Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 15, 2016 09:22PM |
chaster
Minor question - did other people receive four pieces of plastic U-channel with their kits? They are about 7mm wide and 1.5' long (sorry for mixing units.. I don't have a long metric ruler). I just noticed them sitting in the box and the instructions don't make any mention of them. I am guessing they are for aesthetics (covering up wires that run in the slots of the aluminum extrusion) but just wanted to make sure they aren't for something else...?
Eric
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 15, 2016 09:27PM |
Dav3xor
My heater plate had a little bow in it; I figured out it's geometry, and with a careful and studious use of my foot, and a copy of Bill Shatner's autobiography (hardcover), I was able to make it as flat as my cheap metal ruler and a bright light source could measure.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 15, 2016 11:49PM |
09zx-6r
ok so i have my FT kossel Rev B calibrated on XYZ... PID auto tuned the Bed... BUT when i try to PID atuo tune the nozzle, it wont go over 78C !!! i have a full 12.10VDC at the cartridge connector...
SUGGESTIONS ????
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 16, 2016 12:11AM |
09zx-6r
09zx-6r
SUGGESTIONS ????
Anyone?????
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 16, 2016 02:10AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 16, 2016 09:03PM |
09zx-6r
Any one know how to relocate the heat bed symbol on the LCD full graphics display... i can move the position of the temps but not the symbol itself... how do i do that... i dont like that its all the way to the right...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 17, 2016 01:11AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 17, 2016 01:26PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 06:13AM |
faithblinded
I lowered my temp and adjusted my retraction settings, and now I'm getting really good prints, with no stringing at all. Thanks Paul Delta for all your help and suggestions!
I printed a fan shroud that splits the output between the heat sink and the part, and my hotend seems to be holding a much steadier temp. It was falling off due to the quick infill motions of my printer, so I drilled a couple holes in it, and wrapped a zip tie around the top of the heat sink to secure it. Good to go!
I'm still looking for a printable spool holder that works well with the revB extruder setup, as stock. Any suggestions would be appreciated.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 09:20AM |
Legrand
Faithblinded: I use this one on my two FT machines: Universal Spool holder
When the tripod base is printed out, you'll notice two blind holes at the ends of these feet. I drilled them thru with a 3mm bit and then mounted the base to the top of the machine with some of the extra t-slot nuts and bolts. Works like a charm.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 09:24AM |
faithblinded
Legrand
It's funny you posted this. I was getting ready to make a post later today with pictures, about how I found my perfect fully printed spool holder. It's that one! You should grab the current files for it. There are a bunch of alternative bases, including a couple made for 2020 extrusion. I printed one, and it mounted on top of my printer. It spins effortlessly even with the heaviest roll I have. Now I can feel comfortable that a 10 hour print won't fail due to filament feeding issues(happened to me a couple times before I printed this). I like this spool holder so much, I'm printing parts for a second one, with the standard tripod base. I know more printers are in my future, so why not.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 09:31AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 09:33AM |
Legrand
Small world...
I forget to mention that I had issues with the cone part printing due to the text on it acting like the first layer and printing it the other way made for a sloppy print (large overhang angle wasn't printing nicely), so I remodeled it without the text and if anyone needs it, just let me know.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 09:53AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 02:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 05:12PM |
Legrand
OK, I'm coming back at the auto leveling problem since my plate keeps getting skewed when I remove parts from it (with the springs under it).
Can anyone who had the "climbing problem" tell me how they fixed it, and Paul, do you have to have some sort of compensation factor, or offset, since you're probing so far from the nozzle?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 05:27PM |
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 18, 2016 10:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 04:05AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 06:08AM |
09zx-6r
Legrand
if ur refering to the nozzle climbing as it reaches the outside of the plate then you need to ADD (+) a dimension to the DELTA RADIUS...(note the BOLD print at the end of the equation)
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+.30)
your number may differ... but if the plate is cupped then you add if its humped then you subtract a number
if the plate to nozzle distance is flat but the plate is tilted, then adjust your endstops
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 06:16AM |
EvilBetty
Hi everyone. Just completed my Folger Tech Kossel 2020 build (first 3D printer).
Everything went together right the first time, thanks to this forum and some very scattered but helpful videos.
I am up to the point of printing my first test cube, and I'm getting nothing from the nozzle.
The first time I attempted it, I realized I didn't have the filament all the way down to the hot end, so I stopped it, loaded the filament all the way down and started again. Still nothing.
The filament was skipping in the extruder motor gear. I pulled the PTFE tube from the hot end, and a length of squiggly filament. PTFE still disconneced, I turned on the hot end heater manually via Repetier, and then manually extruded filament. Motor / gear worked fine.
I trimmed off the length of filament, Used a flashlight to make sure I could see light from nozzle to compression fitting, and refitted the PTFE tube, fed filament to the hot end, and then tried again. Same thing.
Repeated all from above, except this time turned the heat up from 195c to 205c. Same thing.
One last time I just heated up the hot end to 205c, and checked the hot end with an infrared thermometer, showed 63c from the outside (fan off).
I'm not sure what to try next. Suggestions?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 09:18AM |
EvilBetty
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 09:53AM |
paul_delta
Does it show correct room temperature when hot end is cold?
Btw the fan must be on all the time when hot end is hot. The filament must reach melting temperature only inside the square block or it will stick to the wall and clog the tube.
EvilBetty
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 01:58PM |
Legrand
Betty,
Since your extruder motor is skipping and you measured the hot end at 63°C and you're pulling out those unmelted strands, I'd have to say that your hot end isn't getting up to temperature properly.What type of filament are you trying to print with?
It is heating though, so can you ascertain the temperature that the "software" is telling you it's at? If you send a M105 to the printer (after the hot end is theoretically warmed up) it will report back the temperature.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 02:19PM |
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 02:20PM |
Legrand
Something else I just remembered as well, when you assemble the square hot end to the radiator (the cylindrical heat sink with lots of grooves in it) you must make sure there is a gap between the square hot end and the cylindrical radiator. If you don't leave a gap, then the radiator will suck too much heat from the hot end and it will never reach he proper temperature. I found out this the hard way.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 02:23PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 02:25PM |
EvilBetty
Since I couldn't print and couldn't think of anything else to try, I gave something else a try.
[www.youtube.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 06:58PM |
EvilBetty
paul_delta
Seems to.
Bed has begun warming, Hot end room temp.
Hot end fully heated.
My fan was off. I believe I have it set to "Auto" in the config.h. I also noticed when turning it on manually it is blowing away from the fins. If there was a shroud I'd leave it that way, but as it is now I'll flip the pins when I get home.
Thanks!
-EB
