Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 10:47PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 11:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 02, 2015 11:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 01:49AM |
paul_delta
Koenig, I respect your patience but I'm really tired of your RADII Probably it's just terms misuse...
Again, I'm talking about per axe size disproportion of printed item. This is what DIAGONAL correction does (Corr. diagonal A/B/C in Repetier). I don't care what is the reason of such disproportion - I just know that diagonal rod corection per tower is the way to handle it, with minimum AVR computation power. I don't need ABC/XYZ delta radius compensation because I have no gaps with Z0 across A/B/C towers - everything is flat enough to forget about delta radius correction PER TOWER.
PS: and it's not correct to use "tower offset" in this matter, because it's linked to endstop adjustment - both in Marlin and Repetier.
Perhaps the most common problem with Delta printers is dimensional inaccuracy. I am not sure if this calibration method produces other undesirable results, and your milage may vary. My Rostock had a discrepancy of ~0.3mm in Tower A, and this is how I corrected it. It took me a few iterations of this process before I was able to print an asterisk that is symmetrical to 0.05 - 0.1mm, which should be good enough to produce parts for another printer (an oversized Kossel is my next project).
Here is a test object that I use for calibration. It's quite simple. It's an asterisk with the diagonal lines running parallel to each tower, with a horizontal line through the centre. It should be rotated so that the diagonal lengths are parallel to Towers A and B.
The purpose of this shape is to try and isolate movement from each tower to determine whether the 'lines' each one draws is equal. Inevitable inaccuracies in the build (radial positioning of towers, distance from centre and rod length) will produce distortions in the X and Y axes.
These errors are best accounted for by assigning individual DELTA_RADIUS values for each tower. If you happen to have uneven rods, I recommend remaking them.
In order to allow for individual DELTA_RADIUS values for each tower, add the following lines to your Marlin Configuration.h file:
// Tower position correction
#define DELTA_TOWER1_CORRECTION 0.0 // front left tower
#define DELTA_TOWER2_CORRECTION 0.0 // front right tower
#define DELTA_TOWER3_CORRECTION 0.0 // back middle tower
And find these lines in Marlin_main.cpp (2 places):
float delta_tower1_x = -SIN_60 * delta_radius; // front left tower
float delta_tower1_y = -COS_60 * delta_radius;
float delta_tower2_x = SIN_60 * delta_radius; // front right tower
float delta_tower2_y = -COS_60 * delta_radius;
float delta_tower3_x = 0; // back middle tower
float delta_tower3_y = delta_radius;
And alter them to look like this:
// Effective X/Y positions of the three vertical towers.
float delta_tower1_x = -SIN_60 * (delta_radius + DELTA_TOWER1_CORRECTION); // front left tower
float delta_tower1_y = -COS_60 * (delta_radius + DELTA_TOWER1_CORRECTION);
float delta_tower2_x = SIN_60 * (delta_radius + DELTA_TOWER2_CORRECTION); // front right tower
float delta_tower2_y = -COS_60 * (delta_radius + DELTA_TOWER2_CORRECTION);
float delta_tower3_y = delta_radius + DELTA_TOWER3_CORRECTION;
You'll need a pair of calipers for this part. I find that it's best to use them as a kind of feeler gauge, rather than relying on the reading they give. You'll probably find that the length changes a little depending on where you measure and how much pressure you apply. With any luck, the lengths of the lines will be very close to one another. If you have large discrepancies (> 1mm), I suggest backtracking and looking for errors in the build. It is important that you measure test prints once they have properly cooled. ABS will shrink more than PLA, so it might be a good idea to do this with PLA.
Measure each length of the asterisk, taking note of the differences between them. Pick the two lengths that are closest to one another, or the length closest to your target size and use that as your reference point.
Start by adjusting the tower correction value for your innacurate tower(s) by twice the negated value of the difference. If you have two towers that are out of kilter, just start by adjusting one of them. For example, you have a difference of -0.3mm in Tower A, set the correction value to be 0.6mm.
Adjusting the radii of each tower will affect the endstop calibration for that tower (if you increased DELTA_RADIUS, it'll raise the effector at the base of the tower). You might also need to tweak the overall DELTA_RADIUS value (start by making a +/- 0.25mm adjustment to DELTA_SMOOTH_ROD_OFFSET).
In any case, get the effector moving flat once more (again, it shouldn't matter if it's not perfect, as you'll be tweaking things again) and perform another test print. Measure and repeat.
Once you're happy with the symmetry of your asterisk, work on getting each tower perfectly level and the effector moving dead flat. You should be able to send it moving all over the build platform without having it lift or dip.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 01:57AM |
paul_delta
AFAIK RAMPS doesn't support 1/32.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 08:10AM |
Koenig
Why go trying to correct something that is correct from the get go is beyond my understanding + that trying to do so introduces other errors.....
