Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 07:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 01, 2015 11:06PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 03:21AM |
davidf01
Can anyone tell me where the measurements are taken for:
DELTA_CARRIAGE_OFFSET
DELTA_EFFECTOR_OFFSET
I measure from what point to what point for these two settings?
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 08:54AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 10:32AM |
Legrand
Hello everyone!
I'm new to the 3D printing universe and have purchased a Folgertech Kossel 2020 that I'm trying to fire up.The build went relatively smoothly (although they sent me the wrong heat bed and it's a good thing I have access to a machine shop to fix some parts) but my problem seems to be that the end stops just aren't doing anything. I try to "home" the machine and the three axis (after I inverted them in the code) fly to the top of the printer but when they hit the stops (which do light up), the motors just keep trying to drive the axis further. If I take smaller steps using Pronterface while holding any of the endstops closed (tripped, lit up) then I can still move any and all axis. Any ideas what the issue might be? Did I just get a bad RAMPS board?
Thanks for any ideas and assistance.
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:06PM |
thevisad
Sounds like your endstops are either not actuating or are backwards. The fact that they light up is an indication that this is occurring, but RAMPS is not obtaining the signal. Check the wiring on the end of the harness and that you have them plugged in correctly.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:18PM |
Legrand
thevisad
There is only one way to plug them into the small boards where the switches are, and that's keyed so you can't screw it up. I plugged the other three in per the instructions as seen in this pic:
I have passed some m119 codes to the board via Pronterface and if I activate a switch it will report "TRIGGERED" however the motors do not stop.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:21PM |
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:36PM |
paul_delta
Legrand
OK, look at your endstop from the conector side. The wires order from the bottom Green, empty pin, Black, Red. Correct?
Attach your Configuration.h file, I think something wrong with firmware logic.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:45PM |
Legrand
I downloaded the firmware right from Kossel and have flashed both the REVB and REVBPE versions (I have no idea what the difference is). I'm currently using BPE with a couple minor tweaks for axis inverting and offset lengths.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 01:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 02:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:22PM |
Koenig
davidf01
Thanks
[attachment 65128 Delta_geometry.jpg]
Do keep in mind that the "DELTA_EFFECTOR_OFFSET" is an imaginary point between the rods in a pair.
However, both these measurements don't really serve a purpose, the only interesting measurements in that picture is the "delta_radius" and "delta_diagonal_rod"
but both repetier and marlin have chosen to complicate the "delta_radius" by having to input "delta_smooth_rod_offset", "delta_carriage_offset" and "delta_effector_offset"
and then calculate the "delta_radius" from those three values, something like: "delta_radius" = "delta_smooth_rod_offset" - ("delta_carriage_offset" + "delta_effector_offset")
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:34PM |
davidf01
Koenig
davidf01
Thanks
Well According to this picture my Delta carriage offset is way off due to the fact that Folgers carriages did not fit my kit properly. My
DELTA_SMOOTH_ROD_OFFSET is also off by about 10mm if I measure from this picture.
Would these two settings mess up my prints by 0.8mm or less?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:44PM |
davidf01
Koenig
davidf01
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:45PM |
paul_delta
Repetier configuration tool sets these values to zero. I guess your diagonal rod lenght is the reason. If you will print asterisk from thingiverse, you will see which tower has longer or shorter diagonal rod. Both marlin and Repetier allow to correct the lenght of rod per tower - repetier via GUI and Eeprom, Marlin via changes in calculation in .cpp file.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:52PM |
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 06:54PM |
Koenig
paul_delta
IF that is his problem, might as well be the tower offsets (tower radii) that might be off.
