Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 25, 2015 03:04PM |
fattmann
Whoa. Good to know. My buddy swears by Hatchbox, so that's what I've stared off with. Will keep that in mind when performing further tests.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 25, 2015 03:41PM |
Vlerherg
It is more of an issue regarding your particular bowden setup, speed, temp, retraction, etc, as stated before. I can personally vouch for Hatchbox (as many others can, I am sure). For straight PLA/ABS I buy theirs exclusively and have only ever had one bad roll (inconsistent diameter halfway through a .5kg roll of translucent red PLA) out of 30 or so. Have not tried any of their specialty filaments. I tend to go towards higher end sources for those. In my experience with direct drive, speed and temp are the most important, with retraction being farther down the checklist. With bowden, retraction is #1 with temp and speed close on its heels. On my Folger Kossel I never even installed the stock extruder. I had printed a nice bowden wade style geared extruder for my cartesian printer, but never could get it dialed in. String city and oozy plastic everywhere. Nothing seemed to make a difference. That same extruder on the kossel works like a champ with almost no work to dial it in. Odd.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 25, 2015 08:57PM |
Vlerherg
fattmann
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 29, 2015 08:50PM |
paul_delta
No, I don't like how this Hatchbox Silver PLA prints small objects. My Moon Wihte FolgerTech PLA prints are much cleaner and the roll is two times (!) cheaper. I reduced retraction speed twice - to 30mm/s and temperature to 175C - still visible blobs and strings:
[attachment 66587 IMG_20151125_204705643.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 29, 2015 09:11PM |
fattmann
paul_delta
Interesting. I don't get any of the blobbing, but I definitely get the stringing. Next color I buy I will have to try Folger Tech's. Thanks again.
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 30, 2015 03:27AM |
fattmann
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 30, 2015 02:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 30, 2015 03:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 01, 2015 12:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 01, 2015 08:16PM |
Legrand
I can't seem to get ABS parts to print out without curling up on me.
I tried:
Glass with purple Elmers glue
Glass with an ABS slurry
ABS slurry directly on the aluminum heat bed
7mm wide brims
2 layer thick rafts
Nothing seems to help. Will the temperature of the bed directly effect this? I can set my bed to 110°C and eventually it will get there, but as soon as I start printing (no matter what temperature I set the bed at) the temp f the bed drops to the mid 90°'s C. During printing it never really gets above 96°C.
Is this drop in temperature because the motors are pulling too much juice from the power supply and it can't keep up? Is this why the ABS prints keep pulling up? I'm getting fairly frustrated because I can't print anything larger than about 1" long before I start having issues. Any help would be greatly appreciated. Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 01, 2015 08:20PM |
paul_delta
Try this solution: [www.thingiverse.com]
Legrand
I tried:
7mm wide brims
2 layer thick rafts
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 02, 2015 06:23AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 02, 2015 07:41AM |
Legrand
Thanks Paul. You don't think that the curling has anything to do with the heated bed not being able to stay at temperature? It's a simple matter of adhesion?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 02, 2015 10:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 02, 2015 11:00AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 02, 2015 04:57PM |
fattmann
Legrand
I believe that the tip that folger supplied with the 3mm hot end is 0.3mm.
I've wondered this too, what is the size of the Folger tip? Have they changed it from Rev A to Rev B?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 07:59AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 08:48AM |
Legrand
So, here's what I'm getting with the 3mm PLA filament running at 210°C. I slowed the print speed down to 75, which would have been equivelant to an infill rate of 60mm/sec. Looks like garbage.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 09:16AM |
paul_delta
Print will look like this when the speed is too high, temperature is too low or extrusion rate is too low. You say the speed is 60mm/s, so it should be OK, the temperature looks OK too (I print PLA at 180C, actually), so you have underextrusion. The nozzle size in slicer is wrong, filament diameter in slicer is wrong or you have to calibrate your extruder steps.
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 09:23AM |
Legrand
it either can't melt it fast enough, or the extruder setup isn't capable of creating the force required to push in the filament.
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 11:28AM |
paul_delta
.... You say the speed is 60mm/s, so it should be OK, the temperature looks OK too (I print PLA at 180C, actually), so you have underextrusion. The nozzle size in slicer is wrong, filament diameter in slicer is wrong or you have to calibrate your extruder steps.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 01:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 02:07PM |
Legrand
QUESTION: Since I've never printed anything sucessfully in PLA, how do I get this thing off the bed without warping the hell out of it? Do I just let the bed completely cool down and then lift up the tape?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 02:47PM |
Sir_Death
paul_delta
Not neccesarrily correct.
In earlier days PLA was always printed around 185°C; Nowadays - especially in Europe - you only get PLA to print at 210-230°C!
I print PLA at 230°C, 25mm/sec - not more possible with my chineese hotend...
EDIT Nozzle 0,4mm, Layer 0,2mm
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 03:49PM |
Legrand
I had some problems getting above 210°C due to the hot end being too close to the circular radiator and fan (after I switched over to the 3mm head) so I created a small aluminum "foil" shield to keep the "wind" away form the hot end and am now printing at 230°C.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 03:52PM |
paul_delta
Here is my video. I've just printed 20x20 model using stock FolgerTech rev.B Kossel, 04mm nozzle, Black FolgerTech PLA at 180C, bed 50C, speed 120mm/s infill, outline 80mm/s, 0.3mm layer.
I interrupted it in the middle. With DYI active cooling I posted recently.
120mm/s Kossel video
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 04:01PM |
dc42
paul_delta
Assuming the video is running at normal speed, I think it's printing at more like 60mm/sec. You can tell by the time it takes to print the long diagonal. It may be that the print speed is acceleration-limited, and you need to print a much larger piece to reach 120mm/sec.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 04:41PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 03, 2015 05:02PM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 04, 2015 03:04AM |
Legrand
Settings:
230°C Head
70°C Bed
3 mm PLA filament (from RS, good material but was purchased thru Allied electronics, don't buy from them, their deliveries take forever)
0.45 mm nozzle
0.3 mm layer
80 mm/sec infill
60 mm/sec perimeter
