Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 10:37AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:14PM |
davidf01
Some more calibration questions. I have been calibrating my printer. I made this test print based on a bunch I have
seen online and now I'm not sure what I need to adjust to correct the measurements. See attached picture.
It seems that each tower is off slightly and they are not all off the same amount.
Thevisad I'm guessing this is where your updated firmware can come in and help?
Any help would be great.
Thanks
Dave
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:23PM |
paul_delta
davidf01
Thanks
Dave
Try this istruction [bootsindustries.com]. And adjust DEFAULT_AXIS_STEPS_PER_UNIT accordingly.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:28PM |
Koenig
No need to go through that to adjust your steps/mm, if nothing has changed FT includes 20tooth pulleys which corresponds to 80 steps/mm with 1/16 drivers.
In that guide they use printed pulleys which is why they do travel and measure, since this kit includes metal pulleys that is not needed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:43PM |
davidf01
Thanks
Dave
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 04:56PM |
paul_delta
Koenig
OK, in Repetier there is a special variable, per tower, to adjust diagonal rod for accurate per axe dimensions. What variables in this case should he adjust in marlin, from your point of view?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 07:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 08:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level October 31, 2015 08:33PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 03:52AM |
davidf01
I wouldn't mind switching to Repetier but there is no information on how to set Repetier up on this printer. Everytime I try i get results
that are unusable. What firmware do I load to use with Repetier and what settings do I change to match what I have now in marlin?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 04:03AM |
paul_delta
Tip: forget about paper test - it is not accurate enough! Use drill bit - roll it under the hotend tip close to the screw and adjust the screw so the drillbit will roll just slightly touching the tip.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 11:25AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 11:32AM |
Koenig
paul_delta
Don't say that, I just people put to much into it.
The paper test is just a feeler, what you want to do to get it 99.9% right is: finetuning after the paper test.
But then again all calibration counts on a totally flat bed that is absolutely perpendicular to the towers.
Bed leveling is another matter for that you can use screws like the ones you have done, or a probe to correct it in firmware.
Making sure that you have a bed that is perfectly level should be done before any calibration.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 12:20PM |
thevisad
Paper has long been the defacto tool in almost all industries for measuring the gap between two objects. As a mechanic who worked with points and condenser systems, I used a dollar bill as the proper gauge distance to create the right air gap for optimum power. Standard 80 lb paper is .0055 thick, out of the package, every package. So when paper is used and the nozzle is pinching the paper, the tip should be .0055ish to the bed. You cannot much more accurate then that, 10 sheets for a penny. I dare you, absolutely double dog dare you to go to Harbor Freight and buy me a box of straight drill bits. Drill bits are not precise enough to be used as a measuring device regardless of the quality of the bit simply due to the manufacturing process. If you truly wanted to measure this in the correct manner, then you would use feeler gauges; however, tight quarters, heated beds and ease of use makes paper the way to test.
Also, unless you are removing the bed after a print, swapping beds out for one another or using FSR's for adjusting the tip to the minute variations that exist on a heated surface after they have been vigorously heated from room temperature, then the bed should be set it and forget it and your focus should be on the hotend.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 12:47PM |
paul_delta
thevisad
So many men so many minds. With paper test It's very hard to get accurate calibration. Even more - for delta this is completely wrong way, because the chances to crash the head are very high - there is no safety room. Now you have an airgap, second later you have unneeded deformation of whole system. The drillbits give you a room to work, they have zero deformation under tip pressure and precise enough - I measured couple of them with calipers - the opposite end of drill bits were always pretty accurate and round even cheap drill bits from HarborTools. I use round end of drill bit, the straighteness of rod in this case doesn't play a role because of simple geometry. So, I highly recommend to try this way. But I understand that "paper as a tool" traditions is a kind of religion and I respect religious people
The deformation of the paper is what makes it a good way of doing this, because you want it to pinch the paper but not clamp it down, it should move both backwards and forward with some resistance but not shred or fold, how do you distinguish that difference with a drill bit?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 12:55PM |
Koenig
paul_delta
thevisad
Just try, OK? You will see the difference in gradations/feeling.
PS: of course the drill bit must be small enough - 1.5mm-3mm max. With 10mm drill bit there is a chance to get non-symmetrical (oval) end.
Edited 2 time(s). Last edit at 11/01/2015 12:59PM by paul_delta.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:00PM |
paul_delta
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:07PM |
dc42
The problem I have found with the paper test is that the result you get depends on the friction of the bed surface. Higher friction surface (e.g. PVA glue) -> greater height at which the nozzle grips the paper as hard as you are looking for. But I still use the paper test for checking the Z=0 height because it's quicker than using feeler gauges.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:10PM |
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:23PM |
paul_delta
Please let me remind that I'm talking about bed leveling - the way to get the tip equidistant from the bed on at least 4 points. Of course paper test is better (faster) way to get Z0 when everything is flat.
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:27PM |
dc42
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:28PM |
thevisad
paul_delta
Lol, I do not need to "try and see" I know from a lifetime of working with mechanical objects, measurement tools, manufacturing processes and designing my own objects based upon the measurements I have taken. A drill bit is not a measurement device, you absolutely cannot take a 5/16 drill bit, a number 45 drill bit or a 2.5 mm drill bit and tell someone use that as your measurement. Drill bits have variations based upon how they are made, cut, ground, shaped and sharpened. Paper; however, is like I stated before an industry standard thickness.
This used to be a Folgertech printer and has been rebuilt from the ground up. This was created with proper tools to measure spaces, why on earth would I use some ramshackle process to gauge a distance or tell someone else to do so?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:41PM |
paul_delta
I know, you are cool But the problem is that you don't listen me carefully. Again, I'm talking about round (non-working) end of drill bit as a hard, cylindrical object where diameter doesn't play any role. It's just a round object that we can roll under tip to make sure that the tip is equidistant from the bed near screws and in the center. I don't care that it's 2.98mm and not 3mm as it should. I measure it, and I know it's 2.98mm. And when everything is on level, I know that I should change ZMAX to 2.98 to get perfect zero.
PS: I don't want even discuss that hardware bed leveling is much, much better that a set of software compensations with their errors and floating point math problems.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:49PM |
thevisad
My issue is when you tell others to try a mechanically inaccurate process to create mechanical accuracy. So to quote your own comment, you didn't listen very carefully, this tool [www.harborfreight.com] sold for 4.49 + tax is designed for the exact purpose of what you are "trying" to do and is the proper tool to use in replacement of paper.
Again, bed leveling is a MUTE point on a printer then bed will never be removed from.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 01:57PM |
paul_delta
thevisad
OK, we speak about issues... My issue that you make a fork of Marlin that has z-probe problems and confuse people that think that this fork is the best they can get. So, please stop spaming this tread.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 07:30PM |
