obvious items too an experienced 3D printer user like yourself but a little guidance or at least direction to online resources that cover these items would be helpful for a beginner like myself.
I know enough to come to the forums for research and help but someone doing this on their own without any additional information would be unable to get as far as I have. I don’t expect perfect exact instructions but I would expect instructions that get you though the construction to completing your first test prints and adjustments.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 05:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 05:22PM |
matthew900
I would have preferred to use the parts in the kit but some of the printed parts where so bad that they started delaminating as soon as I tightened the screws. And I’m not talking about super tight, just a little past snug. They were so bad that they had already cut away part of the first layer that had delaminated before they shipped it.
Since I had to order new corners I went ahead and ordered a new extruder as many of you on here had recommended. Other than that I used all the provided parts. Except of course all of the additional nuts and screws I had to buy since not enough where supplied with the kit.
I’m not sure where the link you provided came from but that is not the current version of the instructions that they provide on Google drive to people who purchase the kit.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 05:36PM |
tadawson
mmcginnis9272
tadawson
- Ti
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2015 05:57PM |
matthew900
tadawson
-Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 02:22AM |
thevisad
Because these are beyond the scope of the document you are referring to. Also, half the questions are answered inside the firmware, if you would only take the effort to read the configuration.h file or the posts in the forum, just on the page prior [delta-calibration.s3-website-us-west-2.amazonaws.com]
[github.com]
You do not need to adjust the extruder gear normally. Find what the setting is for direct drive, set it at that and leave it alone. [github.com]
Calibrating the bed/hotend is not always needed and is an end user adjustment to make the printer behave better. [reprap.org]
Test prints are your own thing, something for you to learn how to do using the tools provided and the equipment you have. Have fun and experiment. [www.thingiverse.com]
I did not have the forums, did not the additional information and I was able to complete, build and make my prints perfectly pristine with little effort (and a little research). I am only (when it was built and still to this day) using the items that came in the kit, with some additional tweaking. Items that were replaced were the crappy direct drive extruder gearbox, the gear and the hotend throat for a duplicate one. Items added were the insulation, the hotbed platform (removed the acrylic round offsets in favor of 1/4 inch plywood.) Pending upgrades are Budaschnozzle/E3D hotend, Duet controller, magnetic effector/glides.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 05:55AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 08:52AM |
bluesmike
bluesmike
Ok I have a weird issue that Im having a hard time figuring out. Small print jobs print fine but large print jobs the head lifts on one side of the job and stays about an inch above the bed. So lets say that the object is 180x50x20. The print job will start at y90,x-90 and start to move to y-90,x90 after the head passes y0,x0 it steadily lifts until it is about an inch off the bed at y-90,x90. I had removed the autolevel routine from the gcode before hand but have since added it back in. Im stumped!
Ok I never got this resolved. I recalibrated the printer and it will print small jobs fine. On large jobs it still lifts about 1" from the bed and thinks its printing fine. It does this with both stock firmware and TheVisads firmware. Any ideas on what to do next?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 10:00AM |
bluesmike
bluesmike
bluesmike
Resolved this awhile ago and forgot to post my findings up. Re-calibrated several times and found nothing out of whack. Loaded up a part for a quadcopter build that's 100X115X15 and watched the print job closely. As the slider on the X tower came down I heard a slight THUMP THUMP and saw the belt shake. The slider was hitting the bottom stop! I killed the print job and dropped the bottom stop about 1/4" and now everything is fine.
On another note, I really dislike these sliders. They are noisy and wobble slightly. Is there a more accurate quieter setup?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 11:04AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 11:17AM |
tadawson
You don't take the file over, you edit the values from the old version into the new version, by reading and comparing. As you have noted, a bunch of stuff has restructured in Marlin, and the old Configuration.h file won't just drop in.
To get the entire release, you need to be up a few levels at [github.com] You can select 'Download Zip', or, if you feel like installing git on your box, use the link given and do a git clone of the project . . . (which also lets you get incremental changes via git pull . . .)
Note also that the github link you offered is a private repo, not the main repository (which is here: [github.com] ). Not sure if you meant to be looking at that repo or not . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 01:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 01:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 02:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2015 05:58PM |