You just won't take anything in of what other people write right...?
Here's the base for my claims:
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 12:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 02:37PM |
Legrand
I have my next problem. When I try to move the printer head to a specified location in the Z-axis only, it doesn't move any where near straight down.
The guy here that knows a tiny bit about 3D printers stated that it might have something to do with the steps. I currently have them set as:
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 80, 100}
It seemed to me that if the three axis are set the same, then it should move the same? I can see that I might be thinking about this incorrectly too though. Is this a possibility, that they're just set incorrectly?
Another (more mechanical guy) says that it might be drag on a couple of the axis (an answer I better understand). I will mention one caveat: When I assembled the roller sliders onto the rails, they were so tight that they cause the three rollers to be flexed out. There is a screw that goes thru the two sides which you would use to bring the rollers closer together, but that will never be used because the slider unit was so tight. Did I get a bad set of printed parts? Is it supposed to flex out when assembled? The rollers will move but they're pretty stiff.The part I'm talking about is this one:
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 02:42PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 02:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 02:51PM |
Legrand
I have been homing prior to any move. The move I've been inputting is "G0 Z200" (or some other Z value) immediately after sending it home and it doesn't move vertically, but rather at some sort of diagonal.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 03:11PM |
Koenig
Legrand
How many of the motors actually move when you give the command?
dc42
Try adding an F parameter to your G0 Z200 command, e.g. F1000, to specify the speed. It may be trying to move too fast for your combination of motor rated current, current set on the drivers, and supply voltage.
paul_delta
Did you check Drivers Vref voltage (small boards on RAMPS that manage steppers)? If carriages are tight and one of drivers underpowers stepper motor - the behavior could be like you described.
Try to change two boards, for example move X to Y and Y to X and see if there is any change in diagonal move.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 03:26PM |
Legrand
I have not tested the voltage nor tuned it per the instructions here: A498 Tuning I will try to change two boards tomorrow as I'm out of time here right now. Does anyone have any better instructions than given on that sheet? They're not really all that great and I don't want to toast something. It mentions removing a capacitor and such from the boards... I'm a little concerned about that.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 04:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 04:35PM |
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 04:57PM |
paul_delta
Legrand
It's easy. Actually, you don't have to change anything, just set Vref voltage. Hook your multimeter "-" probe to the ground (on RAMPS board, for example, one of "-" marked pins and your "+" multimeter probe to the center of potentiometer. Adjust potentiometer, using provided ceramic screwdriver, to get 0.35v on your multimeter. For extruder driver set it to 0.5v. I think it will fix all your issues with motors.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 05:03PM |
Koenig
I think 0.35V is a little high on the small motors provided by FT, if they haven't changed it they ship this kit with Chinese a4988 pololus that have 0.1Ohm sense resistors which would result in a 0.7A current for a motor that is only rated for 0.4A.
There are some reports about melted/deformed corners due to hot motors.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 05:15PM |
paul_delta
Koenig
Yes, they are slightly overpowered, but revision B. of Folgertech Kossel has aluminum corners that work like heatsinks. My motors are just slightly warm after 5 hours of printing.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 03, 2015 10:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 08:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 09:13AM |
fattmann
Also when I start a print, it jumps the temp from the PLA 185C preset I selected, and waits to hit 205C, I don't get that part either. Nowhere in the settings does it say 205C.
fattmann
I don't understand how it is trying to move outside of the print radius that is set?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 09:19AM |
Check your slicing software and inspect generated g-code. There is definitely temp. command in g-code that waits for 205.
Because the model you are trying to print is bigger than your radius or has too big offset from the center of bed (because of wrong setting is slicing software, for example).
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 09:23AM |
fattmann
The model I was trying to print was only the size of a Nickel, so I know the object wasn't too big. I will investigate this offset setting. Thanks!
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 09:38AM |
paul_delta
fattmann
Check your printer settings in slicing software, looks like there is default cartesian printer setting. You need to select Delta and 0,0 coordinate will be in the center this way.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 11:33AM |
paul_delta
dc42
Also check that you have the microstepping jumpers set to x16 (i.e. all 3 jumpers present) under all of the drivers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 11:51AM |
Legrand
Next up is that I will try to figure out why it's not going to the center of the bed when I hit the center (X/Y) button in Pronterface.....
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 12:32PM |
Koenig
Legrand
Do you mean it doesn't go down to the bed, or that it just doesn't center in the plane it is over the bed?
Have you set that you have a circular build platform in pronterface?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 12:36PM |
Legrand
Koenig
Legrand
I mean that it doesn't center in the plane over the bed. It just drives one motor pushing the head to one side.
I do have the circular build platform checked (now), but it doesn't change anything.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 04, 2015 12:43PM |
Legrand
Koenig
Legrand
