Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 27, 2015 07:16AM |
hideehoo
It lives! Using the latest Repeiter firmware and host, with Slicr doing the slicing inside of Repeiter. Pretty much all defaults at this point. These are the first prints after a rough calibration. 10mm cube came out a little rectangular (9.5mm x 10.2mm) and I need to recal with the bed and hotend heated to account for expansion (first layer was really squished). Raised the Z by 0.3mm on the next print, dropped the PLA temp to 190, and Marvin came out pretty good.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 27, 2015 10:06AM |
Flish
Well, I stand (partially) corrected - all the free software produces about the same print quality (seen this firsthand and is not open for debate) Simplify 3D might be worth the price... don't know firsthand about this one though. I mean, don't get the idea that you can have a machine not dialed in properly and have $150 magic software make up for that.
Whats with the slicing time? I've not see complicated large models take any more than 2 minutes to slice with the free offerings. However, this might be more dependent on the computer running the slicer... This certainly isn't a time bottleneck for the 3dprinting process though. Still, this wouldn't be a selling point for me.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 27, 2015 10:48AM |
davidf01
hideehoo
Nice. how did you work out the carriages? did you just go with parts you shaved down so there was no rubbing or did you work something else out?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 27, 2015 06:58PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 27, 2015 08:12PM |
cman8
Havent tried anything but Slic3r and that has worked for me, it has crashed on me a few times though loading stl files. It would be interesting to try Simplify3d. wish there was a free trial. But agreed with all the rest. Mechanically sound printers should be the priority first and foremost. I would have never thought of printing nice prints like this when I first started and to some this isnt even that great. To me it is though.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 28, 2015 03:26PM |
SlowFoot
dc42
SlowFoot
Thanks!
I have access to a workshop so I can machine the parts and/or make custom shims. But I still need an idea of what a reasonable tolerance is. At what level will the error drown in the general noise?
That's a very good question. I haven't done a mathematical analysis of the effects of different bearing spacings at either end of a pair of diagonal rods, or of the effects of the two rods in a pair having slightly different lengths. I have not seen any such analysis either. Maybe I'll do one when I have more time. All I know is that my effector does tilt slightly, and I compensate for the resulting probe height errors in the calibration macro file. Reducing the bearing spacing difference from 0.35mm to 0.1mm didn't help, so the problem must lie elsewhere in my build.
I built a simulator in the CAD, it is a bit of a beast to work with but I got some results.
0.5 mm wider between the balls joints, symmetrical error, at one carriage, give an error of less then a micron at the nozzle.
I only tested three positions so far I will play more another day.
Cheers!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 28, 2015 04:44PM |
Here's one I printed out a couple months back...|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2015 11:30AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2015 07:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2015 08:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2015 09:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 29, 2015 09:27PM |
tadawson
Folger doesn't have any bearing on what will work or not . . . the Kossel 2020 is bone stock Marlin and RAMPS1.4, so if the display works with that pair, it works with the printer . . .
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2015 01:27AM |
Rattfink
tadawson
- Tim
I understand that - i am asking about LCD touchscreens and if anyone has one - suggestions or experiences.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2015 12:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2015 02:42PM |
davidf01
Rattfink
tadawson
- Tim
On page 49 of this thread somebody posted something about a PanelDue screen. Not sure if that helps or not but it looked like a nice screen.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 30, 2015 07:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 11:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 12:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 12:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 02:11PM |
thevisad
Sven.L
Rattfink, can you give me a URL for your hexagonal extruder? Thanks.
How many microns is the printing resolution of the Kossel 2020? Who knows?
The tip is a .4, you can go down to .1 layers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 08:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 11:38PM |
Rattfink
tadawson
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 11:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 31, 2015 11:59PM |
davidf01
Quick question for you. Can anyone tell me if this wiring looks correct? The instructions has different writing on the circuit board then
the one I have. I'm just trying to make sure I'm setting this up correctly before I put power om it.
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 12:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 12:59AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 02:01AM |
cman8
For those that replaced your steppers, do you have to reconfigure the fw and recompile? Or is it just plug n play? I bought these as suggested. Will they work better?
[www.ebay.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 07:09AM |
thevisad
Corner braces for a Delta designed for the Folgertech size machines. These work perfectly with the Robotdigg corners, should work fine with the Folgertech and should add some rigidity to the machine.
http://www.thingiverse.com/thing:993474
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 07:31AM |
davidf01
Does anyone know when or what I use the tensioner bolts in the sliders for? The directions say they will be use later but it never gets to it in the Rev B draft insturctions.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 11:36AM |
KDan
I tried braces like that several months ago (except modeled all in one piece) and they seemed to do almost nothing to reduce tower shake. The frame was still twisty. I decided that a lot more leverage was needed. So I modeled these...
It brought the machine to a whole new level for rigidity. No more tower shake, the frame can not twist, and the surface quality of certain parts was clearly improved.
