Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 01:15PM |
Koenig
davidf01
Does anyone know the specs on the hot end that comes with this printer? I'm looking to buy some new nozzles for it and I'm not sure what to get? Do we have a MK9 type and not sure what threads it has?
It's M6 thread in the heatblock, confirmation it by measuring the naked part of the heatbreak, between heatblock and heatsink, with a pair of calipers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 04:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 05:05PM |
Cyber7
I'll be getting my Kossel this Monday. The manual really needs some work and lacks a schematic. So I made a wiring schem specific to this kit.
Let me know if you find any mistakes. Also, the Hot end fan setup should work on D9 as shown, but has not been tested.
Kossel 2020 Wiring Schematic
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 05:29PM |
Cyber7
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 05:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 06:00PM |
thevisad
The fan should be connected to d9 i believe it is and not always on. With this you can control the speed and fan from inside the firmware. Otherwise you are locked into having the fan forced on for you.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 09, 2015 06:09PM |
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 10, 2015 07:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 11, 2015 01:23AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 11, 2015 01:38AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 11, 2015 02:56AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 11, 2015 03:21AM |
davidf01
So I have figured out what the problem was. I found this inside the hot end. I have no idea what would cause something like this. Any ideas so I can stop
it from happening again.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 11, 2015 09:43PM |
Koenig
davidf01
Did your extruder chew into the filament when this happened?
It has happened to me as well, twice. there's a little space between the PTFE-coupling and the heatsink where the filament can "curl up" and if your extruder is pushing the filament to hard this will happen.
It can happen if you are over-extruding or if your nozzle gets jammed by something.
It probably got jammed when your fan got disconnected
I solved it by fine-tuning my stepper driver, so it starts skipping steps before this happens, so for any reason my hotend can't keep up (low temp, over extruding) it starts to skip steps instead of grinding into the filament / makes a salad underneath the PTFE-coupling.
Ultimately I bought my self a genuine E3D v6, no "curl up"-space on these, and threw that chinese knock-off that came with the kit in the bin.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 12:51AM |
davidf01
Koenig
davidf01
Koenig,
Is this the version of the extruder that you got?
[www.amazon.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 01:38PM |
cman8
Thats probably it then. I had mine unplugged for 1 layer of printing by accident and it makes the throat get hot enough to make the plastic pliable which in turn makes a jam like you see. Keep the heatsink fan running and you should not have that issue anymore.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 01:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 04:32PM |
Koenig
davidf01
Koenig
davidf01
Koenig,
[www.amazon.com]
Yes.
Although I got it considerably cheaper, I bought from reprap.me's ebay store.
If you don't plan on printing any materials that require more than 240°C (which you can't do today anyway due to PTFE-lining) and/or use long retractions I suggest getting the E3D lite6 instead.
The E3D v6 is an all metal hotend thus somewhat prone to clog when printing PLA and using to long retractions, the lite6 has a PTFE lining inside like the hotend you are using today and less prone to clogging + it's cheaper.
I own one of each today, they have the same measurements so easy to switch + I plan to build a slightly larger delta so I'm going to have use for both.
But you don't have to shell out any money on this, it is enough to just tune the driver to start skipping before you get that salad in the hotend, the difference is with the E3D v6/lite6 you can use slightly more torque but you still want to tune the driver so it won't chew into the filament.
It's a rather fine line torque-wise between the salad and the chewing into the filament, so think twice before you spend your hard earned cash on this, do you really need that slight increase in torque or would it be enough to just tune the driver?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 05:14PM |
davidf01
I would love to try printing some flexible material
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 12, 2015 06:28PM |
Vlerherg
davidf01
Flexible material is very fun to print with, but can be a headache as well, especially with a bowden setup. The softer filaments (like NinjaFlex) are not really usable (in my experience) with bowden, as the filament surface creates far more friction in the tube than solid filament and will not feed correctly, if at all. Even with my non-bowden setup on one of my other printers it is tricky, but when it works, it is awesome. If you do try it and have success, let me know which filament you used, as I'd be interested in giving it a go as well!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 12:28AM |
davidf01
Vlerherg
davidf01
Vlerherg, I will keep you posted for sure. I was reading the information on the E3D v6 website and they were talking about how the new design allows for printing flexible material
That you couldn't do with a normal Bowden design. I will order one of these and let you know as long as it is not to hard to swap out with the current hot end.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 10:36AM |
davidf01
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 10:53AM |
Vlerherg
I cannot recommend the E3Dv6 hot end enough. It is the Cadillac of hot ends, to be sure. I use them on my other two printers and have not regretted it for a moment. I will eventually pick one up for the Kossel as well.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 11:39AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 12:19PM |
Koenig
There are users that has indicated that the "all metal E3Dv6" gives you some trouble when using long bowden tube and printing PLA, so depending on what you plan to use most it is a good idea to also mention the Lite6 which is a bit more forgiving.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 13, 2015 01:58PM |
wrangellboy
On the topic of extruders. Does anyone know the practical upper limit of the stock folger unit? I've got a roll of PETG I've been experimenting with and it likes to print really hot. I've read many hot ends can't really go above about 245, but petg has a print temp suggested range up to 250, and in my experience hotter is better. I realize 250 from my thermistor doesn't neccesarily mean the hot end is actually that temperature, but I'm wary of going too high and melting the ptfe tube.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 15, 2015 08:33PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 16, 2015 12:37AM |
davidf01
So when I order this E3D V6 do I need to add the Bowden add on I though I read that it has a Embedded bowden coupling. Not sure what that means?
Thx
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 16, 2015 02:37AM |
davidf01
Thx
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 16, 2015 01:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 16, 2015 03:08PM |
davidf01
Ok Thanks for the help folks. I ordered the E3D (v6) Hotend - 12 Volt / 1.75mm Universal w/Bowden Extras.
Now is it pretty straight forward to hook this up? Do the wires all go to the same places as the current hotend?