Or a combination of the two, hard to tell.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 07:05PM |
paul_delta
Koenig
paul_delta
Actually, yes. But finally we can tweak only rod lenght per tower to compensate such kind of dimension errors.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 07:08PM |
paul_delta
Koenig
paul_delta
PS: I assembled my Folgertech Kossel pretty accurate, all parts were attached almost with zero gap.All rods were assembled using special tool that I build especially for this purposes, so all rods were absolutely identical. But after measurement one axe was OK, but two another had around 0.5-0.7mm off with asterisk calibration model. Finally I printet DIY asterisk with maximum radius that bed allowed, changed rod correction per tower and now I'm pretty happy with measurements.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 07:12PM |
Koenig
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 07:16PM |
paul_delta
Koenig
Were you actually sure you made the rods so inaccurate?
The other error, tower radii, is much harder to take any physical measure to confirm.
paul_delta
Of course it was not rod. Something in the frame size. Some people complained about aluminum corners that sometimes are slightly off of right angle. But rod compensation solved dimensional errors completely.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 07:26PM |
Koenig
paul_delta
Koenig
paul_delta
Correcting to wrong thing will likely give you other issues, like inconsistent Z=0, meaning the thickness of the first layer will vary over the build pate perhaps even so much it will get hard to get it to stick over the entire build plate
You can correct the angles as well.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 08:01PM |
Koenig
paul_delta
Koenig
paul_delta
As I said, might not be the rods that need correcting but the tower radii.
Both errors give dimensional inaccuracies.
If has done his rods in a jig it's unlikely there the problem is...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 08:23PM |
davidf01
My rods are damn close. I made a jig to make them and they are measured and all of them are the same size or at lease within 0.1mm. I'm guessing my tower offsets are the problem.
I just need to know what to adjust to test if it is the tower offsets or not. I think it has something to do with the build. My aluminum corners were not perfect and I had to use a belt strap
to get the frame together.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 08:49PM |
paul_delta
davidf01
I guess there are only two things you can adjust in software - the tower's angle and diagonal rod lenght per tower (if angle in printed asterisk is wrong or lenght of asterisk for corresponding axe is off).
Adjustment of diagonal rod lenght per tower, actually, compensates frame problems. As I said, In my case I'm pretty happy with results. My software (Repetier) diagonal rod adjustment, per tower, is:
A : 0.920mm
B : -1.341mm
C: -1.054
As I said, my rods almost ideal and these corrections compensate frame misalignments or something else.
PS: the quality of deflector from FolgerTech is far from good. I suspect that all compensations I have to add are because of dimensional disproportions of deflector (uncalibrated printer in Folgertech per axe, for example.). Probably I'll print one myself with all my calibrations and will see the difference.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 10:00PM |
Koenig
paul_delta
davidf01
A : 0.920mm
B : -1.341mm
C: -1.054
I don't know how many times I have to mention this for you but the the tower radii (offset) is correctable both with Marlin and repetier.
I've mentioned in at least my three latest posts.
Not in the version provided by FT but in later "official" versions, thevisads repo have it together with other settings suitable for this printer.
If you go for thevisads version look for something like "tower_correction" in configuration.h
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 10:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 10:40PM |
fattmann
After a few weeks of hiatus from trying to get this thing setup, I am back with more (of the same ) questions.
I was having trouble getting my Z axis to move 10mm when told to have it move 10mm. As of right now it is only moving 5mm. I had upgraded to the Drv8825 stepper drivers after finding all mine from Folger were bad. I was enlightened earlier in this thread that you have to have the jumpers in a different configuration to get 1/16 steps out of the 8825s. Using the advice of others, and this guide, I attempted to just have the M3 jumper, and leave the FW Steps Per Unit at 80 (20 tooth pulley)
That did not help. In fact, any configuration of jumpers, and Steps Per Unit all result in moving 5mm instead of 10mm. Nothing seems to change that at all. I'm also still running into the issue that I have to have my MANUAL_Z_HOME_POS over 500 (534.4 to be exact) to get it to pass the paper test. I was hoping that that was tied to the steps problem, but so far I can't fix one to fix the other.
Every time I adjust the FW, or jumpers- I completely power down, disconnect power/usb, then recompile and upload FW. Every time.
What else can I look at?
EDIT: When I use the M114 command, it indicates that it is moving 10mm digitally, but only moves 5mm when placed against a ruler.
